Question about JVC RX-6018V Receiver
Get rear speakers to work with front speakers
Hi i have a 95 buick lesabre i bought from a friend everything works great sides the radio i have an after market stereo jvc model no kd-g320 not sure witch color the antenna wire would be car has a power...
Antennae wire and other wires for the stock stereo are listed below:
1995 Buick LeSabre Stock Radio Wiring Diagram
Car Radio Constant 12V+ Wire: Orange
Car Radio Ignition Switched 12V+ Wire: Yellow
Car Radio Ground Wire: Black/White
Stereo Radio Illumination Wire: Gray/Black
Stereo Radio Dimmer Wire: Brown/White
Stereo Radio Antenna Trigger Wire: Dark Green
Stereo Radio Amplifier Trigger Wire: N/A
Front Speakers Size: 5 1/4? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Front Speakers Location: Doors
Left Front Speaker Wire (+): Tan
Left Front Speaker Wire (-): Gray
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Dark Green
Rear Speakers Size: 6? x 9? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Brown
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Dark Blue
Right Rear Speaker Wire (-): Light Blue
Feb 19, 2015 | 1995 Buick LeSabre
Need to wirer kenwood kdc-hd545u radio to my 1999toyato avalo and the wirer harness has been cut off the toyato need wirer diagram to match wirer colorsto make it work!!
1999 Toyota Corolla Car Radio Stereo Audio Wiring Diagram
Car Radio Constant 12v+ Wire: Blue/Yellow
Car Radio Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Violet
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Blue
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
Oct 14, 2012 | 1995 Toyota Corolla
2002 4x4 tacoma replaced radio now door chime and stereo doesnt work
2002 Toyota Tacoma Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Blue/Yellow
Car Radio Accessory Switched 12v+ Wire: Gray
Car Stereo Antenna Trigger Wire: N/A
Car Audio Front Speakers Size: 6 1/2′
Car Audio Front Speakers Location: Doors
Left Front Speaker Negative Wire (-): Purple
Right Front Speaker Positive Wire (+): Green
Car Audio Rear Speakers Size: 6 1/2′
Car Audio Rear Speakers Location: Rear Corners
Recheck your wire connections, good luck.
Thank you for using Fixya
Mar 19, 2010 | 2002 Toyota Tacoma
Car front two speakers arent working. rear two are.
have the front speakers ever worked?
if not have they been connected properly?
if yes then
look under ballance and check theat rear and front ballance is in the middle
if it is then for temporarily replace the front speaker with any old speaker
if that works then you need new front speakers
if no then the radio is broken
but what you could do is rewire the back speakers so they also play though the front ones too
this can be done from behind the radio
find the rear right positive and negative wires
strip the insulation but dont cut the copper wire
cut the front right speaker and attach that to the rear speaker wire
do this for both positive and negative
rear right
positive
..v
..v
I...I
I...I
I...I
.I.I..........< strip cable but do not cut metal
.I.I..______________
.I.I=_______________ <<<front right positive
.I.I
I...I
I...I
I...I
I...I
Jan 06, 2010 | Sony Xplod Car Audio CDX-F7810 - CD/MP3...
Need wiring diagram for a 2002 mustang Mach 1 radio. radio is hooked up and working but not the bottom door speakers . need to know what color the bottom door speakers are left and right and + & -
2002 Ford Mustang Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Purple/Light Blue
Radio Switched 12V+ Wire: Black/Pink
Radio Ground Wire: Black/Light Green, Black
Radio Illumination Dimmer Wire: Light Blue/Red
Radio Antenna Trigger Wire: Orange/Light Blue
Left Front Speaker Wire (+): Orange/Light Green
Left Front Speaker Wire (-): Light Blue/White
Right Front Speaker Wire (+): White/Light Green
Right Front Speaker Wire (-): Green/Orange
Left Rear Speaker Wire (+): Gray/Light Blue
Left Rear Speaker Wire (-): Tan/Yellow
Right Rear Speaker Wire (+): Orange/Red
Right Rear Speaker Wire (-): Brown/Pink
Nov 25, 2009 | 2002 Ford Mustang
I am putting in a cd player and i don't understand why it won't get power. i hooked it up staight to battery and it works just don't know which wire is power from the fuse block
1995 Jeep Grand Cherokee Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Red/White
Radio Switched 12V+ Wire: Red/Gray
Radio Illumination Wire: Blue/Red
Radio Dimmer Wire: Orange
Radio Power Antenna Trigger Wire: Green/Red
Radio Amplifier Turn On Trigger Wire: N/A
Left Front Speaker Wire (+): Green
Left Front Speaker Wire (-): Brown/Red
Right Front Speaker Wire (+): Purple/Yellow
Right Front Speaker Wire (-): Blue
Rear Speakers Location: Rear Doors
Left Rear Speaker Wire (+): Brown/Yellow
Left Rear Speaker Wire (-): Brown/Light Blue
Right Rear Speaker Wire (+): Blue/White
Right Rear Speaker Wire (-): Blue/Pink
Oct 01, 2009 | 1995 Jeep Cherokee
Windows 7 Audio Quadraphonic Not functioning well
Sounds like you are getting quad sound in the test process that checks them, yet when in windows media player or winamp (or whatever) your rear speakers aren't producing sound: Try setting your sound drivers to do something like "speaker fill" then you are set. I'm under the belief that stereo sounds aren't being matrixed into all 4 speakers.
Mar 25, 2009 | Computers & Internet
Need diagram for wiring radio for 1997 Hyundai Sonata
1997 Hyundai Sonata Car Stereo Radio Wiring Diagram
Car Radio Constant 12V+ Wire: Red
Car Radio Switched 12V+ Wire: White/Green
Car Radio Illumination Wire: N/A
Front Speakers Size: 4′
Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Brown/White
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): Brown/Yellow
Right Front Speaker Negative Wire (-): Black/Yellow
Rear Speakers Location: Door
Left Rear Speaker Positive Wire (+): Brown/Red
Left Rear Speaker Negative Wire (-): Black/Red
Right Rear Speaker Positive Wire (+): Brown/White
Right Rear Speaker Negative Wire (-): Black/Whi
Mar 20, 2009 | 1997 Hyundai Sonata
JVC RX-6018V Receiver Logo
24 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
