Question about LG BP420 Smart 3D BRay Disc Player
Lg bp 420 picture goes black ok - LG BP420 Smart 3D BRay Disc Player
My LG tv will go on then after a few seconds the screen goes from black back to picture of and on a few times then shuts off. Help!
LG LED TV has no picture (black screen) but still sound ...
www.tomsguide.com/answers/.../led-picture-black-screen-sound-fixed.ht...
7 days ago - My 32' LG LED TV has suddenly lost picture! The sound is all right but theScreen is pitch black. After switching it on the picture flashes for a second and thenthe ... LG LED TV has no picture (black screen) but still sound - can it be fixed? Tags: ... a touch on the screen reveals nothing so it's not the back light.
Monitor going black after 2 seconds [Solved] - CCM.net
ccm.net > Forum > Hardware
Oct 9, 2012 - Brightness goes down, display draws less juice, and you can at least use .... it's the LCD's Inverter ... you have to replace it for it to go back to ... If the screen is turning off every two seconds or so and then it comes ... i turn my tv on it comes right on, but then after a few minutes turns off, .... Digital Trends for LG. No display in monitor
Jan 11, 2013
Ps3 and hdmi cable
Oct 8, 2012
More results from ccm.net
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
Dec 20, 2015 | LG Televison & Video
Lg 26 inch tv flat screen, no picture but sound ok!
The inverter needs replacement. You should be able to get one from www.tvrepairworld.com
Nov 03, 2012 | LG Televison & Video
My LG 37LC2D picture suddenly goes black and then if I bang on the corner of the set sometimes the picture will return. What is wrong with my TV?
could be the power supply card(s) is unseated..open it up if you dare and re-seat and/or maybe remove and clean the card edge connector contacts with an eraser
May 27, 2012 | LG 37LC2D Television
Monochrome pictures on my e-420 when using the M, S, A & P settings.
Set the picture mode to one of the color modes. The MSAP settings allow you to control every aspect of your picture, including whether you get color or b&w pics.
Full details are in the "Picture mode" section on page 63 of the manual.
Mar 20, 2012 | Olympus E-420 Digital Camera
My washing machine model is LG WF-660.. it cannot function due to failure indicator at water level.... it keep on "beeeping" cannot do other operation.... plz help....tq...
pl check the bp sensor or the conector of the wire harness.according to my knowledge there is no door sensor in wf-660.if bp sensor is ok change the P.C.B
Feb 03, 2011 | LG Washing Machines
LG 37LF75 LCD SOUND NO PICTURE SOMETIMES CAN GET INPUT TO COME UP AND GET IT ON HDMI ONCE YOU PRESS OK AFTER 2SECONDS SCREEN GOES BLACK
I have a LG 37LF75 that the picture has stretched hoizontally eg; wording at left or right of the screen is slightly off screen in all ratio settings. How do I adjust the picture horizontally?
Sep 07, 2010 | Televison & Video
Screen blacks out on certain channels randomly..doesn't happen all the time audio still works the picture just goes completely black for a bout a second then reappears.. very annoying.it's new and it also...
Ur LCD inverter backlight board have problems,just not dead yet.When ur LCD inverter backlight board is dead.U will get only sound and no picture at all.
Feb 26, 2010 | LG 55LH90 55 in. LCD HDTV
Pickture is shown 2 sekunds, then it go black. power on LG RD-JT30 and see a pickture thru RGB-signal and after 2 sek the pickture go black
if the lamp is still on and no picture transmits, reset the settings to factory default. the resolution doesn't match or the signal is lost. if the lamp goes out, you may need to replace the lamp. check the lamp for bulges, black spots or fogging. if the lamp is ok, check the colorwheel. if you hear squealing or chirping and it stops when the lamp goes out, replace the colorwheel. if that is ok, replace the ballast.
Dec 03, 2009 | LG RD-JT30 Multimedia Projector
Bl;ackplanet
This is an issue with Black Planet's server. You'll need to contact Black Planet for support on this issue.
Jul 07, 2008 | Toshiba Satellite P205-S6287 Notebook PC
LG BP420 Smart 3D BRay Disc Player Logo
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
