Question about Vacuums
Philishave c241 How do I replace the cable philips c241
Dismantle philips tc722/A to repair cable rewind
Briefly, you don't remove the top section, rather you get at the cable drive / release through the cord feed hole.
To do this I use a couple of large flat bladed screwdrivers and get fairly brutal with them to lever out the plastic surround to the cable inlet. it's tough plastic so don't be afraid.
Once the plastic surround is out you can see a piece of black plastic and white plastic. The black should fit in the socket on the end of the white. That's it, just push the white plastic down and the black seats the socket. To test, press the release mechanism and you should see how the black pulls the white drum release back toward the rear of the machine.
once you have done it once it takes about 5 minutes.
Aug 25, 2014 | Vacuums
The on off swtich cannot work in philips vacuum cleanner FC8386/01
Have the switch replaced in a local small appliance repair shop.
Jun 15, 2014 | Vacuums
Changing hepa filter
Helen,
Remove the lid of the Dust Bin, and while holding it upside down in your hand, insert a philips screwdriver (this needs to be a medium screwdriver but with a long blade!) down through the centre of the actuating column. Hold the Filter Refresher knob (green) to prevent it from moving and undo the philips screw.The assembly will now come apart. Pull the actuating column out (the philips screw will remain in the column so don't loose it) The Filter Refresher knob will come away from the Lid. The Hepa Filter can now be removed and the replacement fitted. If the replacement filter is not supplied with a rubber gaskit use the gaskit from the old one..Re-assemble in reverse order.
Jan 11, 2014 | Panasonic Mc-Ul594 Eco Max - Bagless...
Philips 707/05 Portable DVD Player charging issue.
Just go out and get a new charger to replace the one with defective wire/plug.
Aug 31, 2017 | Philips Vacuums
Can I buy a new head for philishave #5401
Replacement frames can be purchased as at the link below.
http://www.espares.co.uk/part/mens-shavers/philips/p/1114/128/0/0/540130/philishave-electric-razor.html
Or replacement blades can be purchased as at the link below.
http://www.shavercentre.com/canada/philips_parts.html
If you need any further assistance then if you advise what country you're in I'll look into it further.
Aug 27, 2011 | Philips Vacuums
I have been lent a Philips Baby Monitor 0682 without a manual and don't know how to work it. Can I access a manual on line, if so How, or do I have to buy one,if so How? Grateful your advice, John...
Hi John.
0682 did not correspond to any known Philips baby monitor model...at least nothing came up in Philips support database. I published below the manuals for different Philips baby monitors. Please check if any of them corresponds to your series.
Philips SBCS369
Philips SBCSC469
Here a list comprising the manuals for most Philips baby monitors models.
Regards.
Ginko
Aug 11, 2011 | Vacuums
The power cable connected to the philishave has got burnt. to be replaced/repaired
The cable must be replaced as soon as possible to avoid any short circuit and damage to your appliances.
Nov 08, 2010 | Vacuums
Problem opening up vacuum cleaner to get at power input from cabl
They're very robust you know, if its an upright, start with the screws at the bottem plate unless there's aa way of accessing the cable from the handle, on a cylinder just undo the hefty Philips screws, i don,t think you need a manual, just keep it all tidy and set out your parts on a nice best table cloth in order of removel, wish i was there with you Joe, good luck , the Yeti
May 20, 2009 | Vacuums
Vacuums Logo
93 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
