I HAVE A MSI MS-7131 M/B PROBLEM IS NO DISPLAY,PROCESSOR HEATING NORMALY,RAM AND CLOCK ON B16 ARE OK .NOT RESET SIGNAL ON A15,WHICH IS GENERATING RESET SIGNAL AND HOW TO SOLVE THIS
  • 3,606 Answers
Hello here is some info about the mainboard:
http://www.motherboards.org/mobot/motherboards_d/MSI/915GLM-V%2B%2528MS-7131%2529/
More info and drivers visit the MSI homepage.
The fault could be the ram module ( wrong mhz size )
The ram module must be DDR ram, other type of ram will not fit the mainboard.
The mainboard does not support more than 2gb of ram, if more insertet the mainboard will not boot up ( no display ) and maybe a beep code will come when you try to boot.
The fault could also be the power supply, or a intenal fault on the mainboard, maybe bad capacitors or the graphic chip is burned.
Try to boot with only one ram module, and try also with another power supply you know is working.
Try also to reset the bios by removing the cmos battery for like 10 min.
The power cord must be disconnected when you do this.
Also try with a intenal AGP graphic card.
Hope you get it running
Posted on Aug 01, 2013
Can i chage my processor pentium 4 to core2duo my motherbourd is(MSI PM8M-V H (MS-7104 v2) thnkz
No, you cannot upgrade to a core 2 duo with that motherboard because it is a socket 478.
Jun 04, 2012 | MSI Computers & Internet
No display but power on ram ok cmos battery ok cpu fan and cpu ok
first check ur display cable for breakr if you have built in display disable it in bios and and if you have addon display card remove them insrert a new addon diplay card if you have display the display section in you motherboard is faulty or diplay add on card is faulty if it still dont work the clock and reset section in your motherboard is fulty to find the at the above section if you have a multimeter check the pci slot A15 means the pci pins facing the processor must have 5v if this is ok your motherboard is ok and the problem is with your display card
Oct 07, 2010 | Intel D845GVSR Motherboard
Is the MSI-K9N SLI-Platinum (MS-7250) capable of running an HD capable video card?
I would recommend upgrading your RAM to 2GB or even 4GB before investing into HD video card. It might be jerky. Your processor should be ok for it as it is.
Jul 21, 2010 | MSI K9N Platinum Motherboard
I have had a motherboard failure the MS-7357 (V1.X) Mainboard... needing upgrade thinking of the MSI G41TM-E43 LGA 775 Intel G41 will i have to mess arround with the power switches with the case as this...
Boards don't come with switches. The problem with company made computers is that they get a manufacturer to make a board especially for the case they make. They do this to specifically stop you doing what you are trying to do, upgrade a machine with a proprietary board in THEIR case. You will find trouble at the rear of the machine getting to sockets and plugs.
It is far better to buy a good case, and then you can swap out components with ease. The case that held my Asus boarded P4 with the first SATA drives now has an Asus Quad Core in it with SATA 2.
MSI G41TM E43 LGA 775 Intel G41 HDMI Micro ATX Intel Motherboard Newegg ca
I would contact MSI direct
G41TM E43 MSI Global
Some of this might be useful
G33M - MSI
https://www.msi.com/Motherboard/G33M.html
... the app from the MSI website. Features - Automatically Detect the BIOS/Driver/VGA/Utility Update - Support Microsoft Windows XP/Vista/7 32/64bit. featurePic ...
::UPGRADE:: G33M (MS-7357) - new processor and RAM - MSI Forum
https://forum-en.msi.com/index.php?topic=125215.0 Mar 11, 2009 - 6 posts - ‎2 authors
The motherboard is a G33M (MS-7357) and has a piddly 1.6ghz processor and 1gb of generic RAM. I'm running Windows XP Home.
CPU-Upgrade: MSI G33M (MS-7357) processor support and ...
www.cpu-upgrade.com > MSI Nov 28, 2010 - MSI G33M (MS-7357) motherboard specifications ... FSB 200 MHz, L2 512 KB, TDP 35 Watt, Conroe-L, Rev A1, SSpec SL9XP, 7357v10.zip.
UserBenchmark: MSI G33M (MS-7357) Compatible Builds
www.userbenchmark.com/System/MSI-G33M-MS-7357/450 Compatible Components (from 7 PCs). Popular components in PC builds with the MSI G33M (MS-7357) Motherboard. CPU. Core2 Quad Q6600Intel $190Bench ...
Oct 21, 2017 | MSI G41TM-E43 LGA 775 Intel G41 HDMI Micro...
HOW TO CHECK RESET SIGNAL ON PCI SLOT OF MOTHERBOARD
you can find out on A15 pin for reset and B16 for clock .
reset singnal have around 5 volt and clock have 1.7 vlt
Mar 15, 2009 | Computers & Internet
No display on IBM motherboard
replace your ram as wwell as cmos battery
Mar 13, 2009 | Computers & Internet
Upgraded computer and won't come on, no bios.
disconnect all and reconnct it.something jammed .may be *********** bord circuit is ground.
disconnect hdd ram then try.
to reattch one by one.
try with only smps ,mother bord and ram.
also check processor sitted correctly.
Nov 24, 2008 | MSI MS-6734-10 (-6734-010) Motherboard
Msi ms 7131 ver1.0 manual
Your post for MS 7131 is either a 915GLM-V or a 915GVM-V. Pls verify/determine which of the 2 you have.
In any case, user's manual for either is available here.
Good luck and kind regards.
Nov 13, 2007 | Intel Motherboard
Computers & Internet Logo
79 people viewed this question
David Payne
David Payne
