Question about Samsung 55" UA55C7000 MULTISYSTEM LED 3D TV FOR 110-220 VOLTS 2 pairs of glasses and a movie
Need a new power lead for samsung Uac55c7000 where can i buy one need to get it posted to the UK
I am looking for power lead for elctric wow
If you get one for your WOK it will be compatible but is the WOK 220 volt or the north American 110 volt system??
Sep 21, 2014 | Rival Kitchen Appliances - Others
Samsung C3050 HOW DO I LOAD PICTURES ONTO SD CARD
You will need a USB/Data cable to connect the phone to your computer, if you don't have one they can be bought from here http://cgi.ebay.co.uk/New-Genuine-Samsung-C3050-USB-Data-Cable-Sync-Lead-/260509082004?pt=UK_MobilePhones_MobilePhoneAccesories_MobilePhoneDataCables_JN&hash=item3ca78d2194
Then go here for the samsung pc studio programme that will assist you in putting pictures on your SD Card
Feb 17, 2011 | Samsung C3050 Cell Phone
Where can I purchase a power cord for a Hitachi CP-X327T LCD Projector?
You should be able to buy one from stores such as Maplin, Radio Shack or any other electrical/electronics retailer.
It's known as an IEC lead.
Online options may be www.leadsdirect.co.uk/productinfo/mainsleads.html (UK) and
www.comms-express.com/categories/iec-power-leads/ (USA)
Feb 15, 2011 | Hitachi CPX1350 LCD Projector
When i connect it dont show it and it keeps saying about the usbnot being a 2.0
Ok you need a usb lead that has two inputs, your laptop/pc clearly only has usb standard 1.0 which doesnt give as much power out, so you need the lead with two ports on it and it will use one for power one for data.
I've linked a pic of one below in case you already have this lead or if you need to buy it. I certainly wouldnt pay £8.20 though! If it comes to it we can post you one for a lot less than that!
http://www.amazon.co.uk/LINDY-USB-Cable-Dual-Power/dp/B000FKP7XA
Oct 31, 2010 | Seagate FreeAgent Go 120 GB USB 2.0 Hard...
Hi, my friend has thrown out her power lead for a samsung 233hd. Does anyone know what she needs to replace it? Is it just a power lead or does it have an external power supply? Thanks.
Samsung tv power a/c cord,just a generic power a/c cord.Tries websites like Partstore.com,Ebay.com,Amazon.com to buy a new a/c power cord for the tv.
Oct 23, 2010 | Televison & Video
When I bought my Genio touch (SAMSUNG S3650) I was not given a USB lead with it, or a CD. I bought a USB lead for my SAMSUNG phone online and the first time I tried to use it, noting came up. So, i...
Hi you will be able to get all you need from the samsung site you will be able to download everything from their
once you have downloaded the software your computer will recognise the phone and allow you to transfer data between the two
CLICK HERE
the link here is for the UK site as i am in uk not sure where you are so you would need to search for the samsung site in your country
how ever if you type into your search browser the following Samsung S3650 software
then hit search this will then bring you up several sites that you can download the software from just stick to the samsung sites and you will have no problems using the software.
let me know if you need further assistance ok
plz rate this solution as i have a whole page on unrated posts, thanks
Aug 30, 2010 | Samsung S3650 Corby / S3650 Genio Touch...
Samsung LN26A450 LN26A450C1DXZA won't turn on
I had the same problem with my Samsung LN26A450 LCD TV. I found the following YouTube video http://www.youtube.com/watch?v=Mm51C_RDIZE titled "Samsung TV Repair - Part 1 of 2) (also watch Part 2 of 2) which shows how to easily fix the problem. The problem is bad capacitors on the power supply board. My TV had seven (7) bad capacitors - all 7 had dark stains on the ends from leaking electrolytic fluid and one (10V 2200MFD) was blown with bulging ends. I ordered 7 new high-temp (105 degrees C) aluminum radial capacitors from DigiKey.com matching the Temperature, Capacitances and Voltage Ratings for each damaged capacitor that I removed. I followed the instructions in the video except I used desoldering braid ($3.99 at RadioShack) to remove the solder attaching the bad capacitor leads to the power supply board. Once you wick up the old solder from all sides of each lead wire using the desoldering braid, the bad capacitors are easily removed. Total cost of repair including soldering equipment was less than $50. Thanks to “The Professor” for posting the video and saving me $400.
Sep 24, 2009 | Samsung LN26A450C LCD TV
Dell latitude d600 purchased in USA WHAT do i need to make it work in UK POWER PLUG NOT AS IN UK thank you
if its a round 3 pin and it plugs into a power unit 3 spade type plug end, using a plug like the one that goes into an electic kettle, just buy a kettle lead and use that.
If the power unit itself is not 240 volt you can buy a universal charger/power unit from maplins or similair, but check the wattage
http://www.maplin.co.uk/Search.aspx?criteria=laptop%20power&source=15&SD=Y
Aug 23, 2008 | Computers & Internet
Samsung V25 notebook Tft failure
We got your messsage and we're looking.
Jul 01, 2007 | Samsung V25 XVC 2800 Notebook
Samsung 55" UA55C7000 MULTISYSTEM LED 3D TV FOR 110-220 VOLTS 2 pairs of glasses and a movie Logo
21 people viewed this question
Jerry Greenberg
Jerry Greenberg
