Question about Exercise & Fitness
Hi, I have a Reebok Fusion treadmill and lately
Hi, I have a Reebok Fusion treadmill and lately it has gotten really noisy when I increase the speed. Sounds like its the motor, what do i do?
    Top Expert:
  • 12,223 Answers
LUBE THE deck belt,+rollers bearing front and back. test the drive belt motor, and replace the belt if necessary.
However if the problem persist, TIME to replace the deck belt
God bless you
Posted on Aug 01, 2013
  • 15 Answers
SOURCE: the treadmill stop when i increase the speed and t...
Error 26 is what's known as a Motor Pulse Width Incorrect. It basically monitors the sensor signal and verifies that it's appropriate for the requested speed. If your machine uses an infrared sensor, check the line of sight between the optical eye and the sensor target, an array of black and silver wedges arranged like a pie. Ensure that it is 3/16" apart and that it's pointed at the larger point of the wedge section. Use an electronic cleaning compressed air cleaner to blow out any particles that could block it. Have a close look at the target, if it's torn or badly scratched, it will need to be replaced.
If the machine uses a hall effect sensor (magnetic) ensure the distance between the flywheel tooth and sensor is 3/16".
You can sometimes get this error if the speed sensor is faulty, but usually it will happen without you even touching the controls at that point because the lower board isn't receiving any signals from the sensor, or you will get a different error code.
Posted on May 28, 2010
SOURCE: hi my reebok treadmill was plugged in during a
how do i replace the drive belt on8700es
Posted on Aug 07, 2010
  • 218 Answers
SOURCE: where can I get a owners manual for a reebok
iconservice.com
Posted on Aug 11, 2010
  • 15 Answers
SOURCE: I have a reebok fusion treadmill, been fine until
reset the running timer, for the amount of time you would like to walk run ecsetra
Posted on Oct 25, 2010
AJIN G
  • 6694 Answers
SOURCE: reebok 5500C - when turn on treadmill and increase
hi,
Replase the IGBT on the aluminium heat sink. this problem will be solved. Adde the photo of IGBT .
ajin_g_5.jpg ok
Posted on Mar 08, 2011
Fix led displays
Check to see if the RPM/speed sensor is functioning. On some models this sensor is positioned next to the pulley on the front roller and opens and closes each time the magnet on the front roller passes the sensor.
The sensor could have failed, or it may simply be too far away from the magnet on the front roller. 1/8 " is the normal distance between the sensor and magnet. It is also possible that the magnet is missing from the front roller.
Be sure to post the units exact model# which normally starts with RBTL....
Nov 29, 2013 | Reebok Exercise & Fitness
HOW TO REWIRE A REEBOK FUSION TREADMILL
Dear Sir:
If you do not have a wiring diagram +schematic diagram will be difficult for you to do it.
You have 2 options to buy the a) schematic and wiring from www.fitnessrepairparts.com
b) Call to the Reebok Treadmill and ask for Service Tech.
sincerely. God bless you
Apr 25, 2012 | Exercise & Fitness
Reebok fusion rower manual-how to operate the electronic display
I have recently bought from a friend a reebok fusion treadmill. However due to a break up the treadmill was dismatled and put into storage and now they cannot remember where the wires go. Can anyone help?
Oct 15, 2011 | Reebok New York Giants Eli Manning Jersey
Reebok 5500C - when turn on treadmill and increase the speed, the motor has a sudden surge, for approx 1-2 seconds, then stops.
hi,
ajin_g_5.jpg ok
Mar 08, 2011 | Nordic Track Mc2100wa Treadmill Motor...
Distance screen on treadmill
It's in Miles The treadmill goes a max of 14km an hour - if you increase the speed it only goes to 8 - 14km per hour is 8.4 miles per hour and I've been running between 5.5 and 6.5 and covering 3 miles which would be about right :) Hope this helps
May 05, 2009 | Reebok Exercise & Fitness
Oil can caption on my reebok fusion treadmill (rev10301)
It means that you need to spray silicone between the belt and the platform it runs on
Jan 10, 2009 | Reebok New York Giants Eli Manning Jersey
I have a Reebok Fusion Treadmill, an Oil Can Icon has appeared
I have the same problem. I phoned Reebok Tech Support 01908 512244. It is a timed icon to advise the deck should be lubricated. If you have done so / do this regularly you can ignore it. To remove the icon follow the instructions they emailed me. Hope this works Cheers John Please follow procedure below:
1. Keep power on and remove the safety key
2. Press and hold incline down and speed down, at the same time insert the safety key
3. You can release the “Down” buttons. (you will now hear a beep)
4. Press Speed up
6. Press stop. You will now hear a beep and the icon will disappear
Dec 02, 2008 | Exercise & Fitness
Exercise & Fitness Logo
110 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
