How to change filter (what size?) on goodman capf1824a6ba? Thank you.
2 Suggested Answers
Joe_Rex
  • 114 Answers
SOURCE: GOODMAN # ARUFO49 AIR HANDLER
MOST ALL GOODMAN ( UP TO 3 TONS)INTERNAL FILTERS ARE 22" x 22" X 1". YOU CAN GET THEM ON LINE AT www.filtera.com. ALWAYS TAKE A TAPE RULE AND OPEN THE BOTTOM FILTER DOOR AND MEASURE THE FILTER RACK. MAKE SURE YOU DO NOT HAVE A RETURN-AIR FILTER-GRILLE. LARGE WHOLE -HOUSE RETURN AIR VENT NEAR OR AT YOUR FURNACE, A/C AIR HANDLELER. Joe_Rex New Member of FixYA Retired HVAC&R contractor 45+ years exp.
Posted on Apr 28, 2007
What do I replace my Goodman Model CPLE24-1C with
goodmans 2 ton. going any larger would require changing orfice and or coil.
Apr 11, 2014 | Goodman Heating & Cooling
Trying to find out how to change the filter for Goodman AC model # ARUF36C14BB
The filter compartment is at the front bottom of your indoor section of the air conditioner.
There should be an access plate located there and may have a 5/16" screw on each side you need to remove to get the access cover off.
An air filter should be visible, and you should slide the filter out toward you for removal.
Mar 27, 2014 | Goodman Heating & Cooling
Goodman capf1824a6ba
Had the same problem; should be the flame sensor, sticks in the flame to monitor temp, take out and clean it or just replace, order on on ebay for ten bucks. Save yourself a 150 bucks to call someone.
Feb 17, 2012 | Goodman GMS90703BXA Heater
What size filter do I use for a GMS8 gas heater? The installer put in a filter that is too large and is hanging out of the side of the heater.
measure how much it hanging out and take this off the size of the filter this will give you the size , try candain tire for filters
May 27, 2011 | Goodman GMS90703BXA Heater
When copying any information from my Computer to my Kodak EP7 printer--the fonts are very small. How can I fix it that the printer will print in a specific size. Thank you, Alvin Goodman...
Please check the following steps:
1. Check the printer page setup
2. try to print some test pages by jumbled fonts sizes
3. try to re-boot the printer
**If this works please rate else let me know in case of further help.**
Jul 05, 2010 | Office Equipment & Supplies
How to change the filter ?
Your filter is in one of two places.
Either its in a filter grille or its at the furnace/air handler itself. If its in the grille, simply remove and replace.
If its in the unit, it will be at one far end of the unit opposite where the electrical connections are. It's uncommon for Goodman to be filtered at the unit as they do not have an independent filter access panel but I have seen it.
If its not in either of these locations, you either do not have a filter installed or your installing contractor has installed a filter box somewhere that will need to be located.
Hope this helps.
Jan 10, 2010 | Goodman CLQ36AR49 Air Conditioner
Easy change out of A/H
This is a 4 ton a/h. Your only Goodman choice is model # aruf486016.
Size specs are 22 wide x 53 1/4 high x 24 depth.
ref. lines 7/8 and 3/8.
Any current Goodman will be these dimensions.
May 01, 2009 | Heating & Cooling
Need to Know Where to Change the Furnace Filter
On the bottom of the indoor unit should be a cover or tray. Sometimes a large grill inside the house, close to the unit is where they are placed. Good luck
Apr 23, 2009 | Goodman Heating & Cooling
GOODMAN ARUF3642
These guys list the actual sizes of a good selection of goodman filters - just measure the old one or the space where it should be and match it to the right filter(should be a fairly tight fit). http://www.filters-now.com/products/dgb.html#skipmenu and this site describes what the different filter types available are http://www.oxyclean.com/goodman.html Hope this helps :)
Mar 07, 2007 | Goodman CLQ36AR49 Air Conditioner
Mar 07, 2007 | Goodman CLQ48AR49 Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
