Question about Bosch HES435U Electric Kitchen Range
Bosch oven hes435u- stating excessive heat! What do I do?
2 Suggested Answers
SOURCE: Bosch HES435U - Stove Keypad is Locked
Locking or Unlocking the oven control panel
1. Access Select Function Menu
2. Turn knob clockwise until Lock Keys is flashing
3.Touch Start. Key Pad locked is displayed.
4. To unlock keypads, touch cooking mode and hold for 5 seconds. Display will read unlocking key pad
5. When unlocked the clock will again appear in the display.
Posted on Jul 18, 2009
How to lift up glass top for heating element replacement.
Most of these units have a few screws underneath the top at the front lip where the top of the door closes. Remove the screws and you should be able to lift the top up. Most of them also have a metal bar you pull down or up depending on the make and model on the side to hold the top up once you open it
Mar 08, 2015 | Bosch HES435U Electric Kitchen Range
Tip
Common heating faults with Bosch HBN 430560B / 430520B single oven
For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the Bosch fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the BOSCH element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your BOSCH fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your BOSCH oven thermostat
4, A quite common and easily overlooked answer is if your BOSCH oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
on Jan 19, 2010 | Bosch HBN 430560B / 430520B Single Oven
Bosch Microwave Oven
The problem is most likely a bad magnetron, "heart of the system" or the inverter board has failed, "if less than 7 years old"
Apr 18, 2012 | Bosch HMT8625GB Microwave Oven
My Bosch oven will not heat
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jan 04, 2011 | Bosch HBL 445 Stainless Steel Electric...
Shuts off after one hour...won't heat anymore until it is cool
You have a problem with the hi-limit switch. Designed to go off when excessive internal temps are detected, most likely in the controls compartment.
Jun 22, 2010 | Bosch HBL 455 Stainless Steel Electric...
Microwave vent turned on by itself and won't turn off
The HMV9305 has an automatic vent turn-on feature. It senses heat, possibly from the oven or range beneath, and turns on the exhaust fan until temps return to normal. Sometimes this may take 4-5 minutes, which can seem like an eternity of listening to the blower run, but it is a safety feature designed to prevent damage to the microwave from excessive heat generated by the cooktop or oven beneath it.
Jan 24, 2010 | Bosch HMV9305 Microwave Oven
Bosch convection double oven,ovens won't heat,only broilers work
If it is fan assisted then check the fan element, it is located behind a panel at the rear of the oven compartment.
Plz rate my\solution.
Thanks.
Dec 17, 2008 | Bosch Ovens
Apr 29, 2008 | Bosch HLK4525GB Convection/Microwave Oven
Bosch HES435U Electric Kitchen Range Logo
Top Bosch Kitchen Ranges Experts
William Miller
William Miller
ashburton
Are you a Bosch Kitchen Range Expert? Answer questions, earn points and help others
