Question about Toto Home
Toilet has dripping sound - NOT the flapper
I have tried two seperate flappers and dripping sound still continues. Can even hear the dripping in the basement directly under the drain but no water anywhere. Is there anything else it could be dripping other than the flapper? Also, water isnt over the fill tube, so its not that.
    Problem Solver:
  • 20 Answers
As long as the chain on the flapper is slack after it flushes it will seal.
then put some weight on the flapper just to experiment to ensure a tight seal.
if you can see the drain elbow under the toilet in the basement with the ceiling exposing the drain that would be the guaranteed way to know for sure. I am assuming you have done that.
Last but not least the small line on the fill valve that goes into the overflow could be weeping from the fill valve as this is the bowl wash.. So it will drip or sometimes it runs a bit . If this helps
Posted on Aug 04, 2013
picatudo
  • 239 Answers
SOURCE: toilet not flushing properly
there are allot holes around rime inside they get clogged over time because water quality very hard to get there to clean best bet replace toilet
Posted on Jan 04, 2009
  • 5 Answers
SOURCE: My toilet is leaking around the flapper. It does
remove old flapper, go to local hardware store and get a replacement for about $4.
do not forget to turn water off and flush it to clear the tank first. clean the fapper seat too.
Posted on Mar 14, 2009
SOURCE: Water continues to drip from fill tube after the fill.
I had same issue but with different solution... I noticed that the rubber fill tube was rubbing against the inside of the flapper assembly just enough to prevent flapper from fully sealing after flushing. I routed the rubber fill tube so that it doesn't touch or impede the flapper valve.
Posted on May 20, 2009
phmaddnes
  • 24 Answers
SOURCE: Running toilet
Mine does that also, here's what I found.; I am on a well and occasionaly sand gets caught in the valve thingy... Take the tank lid off, turn the arm that attaches to the float assy. 1/4 turn towards the back of the tank and take it out. Rinse off the gasket and pin as well as inside the hole. Reassemble and it should solve your problem.
Posted on Jul 04, 2009
  • 10 Answers
SOURCE: Replaced toilet fill valve - now bowl water level a bit lower
put some water in with a bucket. poor some in slowly until you get it where you think it should have been. If it levels back out at the lower level. Then there is nothing wrong. Maybe the leaking water was keeping the bowl water line high than it should have been.
Posted on Jul 26, 2009
Water Ridge dual flush toilet issue!!
Of course ALL the DIY centers (Lowes, Home Depot, Ace Hardware, Do-It-Best, etc.) sell toilet repair kits. Sounds like you need a flapper replaced in your toilet. Search online for toilet flapper replacement to get guide on DIY.
Nov 10, 2014 | Home
I purchased a Fresca FTL2336 Apus One-Piece toilet and installed it. I can hear a constant drip of water escaping from the tank causing the toilet to refill every few hours. I have lifted the flapper,...
The flapper may be defective or not seating completely which causes a continuing slow leak until the tank level drops low enough to cause the flush valve to refill it. I find a cheap flapper lasts just as long as more expensive ones and lasts about as long. Arbitrary replacement of the flapper is a regular periodic maintenance item
Feb 16, 2013 | Fresca FTL2336 Apus One-Piece Square...
How to fix a dripping toilet
if the fluidmaster,itself is leaking, there is a rubber disk in the base of fluidmaster, replace disk. however, i can almost promise you the dripping you hear is from a bad flapper. replace with KORKY brand flapper. buy the basic black one, with no water saving gadgets on it.you will see cheaper black ones, but get the KORKY
Dec 20, 2012 | Fluidmaster S2DBL Dual Flush Toil System
The water in the tank continues to leak out and the tank has to continue to refill. I have replaced the flapper, I have taken the tank off the toilet and check gasket alignment. The tank does not leak...
There are only a coulple of places that the toilet could leak or, overflow and give you this problem. When you replaced the flapper valve, did it have an extra piece of rugger on it? Universal flappers have a round piece on them that are designed to fit over the overflow tube. If you flapper had this piece and you don't have need for it, you need to cut that out, if the flapper "hooks" to the overflow assembly. Leaving that piec on can contort the shape of the flapper and make it so it won't seal. If you are noticing constant movement(slight swirl) in the bowl, make sure the back tank is not constantly overflowing into overflow tube. If this is the case, your water level is too high. You will either need to adjust the water level and/or replace the fill valve. If you can hear the toilet running or leaking, push down on the flapper, if it stops, you have a problem with the flapper and/or the chain adjustment. When you install the flapper, you have ton make sure the chain is long enough to let the flapper fall and seal but, not so long that it can tangle or get between the the flapper and it's seal below it.
Jun 19, 2011 | Jacuzzi Home
Slow leak water drip into the toilet bowl. How to fix it?
Lift the tank lid and you will see a rubber flapper that controls the flush down to the bowl.(connected to the chain, controlled by the hand lever) That flapper starts to deteriorate from hard water over time and starts to lose its ability to seal. Turn the water supply valve off and take your flapper to the nearest store and find one that fits your model. They are generally about 4-7 dollars. Even though they sell universal flappers, trust me and just take your old one to the store because you never know. Hope this helped!
Dec 06, 2010 | Home
Water continue to drip just a little after fill valve stops
Check the little tube the goes from the fill valve into the overflow tube. You NEED to have a good arch in the tube to prevent back siphon from the tank. If that doesn't work then check to make sure the flush valve flapper is completely seated without any of its port showing. If you see the slightest amount of the flush port then you need to replace the flapper. AS well as make sure none of the chain is getting siphoned into the port preventing the flush valve flapper from completely seating.
Mar 20, 2010 | Toto Toilets ST784S 12 Sedona Beige...
Shortly after toilet flushes, you hear a tinkling sound for several seconds, as if water dripping inside. Sometimes also hear another sound like flushing even though toilet is done running,
Check the water level inside the tank to be sure the tank isn't overfilling and spilling into the overflow tube.
Also check the flapper valve (the rubber valve at the bottom of the tank that sits over the flush hole and is connected to the flush handle) to be sure it is holding and not leaking.
Make sure the handle chain that goes to the flapper valve isn't tangled up and holding the flapper valve partially open.
Dec 12, 2009 | Office Equipment & Supplies
I have the bellevue model and it keeps running even when the toilet has been flushed. It continuely seems to need more water and leaks a bit of water all of the time. It is a new toilet!
Your flapper is not sealing at the bottom of the tank. You can either return the toilet, replace the flapper, or try smearing a little vaseline on the underside of the flapper lip where it contacts the tank bottom. The latter may be all it needs to seal a tiny leak.
Dec 03, 2009 | Villeroy & Boch 98M2 S1 01 Bellevue Toilet...
My one piece elongated bowl toilets are filling for no apparent reason between flushes what can I do to fix the problem
it sounds like your flapper (flush valve) is leaking.
if you here your toilet filling up and no one flushed.
push down on flapper to see if you here the water stop leaking out. if so replace flapper. even if toilet is 1yr or less old. could be a bad flapper. hope this helps. duane :)
Oct 11, 2009 | American Standard 2002.014 - Champion4...
Chances are the flapper is leaking. Thats causing the random refilling as the tank slowly loses water into the bowl.
Replace the flapper with only the best available at your supply house. the cheap ones tend to leak even when new. The good ones are less than 8 bucks most places.
If your fill valve has the float ball, there should be a screw right on top of the fill valve at the end of the rod holding the ball to adjust the water level.
Closckwise lowers the level.
Be carefull not to break the plastic ones. If the adjustment is all the way in or does not work, you will need to replace the fill valve.
You could also try bending the metal rod holding the ball, but only as a last resort.
Nov 25, 2008 | Home
Home Logo
189 people viewed this question
Top Toto Home Experts
Donni Steen
john h
Mike
Are you a Toto Home Expert? Answer questions, earn points and help others
