Panasonic vhs super drive Ai NV-SD400 show view
Loaded tapes just jam in situ. Apparently I need a new/replacement loading mechanism. Any suggestions on where I can source that from, or is it just cheaper to buy a new machine? Thanks.
  • Televison & ... Master
  • 5,113 Answers
Curry's Partmaster has a good range of parts for this machine. They don't look to expensive, so try them.
Posted on Aug 07, 2013
  • 579 Answers
SOURCE: RCA VR688HF VHS VCR won't accept tapes
The brain in a VCR has a little switch assembly that senses what position all the mechanical stuff its in. Apparently, the mech is out of whack which is why it won't let you play. This is a common problem and any VCR shop should be able to repair it.
Posted on Dec 28, 2007
SOURCE: panasonic VCR VIDEO PLAYER
Hi, the problem may be typical for this VCR , you must to change 2 mechanical parts, one is the plug on the loading motor , the other is a rod, but you must to have experience in VCR repairs, becouse of that the best solution is to find a Panasonic service center
Posted on Jun 04, 2008
  • 4234 Answers
SOURCE: Part for VCR mechanism
I'm not sure what part you ned, but parts are still available from generic suppliers although not from Mitsubishi. Where are you located?
Dan
Posted on Oct 01, 2008
Grubhead
  • 5113 Answers
SOURCE: How to time loading arm cogs on VCR?
Most Panasonic VCR use a mechanisms with a letter. For example the NV-HS900 uses a K Deck. What you need to do is type the model number into google and search for which deck it uses. Then with luck you might also find the instructions for setting the deck up correctly. I got the K-Deck one free.
Posted on Jan 28, 2009
sodeep
  • 3267 Answers
SOURCE: VCR won't eject tape - timing of loading mechanism is off
Now-a-days most of the gears are made out of plastic(HDPE, if I remember correctly), when the rewinding command is given even if one gear tooth is worn/broken it will throw the entire timing out of 'gear'. Since the problem has already occurred, and, this is the only function that has malfunctioned my advice would be to leave it as it is! ('cos repairing/replacing it is manual & therefore a costly affair plus there is no guarantee that the replacedment will function properly)....sodeep
Posted on May 09, 2009
Panasonic NV HV 62
I think that code might mean that the mechanism is getting stuck as it tries to unload the tape. Look around for signs of damage and examine the Loading Motor.
May 31, 2014 | Panasonic Nv-Hv62 NV-Hv62gcuj
Panasonic NV-Fj620 What's youThe turns it self off a few seconds after being swithched on. Display shows F 04. Please advise what the fault is.r problem?
This deck uses the K-Mechanism. Which you can find information by searching the web for it. F04 means the mechaism is locking up whilst it's unloading. The solution is to look at the Load Motor and the timing of the drive to it.
Dec 15, 2011 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
I have a nv-gs40 which was laid up for a while o.k now tape will not load and shows TO SERVICE in view finder.
-try a power cycle
*remove battery and disconnect from power cord
*i would also suggest to check the tapes if they're clean
*try to clean the tape head inside the tape deck(tape head: the one that reads the tape)
-try using a soft and dry Q-tip to clean the metal parts inside the tape deck(dont use or apply any liquid solutions. just a plain soft dry Q-tip.
Jun 05, 2011 | Panasonic NV-GS40 Mini DV Digital...
My family videos are stored on the mini VHS tapes. I recently bought a VCR to dvd recorder to transfer them into dvds but now I discover my VHS playpak (that you need to play the mini tapes) is broken....
Maplin Electronics have a motorised VHS-C Cassette adaptor that will enable you to view any camcorder tape on a standard VHS. If that is any help priced around £15.00.
Mar 14, 2011 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
I have a panasonic nv-hd640 i can't eject tape, when i try to eject give me a error f06 and turn off the video thank you
You have a K-Deck model there's lots of information on the net about these so check it out.
Meanwhile F06 means that the mechanism is locking up (getting stuck) after unloading the tape. The cause of which is either something to do with the loading motor or the carriage (where the tape fits) alignment.
Just type "Panasonic K-Deck Mechansim" into Google for the information.
Jan 16, 2011 | Panasonic NV-HD670BDX VHS VCR
Panasonic NV HD630 is showing error f06 when the eject button is pressed. The tape cassette seems to be locked in and does not rise. I have removed the top. The tape is withdrawn back to the cassette....
You have a K-Deck mechanism. F06 means the mechanism locks after unload. The cause of this is the load motor or the carriage alignment.
If you enter "Panasonic K-Deck" into google you should find service information and a guide to getting the tape out - all free!
Oct 13, 2010 | Panasonic NV-HD680 VCR
Jan 03, 2009 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
VC recorder keeps on driving
I beleave your sensor that tells the player weather a tape is in there or not needs replaced ~ It sounds like it doesent know the tape is not there aand will not shut down! (replace tape sensor)
Please rate my answer and help keep this site free!
Dec 31, 2008 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Panasonic video recorder malfunction
It sounds like you need a service manual - it tells you how to remove stuck tapes etc.If you need a service manual for this model, which is helpful for checking things/disasembly/assembly, you can obtain a free one from:-
http://www.reptips.dk/Reptips/NV-FJ620.pdf
Error F04 message displayed
Panasonic K deck F03 or F04 shows in display check loading motor coupling pt no VDP1434 or motor pt no VID12128 £11.95 CHS
Nov 22, 2006 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Televison & Video Logo
82 people viewed this question
Top Televison & Video Experts
Electro Med Services...
