Question about ASUS HS1000W Wireless Headset
My ASUS Wireless HS-1000W does not connect anymore. I can successfully charge the headset, but if I connect the USB dongle to my laptop (directly or via a USB hub) it continues to blink green. And the headset continues to blink blue, regardless of pushing the "link"-button. I also tried to reset the headset, but that did not help. I had no problems using the headset until I installed a wireless logitech mouse. Shortly after that, the problem arose. Might that be the problem?
TIPS72
  • 369 Answers
SOURCE: ASUS EEE PC 900 wireless lan doesn't appear on network connection
please if u have a switch for the wifi connection on your laptop please put it on and should see the wifi on your taskbar also please check in controll panel then go to my network connections and see the wifi resides there if yes just right click and enable if not ther check device manager and check for nework devices if the wifi is enable and installed ...if not please installed by right clicking on it and using reinstall..
please let me know what happens
thanks
Posted on Jan 24, 2009
acdr
  • 1913 Answers
SOURCE: ASUS PRO50G series laptop, wont connect to my wireless internet
pls tell me when u clik on connect wi fi what error come.
r u able to connect or not let me know please
Posted on Mar 23, 2009
SOURCE: Intermittent WiFi with ASUS WL-500W
I had the same problem. The problem is interferance from other devices. Solution, Change the channel from auto to a fixed one. That worked for me. No more droped connections, and a very strong signal now.
Posted on Jun 23, 2009
name_mac
  • 28 Answers
SOURCE: My asus Eee pc 4g 701 will not connect wireless
yes! when it comes to wireless networking just make sure that your connection setting are correct just match the settings from your other laptops and do the same to the one you have probles if the persist just do a diognistic check for problems if that doesnt works just hit me back on my link ok!
Posted on Mar 26, 2010
tbreeze47
  • 3083 Answers
SOURCE: ASUS 1000WR. Have had
First order of business would be to try to get an exchange on it, since whatever is going on is not good. The problem could be a bad battery, broken wire inside the headset, faulty board connection in the headset, slightly oxidized or sprung battery contacts, a bad battery, or probably quite a few other things.
Bottom line is, you'll have to probably take it apart to check it out, and it's not going to be fun or easy.
If you can, exchange it. Otherwise, concentrate on why the battery isn't making or supplying the voltage needed.
Good luck, and hope this helps.
Posted on Nov 17, 2010
Why does my headset turn on/off
Seems like what you say a power problem + the wireless band is a busy surroundig. Try some new batteries . It goes on so that's not the problem, it seems to me your signal is too weak to provide the working power and every day hours loading makes it die just faster.
May 18, 2014 | ASUS HS-W1 Wireless USB Headset
Some Questions from germany: In which way is the headset connecting? is it possible zu use just the headset with another transmitter? i mean without the usb dongle - in wich way is it wireless?...
The wireless headset will not work with the USB charging cord plugged in The battery is 3.7 volts at 350 mAh
The physical size of the battery matters too, it has to fit inside the headset. The dimensions are as follows Approx 5.5mm thick by 25mm wide by 35 mm long or .25 X .9375 X 1.25 inches I am sure that some one make Re-chargeable Li-On Battery this size , I just am having problems locating one. Any help would be appreciated Thanks
ole Blake
Aug 19, 2011 | Klipsch FREETALK TALK 5191 Wireless...
What is Bluetooth Dongle?
Hi message4,
Welcome to FixYa! How are you doing?
Bluetooth Dongle is often refer to USB Bluetooth Adapter, it is a device which you connect to your computer via USB port to allow data transfer from your PC or Laptop to Car Kits, Mobile Phones, PDAs, GPS Receivers and much more.
Hope that helps. Thank you for using FixYa.
May 01, 2011 | Acer Aspireā„¢ T180 PC Desktop
Asus wireless head set works for 5 sec than turns itself off
Are you charging it through a USB hub or such like ? Try connecting the USB stick directly into the machine. Some devices will not charge properly through a USB hub,
Mar 29, 2011 | ASUS HS1000W Wireless Headset
Headset is not charging through USB
If you are using a USB hub, then try connecting the USB dongle directly to the USB port of the machine/laptop. Some USB hubs will not charge devices properly.
I had a similar problem with my headsets solved by plugging into a USB port directly.
Mar 28, 2011 | ASUS HS1000W Wireless Headset
I have hp mini 210 laptop. I connect usb dongle of optical mouse to laptop. It installed automatically & successfully. It showing in device manager (Human interface device) but still optical mouse is...
Welcome to FixYa!
Here's a quick checklist to resolve your wireless mouse connection.
Solution 1.
1. If the underside of the mouse has an on/off switch, make sure to set the switch to the "On" position.
2. Make sure that the battery of the wireless mouse is placed correctly and is not drained.
3. After checking the first two steps, the optical lens on the underside of your wireless mouse should be flashing once in a while. If not, there is something wrong with the battery, the wireless mouse switch, or the wireless mouse itself is defective.
4. Connect the USB dongle in the USB port and let it install automatically.
Solution 2.
5. Connect the USB dongle in another USB port and let it install automatically.
Solution 3.
6. Restart the computer with the wireless mouse turned on and the USB dongle inserted in the computer.
Solution 4.
7. Download and install the drivers from here http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?cc=us&lc=en&dlc=en&softwareitem=ob-47909-1
I hope that this will help.
Thank you for using FixYa and keep me posted!
Jas247
Mar 15, 2011 | HP Wireless Optical Mouse
Hello, i cannot connect my headset (ASUS HS-1000W) with my playstation 3.i ve check it with my laptop and it connected.the flash light is green but not steady.i ve done all the procedure from the manual
If this is a Bluetooth headset, I have found that not all headsets play nice with the PS3. I had to switch to the Sony PS3 headset to get mine to work consistently.
Mar 09, 2011 | Video Game Consoles & Games
NS-BTHDST NOT WORKING WITH MY LAPTOP ANYMORE
If you are indeed talking about your Insignia bluetooth headset the reason it works with your cellphone is probably because your phone is already bluetooth enabled, but your laptop is not, which is what the usb dongle is for. You must install the drivers for the dongle for it to make your laptop bluetooth enabled. Once you have that working you need to go to Bluetooth places (should be on the desktop once the driver is installed) THEN hold the button on the headset down until the lights flash blue and red alternating. Once it is flashing, click on add new bluetooth device in the Bluetooth Places and it should pick it up. Once that is going everything is pretty straighforward...follow the wizard. Hope this helps!
Feb 22, 2009 | Insignia Bluetooth Wireless Headphones...
Aspire 3000 laptop
Normally you setup a passkey or use 0000 or 9999 as a passkey.
The question is, does that pop up when you try to connect a USB device? Do you get that when you try to install the dongle? (That shouldn't happen). If you are trying to connect a PDA or cell phone, you setup the passkey for the connecting device on the computer then type it in to the PDA or mobile phone. If you are trying to connect a bluetooth headset, then you use whatever code is from the manufactorer. Normally this is 0000 or 9999.
Hope this helps!
Oct 18, 2008 | Adapters.com Bluetooth USB Adapater, USB...
ASUS HS1000W Wireless Headset Logo
Top ASUS Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you an ASUS Radio Communication Expert? Answer questions, earn points and help others
