Question about Microwave Ovens
Carlton ec1000 what does mode button do?
Manual for Carlton C179SS09
Go to manufacturer web site for download.
Sep 19, 2015 | Carlton Microwave Ovens
Instruction manual for carlton microwave C21CS09
Currys PC WorldHi Simon,
Thank you for getting in touch.
It's great to hear that you're satisfied with your microwave! My apologies - after searching (and believe me I searched everywhere) I have been unable to locate a manual for the Carlton C21CS09.
You have my apologies for the inconvenience caused.
Kind regards,
Matt
Apr 01, 2012 | Carlton Microwave Ovens
Carlton Microwave - C25MW09. Microwave unit stays on after timer has finished although light goes off and turntable stops rotating. Have to turn it on and off at the mains otherwise microwave unit would...
It is possible that the relay is staying latched to supply voltage to the magnetron even after the timer shuts down. This is dangerous and must be rectified.
You need to check the door switch and the lines from the program timer to switch the relay of the magnetron. It is possible that the timer is faulty and needs a check on the reason why it stays latched unless the power is cut. You can disconnect the magnetron to test but attempt ONLY if you are familiar with high voltage/ electrical circuits.
Jul 09, 2011 | Microwave Ovens
I have a second hand Carlton microwave model no C25MW09 without an instruction manual. Can you help?
Most major manufacturers supply manuals online so if you were to log on to the manufacturer's web site, you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, Dealer Network for spare part supplies and as required.
The information is normally free of charge.
Mar 01, 2011 | Microwave Ovens
Need a manual for a Carlton Microwave / Oven / Grill combination, model number C21CS09
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers for spare part supplies as required.
I hope this helps.
Jan 13, 2011 | Microwave Ovens
Where can I go to get a user manual for Carlton C17GSS09 microwave
Is thisa the 39 Pound special?
Try Curries in the UK they are cheap units made for sales as specials.
Beware tho if they break down tjhey are considered throw away.
Capacity - 17 litres, Microwave wattage - 700W, Grill wattage - 1000W, External dimensions WDH(mm) - 440x318x252, Stainless steel door with silver casing, Power levels - 5, Auto programmes - Defrost/cook, 8 auto cook programmes
The cheapest price Currys for CARLTON C17GSS09 is £39.00. For more information on CARLTON C17GSS09 please visit their online store.
CARLTON C17GSS09 is available from as little as £39.00.
Please rate my help++++Thanks for using FIXYA
May 19, 2010 | Microwave Ovens
Timer runs extra fast and microwave does not heat
I had this same problem with my Maytag Microwave. Unplug the unit and plug it back in. It fixed my issue.
Sep 04, 2009 | Maytag Microwave Ovens
Micro wave cuts out after 20ish seconds
Try this...
Press: Function 0 2 to turn off demo mode. For future reference, Function 0 1 should turn demo mode back on.
Feb 01, 2009 | Panasonic Microwave Ovens
How do I take it off demo
timer button 4 time on demo mode
time button 4 taps more off demo mode
see page 11 of your manual
please rate me for this
Jun 23, 2008 | Panasonic NN-SD997S Microwave Oven
Microwave Ovens Logo
16 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
