Question about Electronics - Others
Stinger bug zapper
The red light is on but the bulb and zapper not working
  • 19 Answers
SOURCE: Rechargable Stinger new bulb is dim orange
Could possibly be a bad switch, I would also get that battery tested out also. If you still have a receipt it should be covered under warranty. If not try sending it in anyway. Limited lifetime warranty does not include bulb, or batteries but, anything else on that Stinger should have a lifetime warranty. Of course that excludes abuse. Check out the website www.streamlight.com and go to FAQ for a nearest Authorized Service Center or send it directly to Streamlight. Address also listed on the website. Hope that helps ;)
Posted on Aug 28, 2009
  • 8404 Answers
SOURCE: microwave doesn't heat
check your door safety interlock switches ...
switch burned = no circuit
no circuit = door open (as far as the oven is concerned)
door open = no magnatron action
no magnatron action = no heat
Of course it could be something else ... but if it is the switch, you can easy fix that.
Posted on Oct 09, 2009
hardrocko
  • 1476 Answers
SOURCE: I have a JVC HD-55g456aa rear projection tv and
You have a high voltage leak somewhere. Probably the flyback but it could also be the HV divider block. Remove the back and while staying a safe distance from the unit turn it on and see where the arcing is happening. It could also be on the main circuit board in the area of the flyback. Odds are the flyback is cracked and needs replaced. This is not too difficult for most people to do.
I have a tip at http://www.fixya.com/support/r4916851-diagnosing_repair_tv_high_voltage which is written for a set which is dead (usually the case) but it explains how to identify the parts you need to change, how to replace the parts and where to get the parts at the best price. Let me know if you need more help.
Thanks for using FixYa and for the generous rating.
hardrocko
Posted on Jul 10, 2010
  • 1891 Answers
SOURCE: I heard some clicking noises
yes . it sounds like the main board . the clicking would be the relay that starts compressor ... change the main board .. mm feed back pls . with a model # i can give you part # & price .
Posted on Oct 22, 2010
SOURCE: is there a repair for stinger uv40, lights up but does not kill
please don't open it until you find the best to solve it! good luck!
Posted on Oct 17, 2012
Should my 1.5 acre stinger bug zapper zap when I plug it up
Intuitively, I glean it zaps when you turn it on only if you are a bug. Zapping is caused by the bug encountering the zapper. Otherwise, it would zap you even if you were not a big bug, simply because you were in close proximity.
Aug 20, 2017 | Air Purifiers
I have a flowtron bk-2125 bug zapper, looking at the troubleshooting, it said check for power on the grid, how do i do that. I changed bulb and it is not coming on, it said if i have power then the starter...
If you have no power from the grid then bug zapper is not problem. If bug zapper is a corded plug in application then unplug and plug into a plug in that you know works. Check your breaker panel for a tripped breaker and reset if necessary. Or try a different appliance by plugging something that you know is operational into the same plug. If it works, there is likely an internal problem in bug zapper.
Oct 08, 2014 | Cars & Trucks
How do I install two C batteries correctly into my Stinger hand held bug zapper ?
The flat end of the battery (with out the nipple) normally goes to the spring in any battery holder. There is normally a picture of the battery orientation in the plastic molding of the battery space (sometimes hard to see)
Sep 03, 2014 | Cars & Trucks
When installing the two required C batteries into my new Stinger bug zapper. In what manner should the batteries be inserted into the battery compartment ?
Not sure which model of Stinger bug zapper you have. If you are using C batteries then it could be a portable racket zapper.
Please check model number and compare with list of manuals on this site.
Owner Manuals StingerProducts com
If there are only two batteries then there are 4 ways in which these can go. You could try and see which one works.
Sep 03, 2014 | Camping, Backpacking & Hiking
How to replace battery
It should say on the back where the battery compartment is which way negatives and positives should go, but the one with the spring is negative :)
Hope this helped!
Sep 03, 2014 | Kaz Inc Stinger Flat Panel Bug Zapper
How to repair
Is the buglight still working? I simply take a blade of grass and place in between the wire cages to make electrical connection and verify transducer is not defective. If you don't get a spark quickly your transducer may be burned out as I cannot keep one working due to larger insect getting in unit and overloading the transducer.
May 22, 2014 | Stinger 1 Acre Bug Zapper
Can not find xfmr 400 32 nb transformer
Sears sells them, $40+. They gotta be making a killing.
Apr 16, 2013 | Honeywell Uvb45 Stinger Ultra Bug Zapper
Light wont come on. Purifier wont work
When the high voltage transformer is working right, it will make the neon bulb glow.
You probably have a burned out high voltage transformer. That's what produces the ozone. Helpful hint...........the high voltage transformer is also the one used in bug zappers
Mar 14, 2010 | Ecoquest Flair Air Purifier
I have a large bugzapper by Stinger. I plugged it
How is the voltage to the zapper, is the circuit ok? Check it on another plug...
Aug 06, 2009 | Electronics - Others
Electronics - Others Logo
82 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
