Question about Dryers
LG Dryer not heating at all. DLG4802W gas dryer. Already replaced two thermostats Thermostat 6931EL3003C and Thermostat Assembly 6931EL3004B and still not heating. Only 18 months old.
    New Friend:
  • 24 Answers
Check your igniter, if that does not get hot enough it will not open the gas valve. If it does not glow at all check for voltage if voltage is present 120vdc replace igniter.
Posted on Aug 01, 2013
4 Suggested Answers
  • 3 Answers
SOURCE: Dryer shuts off after a few minutes
THE KENMORE DRYER I HAVE... IF REN IN THE COTTON CYCLE IT WILL RUN FOR 50 MINUTES AND SHUT OFF. ITS BOLWING HOT AIR AND THE OTHER CYCLES SEEM TO WORK FINE WITH OUT SHUTING DOWN SO ID APPRECIATE A TIP ON WHAT THIS PROBLEM COULD BE
Posted on Nov 02, 2008
flacooo1
  • 172 Answers
SOURCE: Gas dryer continues to run on the Auto cycle.
try to get the manual for the dryer you got and locate the moisture sensor if this sensor is bad what happen is that the automatic timer thinks that the clothes still wet and continues to dry once the sensor detects no moisture then it shut off the dryer normally is located behind the dryer on the exit line of the air duct and tested for conductivity and see if is good or not
Posted on Mar 27, 2009
  • 142 Answers
SOURCE: LG TROMM Front Load Dryer / Not drying clothes
check the vent or condensor depending on what type of dryer.
Posted on Sep 28, 2009
My whirlpool dryer comes on and runs good but it wont get hot can you tell me whats the problem
Hello there and welcome to fixya there are several things that could make this dryer not heat up
Here are the most common things
Thermal Fuse
If the dryer doesn\'t heat, but the drum
turns, check the thermal fuse(s). The thermal fuse protects the dryer
from overheating and helps to prevent fires. If the thermal fuse is
blown, it will have to be replaced.
Enter your model number to see parts for your dryer.
Help me find my model number
Gas Valve Solenoid
The gas valve has two or more electric
solenoids which open the valve to let the gas flow into the burner
assembly. If the dryer doesn\'t heat one or more of the solenoids may be
defective. If the igniter glows for 90 seconds but the burner flame
doesn\'t light, replace these coils as a set.
Dryer Igniter
If the dryer doesn\'t heat, the igniter might
be burned out. Check the igniter for continuity with an ohm meter. Dryer
igniters burn out over time, similar to a light bulb.
Heating Element
The heating element on an electric dryer can
burn out over time. If the dryer doesn\'t heat, the element should be
checked for continuity. The heating element cannot be repaired and must
be replaced if defective.
Heating Element Assembly
the heating element assembly on an electric
dryer can burn out over time. If the dryer doesn\'t heat, the element
assembly should be checked for continuity. The heating element assembly
cannot be repaired and must be replaced if defective.
Flame Sensor
Gas dryers have a flame sensor to detect the
heat given off by the flame. If the dryer doesn\'t heat, the flame sensor
might be defective. Check the flame sensor for continuity. This is not
as common as a burned out igniter or thermal fuse.
High Limit Thermostat
Although not common, if the dryer doesn\'t
heat the high limit thermostat can be defective. It can be checked for
continuity. If the thermostat is "open" the dryer doesn\'t heat.
Cycling Thermostat
The cycling thermostat regulates the
temperature of the air in the dryer. If the dryer doesn\'t heat it may be
caused by a defective cycling thermostat. This is not common.
Main Control Board
The main control board is normally not at
fault when the dryer doesn\'t heat. Check all of the other components in
this troubleshooting guide before replacing the main control board. The
main control board cannot be tested easily and must be replaced if it is
defective.
Timer
The timer is normally not at fault if the
dryer doesn\'t heat. In many situations where timers are replaced they
end up being returned. Check all of the more common components in this
troubleshooting guide before replacing the timer
Oct 14, 2013 | Dryers
Lg gas dyer no heat.
In most of the case you have the safety thermostat pop up. It would be reset but will not last long, you should replace a new one. Part number is 6931EL3003C. It is located at side of the burner cover. Else, you can check the igniter. Both part can be checked by measure the connectivity, if it has open value, replace by a new one.
Sep 16, 2013 | LG DLG5932S Gas Dryer
Whirlpool electric dryer high thermostat replacement
test all this steps in according with your model, electric or gas. God bless you
Thermal Fuse
If the dryer doesn't heat, but the drum turns, check the thermal fuse(s). The thermal fuse protects the dryer from overheating and helps to prevent fires. If the thermal fuse is blown, it will have to be replaced.
Gas Valve Solenoid
The gas valve has two or more electric solenoids which open the valve to let the gas flow into the burner assembly. If the dryer doesn't heat one or more of the solenoids may be defective. If the igniter glows for 90 seconds but the burner flame doesn't light, replace these coils as a set.
Dryer Igniter
If the dryer doesn't heat, the igniter might be burned out. Check the igniter for continuity with an ohm meter. Dryer igniters burn out over time, similar to a light bulb.
Heating Element
The heating element on an electric dryer can burn out over time. If the dryer doesn't heat, the element should be checked for continuity. The heating element cannot be repaired and must be replaced if defective.
The heating element assembly on an electric dryer can burn out over time. If the dryer doesn't heat, the element assembly should be checked for continuity. The heating element assembly cannot be repaired and must be replaced if defective.
Flame Sensor
Gas dryers have a flame sensor to detect the heat given off by the flame. If the dryer doesn't heat, the flame sensor might be defective. Check the flame sensor for continuity. This is not as common as a burned out igniter or thermal fuse.
Although not common, if the dryer doesn't heat the high limit thermostat can be defective. It can be checked for continuity. If the thermostat is "open" the dryer doesn't heat.
Cycling Thermostat
The cycling thermostat regulates the temperature of the air in the dryer. If the dryer doesn't heat it may be caused by a defective cycling thermostat. This is not common.
Main Control Board
The main control board is normally not at fault when the dryer doesn't heat. Check all of the other components in this troubleshooting guide before replacing the main control board. The main control board cannot be tested easily and must be replaced if it is defective.
Timer
The timer is normally not at fault if the dryer doesn't heat. In many situations where timers are replaced they end up being returned. Check all of the more common components in this troubleshooting guide before replacing the timer.
Jul 21, 2013 | Dryers
Can you please tell me where the reset button is ? I hate to pay someone $100 to do this. Thanks, Jo Ann Deloy
Hello, welcome to FixYa.
While I don't have a video or diagram I can tell you on the LG dryers there is indeed a "reset" for the heating/burner funnel (as you obviously know) on the right hand side of the funnel, however they also incorporate a no reset "hi-limit thermostat" on the left side of the funnel. Once it is tripped it must be replaced. This is only present on the gas dryers.
It is located on the left side as I mentioned, but the other is on the right side of the heater housing/burner funnel and will resemble the images shown below.
It is part number 6931EL3004B ( the reset type is part # 6931EL3003C ) and available at "searspartsdirect" (which also has a illustration which may help you) or "repairclinic.com" to name a couple.
i.e. NON-RESET
i.e. RESETTABLE
With the aid of an ohm meter you can check the non-reset for continuity, the other you should be able to push the center reset button ( listen closely for a "click" ) but it too can be ohmed out for continuity to confirm or dismiss it's condition.
Hope that help`s move you forward. If so please take a second and rate the guidance and a testimony to the assistance you received here at FixYa, either or all is appreciated.
Let me know if you need any further info and I'll continue to help in any manner I can. Good luck
Regards,
Macmarkus :)
Sep 01, 2011 | LG DLG5988 Gas Dryer
I have a LG-DLG5932W dryer and can't find the reset switch. The sensor on the dry was triggered (no heat) due to air duct clogged. Had the air duct serviced and now to rest the switch. Please show me a...
Welcome to FixYa.
It is located on the left side as I mentioned, but the other is on the right side of the heater housing/burner funnel and will resemble the images shown below. It is part number 6931EL3004B ( the reset type is part # 6931EL3003C ) and available at "searspartsdirect" (which also has a illustration which may help you) or "repairclinic.com" to name a couple.
i.e. NON-RESET
i.e. RESETTABLE
Let me know if you can provide any further info and I'll continue to help in any manner I can. Good luck
Regards,
Macmarkus :)
Apr 03, 2011 | LG DLG5932W Gas Dryer
I have an LG DLG3744U dryer that is 2 yrs old and does not produce heat. I tried replacing the ignitor but that didnt work. HELP!
Welcome to FixYa.
It could be a number of things so the problem will need to be narrowed down. The place I will start is as follows, have you checked the hi-limit thermostat ?
On the LG dryers there is a "reset" for the heating element/burner funnel on the right hand side of the funnel, however they also incorporate a no reset "hi-limit thermostat" on the left side of the funnel. Once it is tripped it must be replaced. This is only present on the gas dryers.
It is located on the left side as I mentioned, but the other is on the right side of the heater housing/burner funnel and will resemble the images shown below. It is part number 6931EL3004B ( the reset typr is part # 6931EL3003C ) and available at "searspartsdirect" or "repairclinic.com" to name a couple.
i.e. NON-RESET
i.e. RESETTABLE
Hope that help`s move you forward if nothing else. If so please take a second and rate the guidance and a testimony to your inquiry you received here at FixYa, either or all is appreciated.
Regards,
Macmarkus :)
Mar 31, 2011 | LG Dryers
I have an older Kenmore gas dryer model # 97260100 it heats up for 15 minutes then goes cold, drum continues to run can u give me any insight as to what needs to be replaced
The problem is either of the cycling thermostat, high-limit thermostat or the gas valve solenoid coils sitting on top of the gas valve assembly. Disconnect power then verify any of these condition by bypassing the thermostats. Refer to the image below and locate the thermostats.
Note: This is an image of an electric dryer but the thermostat and the thermal cut-off (cut-out) locations are the same.
Disconnect each of the thermostat wires then connect and insulate them properly. Once done, reconnect power and start the dryer. The gas valve solenoid coils are indeed faulty and both need to be replaced if the problem still persists. Click here for the procedure in replacing the solenoid coils.
Gas Valve Solenoid Coils Replacement Procedure
Either or both of the cycling thermostat and the high-limit thermostat are malfunctioning if the dryer continues to heat up with the thermostats bypassed. Disconnect power then reconnect the cycling thermostat wires but keeping the high-limit thermostat bypassed. Reconnect power then start the dryer. The high-limit thermostat is the culprit if the dryer continues to heat up. If not, then the cycling thermostat is the culprit.
Also do the other way; that is reconnecting the high-limit thermostat wires but keeping the cycling thermostat bypassed. The cycling thermostat is the culprit if the dryer continues to heat up. If not, then the high-limit thermostat is the culprit.
Replace the faulty thermostat and it should solve the problem.
Nov 08, 2010 | Kenmore 72872 Gas Dryer
Have a kenmore model # 110.72822101, where's the thermostat located, my dryer gets hot then cold
The cycling thermostat or the high-limit thermostat may not be the problem but rather the gas valve solenoid coils sitting on top of the gas valve assembly. Disconnect power then verify this condition by bypassing the thermostats. Refer to the image below and locate the thermostats.
Nov 08, 2010 | Kenmore 72822Gas Dryer
LG dryer not heating, checked thermostat assembly and their fine,any other options?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Oct 10, 2010 | LG DLG5932W Gas Dryer
Dryer not Heating up
hi thanks for the question i would also check the thermal fuse when you purchase the hi limit thermostat also purchase the fuse a lot of dirt in venting will cause the thermal fuse to fail the appliance doc
Sep 27, 2008 | LG DLG5932W Gas Dryer
Dryers Logo
98 people viewed this question
Top Dryers Experts
