Question about Intertherm Heating & Cooling
Model # E3Eb - 012H. Unit will not run. Have checked all the breaker and even installed a new thermostat. Still nothing.
  • Don Shamburger Aug 02, 2013
    Thanks for all the input. The installer put a in-line fuse in on the blowerer side of the unit. No where was it listed on the digram, hence cost 3 hours of the tecks time, but only charged me for the house call.
    Great guys
the dr
  • 447 Answers
SOURCE: problem running heater
Its not good that you dont know where the air filter is. Odds are there may not even be one in place. In Most mobile homes they dont pay much mind to proper filtration. The heat strips are covered with dust. If the heat Strips are that bad then usually the whole unit is clogged. Is there a unit inside the mobile home?? Or is the unit outside quite large and have ducts running to it??
Posted on Nov 24, 2007
22yooper
  • 828 Answers
SOURCE: Goodman CK60-1C model central AC unit blwing hot air
Clicking sound is the contactor engaging to start the outside unit. Check for a burnt off wire at the contactor. For some reason you are not getting power to the outside unit. If you find a burnt off wire shut off all power to it then remake the connection at the point of the circuit break.
Posted on Jun 27, 2008
  • 19 Answers
SOURCE: Goodman CK30-1A Central AC Unit will not run by thermostat
double check your t-stat wiring your not getting 24volts to the contact at the cond. unit outside
Posted on Jun 21, 2009
co7196
  • 3433 Answers
SOURCE: Goodman Air (outside unit)
was there any refrigerant loss? "bumping" that results in movng usualy causes a leak.If the system is totally empty, It shouldn't start.. If it did major oh nos! will appear. Does it not start all? and was it running when it got thumped? May have to call a tech out on it. Sorry.
Posted on Jul 29, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: Blower keeps running even after thermostat is in
This could be an indication that there is an error code flashing on the control board and needs to be addressed. Most newer units like this indicate a problem by running the room air blower to alert the homeowner something is wrong. Really! Without shutting off the power to the unit, look for a small viewing port that looks into the cabinet. You should see a blinking light that will blink a number of times, pause then blink another number of times. Once you get this number, say 3-4, look at the wiring diagram pasted on one of the door panels for a diagnostic chart. It will give you a starting point where to look for the problem. If you have one. Or you could have a bad control board or shorted wire. Make sure the air filter is clean since you will be in front of the unit, you would not believe how many times I have to charge $100 to replace a filter the home owner could have done for less than $20.
Posted on Mar 11, 2010
Need a wiring diagram for a EEH-012H intertherm
Request the wiring diagram from Hunter and, if need be, Intertherm.
Feb 12, 2018 | Hunter Heating & Cooling
I am replacing the thermostat with the Ecobee3 lite smart thermostat. The thermostat did not power up. My A/C unit is a Carrier model 40AQ030300BB. Might I have popped a fuse or something?
yes you likely blew the fuse. it is likely a blade style/ similar to one in a car, located on a circuit board inside the blower compartment. BE SURE TO TURN POWER OFF AND LOCATE AND REPLACE WITH SAME THING!!
Nov 11, 2017 | Carrier Heating & Cooling
My intertherm e3eb-015h electric furnace will not do a thing even temp.on thermostatdont show up breakers are on still nothing
Check to see if the fuse is blown. If it apprears to be blown, replace it. It is inexpeisive and simple. If you locate the fuse, you will be abel to determin if it is blowin becuase you will be erruption or a burnt mark in the fuse wires.
Sep 21, 2014 | Heating & Cooling
Home a/c intermittent during rain
You need to check the contactor. It sounds like the contacts may be getting close to the end of their usefulness and they are welding themselves closed. Check that and let me know what you find.
Jul 29, 2010 | Heating & Cooling
I have an goodman model gsc130241ae unit will not
Hello Does the thermostat have a display?Check emergency wall switch and curcit breaker all on.Fan on should at least run if power.
Mar 31, 2010 | Goodman CLQ36AR49 Air Conditioner
Problem running heater
Nov 24, 2007 | Heating & Cooling
Heating & Cooling Logo
46 people viewed this question
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Dan Webster
Dan Webster
Bill Long
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
