Question about Datalogic MOBILE PEGASO MOBILE COMPUTER 802.11G WLAN BLUE [950201004] PC Notebook
Wont let me press the start menu - Datalogic MOBILE PEGASO MOBILE COMPUTER 802.11G WLAN BLUE [950201004] PC Notebook
Dont startup
1 Turn on the computer.
2 As the computer starts, press <F8> on the keyboard until the Advanced Boot Options menu appears on the screen.
new_note.jpg Note: You must press <F8> before the Windows logo appears on the screen. If you press <F8> after the Windows logo appears on the screen, the Advanced Boot Options menu will not appear on the screen. If you do not see the Advanced Boot Options menu, restart the computer, and then repeat this step until you see the menu on the screen.
Dec 14, 2013 | Dell Inspiron 1501 Notebook
Key on display wont start
Your washer is in the "child lock" mode, hence it won't allow any program. Press the "menu" button until you see "CHILD LOCK :ON" appear in the display. If nothing is pressed within 10 seconds.following this the menu will close and it will default to program in the display. Once you see that in the display, press the "select" button until "CHILD LOCK :OFF" appears in the display. Finally by pressing the start/pause button the key symbol should disappear - confirming you have successfully exited the child lock program.
Pl click if helped.
Apr 11, 2013 | Bosch Washing Machines
Phone wont ring
Press MENU/SELECT to display menu when in idle mode.
Press up/down to reach Setup HS. Press MENU/SELECT.
Press up/down to reach Rin g volume . Press MENU/SELECT.
Press up/down to scroll through the choices and a sample of each ring
volume will be played. Press MENU/SELECT to confirm.
The screen displays Stored and youll hear a confirmation beep.
If you need a manual, you may download one here.
Feb 17, 2012 | Vtech Cordless 6041 Phone
It wont llet me downlaod yahoo messager
uninstall the previous version through these steps:
XP OS To do so, kindly follow these steps: 1. Click the "Start" menu and select "Run." 2. Type "appwiz.cpl" and press "OK." (This is a shortcut to "Add or Remove Programs.") 3. Select "Yahoo! Messenger" and click "Change/Remove." 4. In the window that opens, click "Finish" to uninstall. 5. Click the "Start" menu and select "Run" again. 6. Type in "%ProgramFiles%\Yahoo!\" and press Enter. 7. Delete the "Messenger" folder.
VISTA OS 1. Click the "Start" menu and select "Run." If you do not see the Run command, then select Start > All Programs > Accessories > Run. 2. Type in "appwiz.cpl" and press Enter. This opens "Programs and Features." 3. Select "Yahoo! Messenger" and click "Uninstall." 4. Click the "Start" menu and select "Run" again. 5. Type in "%ProgramFiles%\Yahoo!\" and press Enter. 6. Delete the "Messenger" folder.
Disable anti-virus and firewall before reinstalling using this link:
http://download.yahoo.com/dl/msgr10/us/ymsgr10us.exe
Oct 09, 2009 | Yahoo Messenger
Wont clean, wont print, says to see user guide, cant find paper jam or foriegn objects, starts to do clean then stops and says unable to clean
Unplug the device from power cord, then press and hold the menu button.Plug back the device.On the LCD you'll see the "machine error" code.If this code is "machine error 40, 41 or 4f" the print head is defective.If the machine error is 46, this is the waste ink tank full.Then follow this procedure:
1. Pres 'menu', 'mono start' then'menu' one by one...
2. Press the arrow up or down to go to'maintenance 80'.
3. Press 'mono start' several times to go to'Purge'. Finding the PURGE will show some numeric value which is Iassume the number of times the printer had cleaned.
4. Press'arrow up' key and scroll for number "2" then press "set".Do the same for numbers 7, 8 and 3. After you have entered thiscombination, the purge numeric value will be reseted to 00000.
Oct 08, 2009 | Brother MFC 210C All-In-One InkJet Printer
My RCA Rear Projection wont change from channel 3.
use the remote that came with it when you bought it and go into channel menu and rescan your tv channels
Feb 17, 2009 | RCA P52937 52" Rear Projection Television
Computer wont load up
If you can open you system than what you have to do is just to unplug the hard disk power cable and data cable and refit is properly and than start your system. This will definately help you unless your system is not effected with virus.
Jan 14, 2009 | Acer Aspireā„¢ T180 PC Desktop
WHEN I CHANGE MY SETTINGS ON MY LE46M87BD IT LASTS ABOUT 30 MINS THEN CHANGES TO DYNAMIC SETTING AGAIN HOW CAN I CHANGE THIS
its in shop settings. press button 1,....menu.......set up...plug and play....then start plug and ply..... will guide u through the rest ...then when you make changes it wont return to dynamic...hope this helps i had the same prob fixed now...
Mar 18, 2008 | Samsung Televison & Video
Toshiba satellite start up
maybe you lost your COMS you should recharg it
Jan 19, 2008 | Computers & Internet
Ink cartrige wont work
press menu then start mono then arrow up button 4 times.
machine will be in mainténance mode. press the arrow up button until 7 is displayed. press menu. press arrow up til 6 then press menu. press arrow up til 3 Dispaly shows powerp_all press start mono. machine runs a power purge. after that press arrorw up til 0 press menu press arrow up til 9 machine will print test sheet. In case you dont have a good result do the power purge again. If you dont get a good result after 3 times purging, the printhead is clogged and cant be fixed anymore!
to leave the maintenance mode press arrow up til 9 then menu then arrow up til 9.
Nov 05, 2007 | Brother DCP-110C All-In-One InkJet Printer
Datalogic MOBILE PEGASO MOBILE COMPUTER 802.11G WLAN BLUE [950201004] PC Notebook Logo
Top Datalogic Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Paul Bade
 Ian Kayhan
Ian Kayhan
Are you a Datalogic Computer and Internet Expert? Answer questions, earn points and help others
