I have a vintage magnavox 750 receiver only the aux hook ups work and their is a problem somewere in the bass control
2 Suggested Answers
SOURCE: Hi, Experts, Vintage Sansui 5050 receiver.
Check for 19 Kz on stero decoder that requires calibration adjustment.
Instrument you need:
Occiloscope or frequezy counter and adj driver .
Good lock.
Posted on Jul 28, 2009
What does "amp error" mean?
If your sub is connected to a separate amplifier, the internal amplifiers of the receiver would be at fault.
Aug 06, 2016 | Pioneer DEH150MP CD/MP3 Car Stereo Radio...
How to fix a Magnavox record player.
It might just need a new belt or a few drops of oil on the motor bearing.
You will have to open it up and check whether the belt has perished, or stretched.
Aug 05, 2014 | Magnavox Vintage 1v9080 Stereo 8 Eight...
Insignia stereo reciever inputs stopped working
check a button on the front labeled 'straight' or 'direct'
Nov 02, 2009 | Insignia 200W Stereo Receiver
I cant figure out how to get my playstations 3's audio to play through my koss surround sound
Hook your video source up to the display (TV), and run your audio cables to an input on your surround sound receiver. Note which input the audio cables are hooked up to and set the surround sound receiver to that channel on the front of the receiver. For example, if you hook up the audio inputs to "AUX" in, then make sure you select "AUX" on the front of the receiver. If you hook up the audio input to "DVD" on rear of receiver, make sure you select "DVD" on the front of the receiver. The connections on the rear of the receiver have to match the selection on the front of the receiver. Make sure that the cables are hooked up to "INPUT" on the surround sound receiver. It doesn't matter how the inputs are labeled (DVD, AUX, etc.) they all do the same thing. Check volume and mute controls on receiver as well. I know it sounds trivial, but sometimes it's the little things that get overlooked and cause problems. I hope this helps and good luck.
Oct 28, 2009 | Audio Players & Recorders
Kdc mp335 aux in doesnt work
if you go to standby with your source button and then hold in your bass boost button it should bring up a menu. there should be an aux setting in there. i just did that with mine and it was there. the manual doesnt show it either.
Jun 27, 2009 | Kenwood KDC-MP335 CD Player
Blank screen no picture
connection between the dvd output and screen has broke link somewere. pull it apart and check it out
Jun 05, 2009 | Philips Magnavox DVD/VCR Dual Player
HDTV Converter hookup with sat. and antenna
Hi there Phil...... this switch from analog to digital has lots of folks scratching their heads. Fortunately I have some great news for you. The signal coming from the Dish network does not need a converter as it is already digital.
May 29, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
My turntable works on old reciever and not new one
A traditional turntable only works on Phono (which contains special preamplification and equalization circuitry designed to raise the the level and flatten out the response of a phono cartridge).
After you do that, iIf you're not having hum problems I wouldn't worry about the ground. Or try it again on the FM Ground.
Feb 20, 2009 | Sherwood RX-4105 Receiver
Magnavox TV remote broken - won't switch to watch DVD
There may be a manual reset button somewhere on the back of the set. If not, try unplugging it for 10 minutes and then plugging it back in. If that doesn't work, call Magnavox.
Apr 11, 2017 | Televison & Video
Aux port doesn't show; Button is Stuck
I don't know if you have figured out how to turn the AUX port on yet, but I just figured it out. First, turn the CD Player off by quickly pushing the "Source" button. This is also the volume knob. Then, after the player is off, hold down the "Source" button. This will bring up the initial setup. Use the arrow keys to navigate through the options. One of the options is to turn the AUX port on. Once this is finished, turn the unit back on and you're ready to go.
Jan 22, 2007 | Pioneer DEH-P4800MP CD Player
Open Questions:
47 people viewed this question
 Grubhead
Grubhead
