Question about Scotsman Ice Maker CM3 30inW Cubed Ice Machine 900LB
The water only flows then it stops - Scotsman Ice Maker CM3 30inW Cubed Ice Machine 900LB
  • howard thompson Dec 15, 2014
    Hi maria o rivera, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? what are you seeing on the CM3 controller? what light is on when machine stops?
  • 102 Answers
Check water filter or make sure water is on....sounds like slow water fill
Posted on Jan 14, 2015
Fl0 code
Flo ? for Flow Error?
That would for any number of reasons that the Flow Switch is not sensing enough water flow to trip the sensor/pressure switch or actual true water flow switch.
Heater will not run or heat, if there is not enough water flowing!
The heater will sense this. So, whatever will restrict or stop sufficient water flow is the problem.
  • Dirty filter
  • Closed valves
  • Not enough water in tub or pool - low water level
  • Clogged pump impeller
  • Clogged baskets:
    • at pump or at skimmers
  • Clog / stopped up plumbing line
And finally, you may have a bad flow switch/sensor
Sep 06, 2014 | Jandy Pool & Spa
Tip
Water stops flowing while washer is filling
The hot water on my washing machine abruptly stopped flowing within the first couple of seconds. After a bit of checking I found that the fill hoses behind the washer are of the sort that automatically stop the water flow if it exceeds a certain rate. They are several years old and apparently the valve on the hot water hose has started to malfunction -- it stops the water at a lower pressure than it should.<br /><br />Temporary workaround: If you absolutely MUST wash a few loads, you might be able to get it working by reversing the hose. Disconnect it from both the washer and the valve, then turn the hose around and connect it back again. The valve should not interfere with water flowing in the other direction.<br /><br />Permanent fix: Replace the fill hose as soon as possible to help prevent flooding accidents. These hoses can't prevent flooding in all situations, but as they say... better safe than soggy. (Sorry, couldn't resist!)<br /><br />Something else just occurred to me as I was writing this. Reversing the flow through the hose for a few cycles of the machine might actually help to unclog the flow-stopping valve. Before plunking down the cash to replace the hose, try reinstalling the hose in the correct direction and test to see if the water flows normally. I will try this and post a follow-up as soon as I can.
on Jan 15, 2011 | Washing Machines
Hot water will not stop flowing. Hot water
Sounds like a bad shutoff solenoid. It operates the valve to let water in and then shut it off. There should be a valve behind the machine where the hose connects to the wall so you don't have to isolate hot water to the entire house.
Sep 18, 2017 | Bosch Axxis WFL 2060 Front Load Washer
I have Paloma PTG2 42PVN No water flow when I open the faucet. I turn the water heater off at the remote and then back on and I get water flow for about30 seconds and the water is warm, then the whole...
Question is not clear.
Does all water flow stop? Or does hot water flow stop?
Open following links for possible help.
http://waterheatertimer.org/Crossover.html
http://waterheatertimer.org/Low-hot-water-pressure.html
http://waterheatertimer.org/pdf/No-Error-Code.pdf
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Add a comment for more help.
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 12, 2011 | Rheem Paloma PTG-42PVN / RTG2-42PVN...
Icemaker clogs with ice. Water flows with icemaker unplugged.
ur solenoid could be allowing water to flow freely its in the back its blue try replacing this solenoid and see if this fixes the problem they r cheap and easy to change
Feb 27, 2010 | Amana ARSE67RBB / ARSE67RBW / ARSE67RBC...
Water flow from humidifier never stops. Even when furnace is off.
No, it will not stop flowwing if it is the water supply. A solenoid valve opens the flow everytime there is a call for humidity, but it stops at the humidifier when there is no call, so it will leak from that point until it is fixed or tightened.
Apr 17, 2009 | Honeywell HE365 Humidifier
Do i need to have a flow stop istalled in my cold water in line?
Yes you'll still need a flow stop unless it is already install in the outlet pipe going out out the heater..
Apr 01, 2009 | Rheem RTG-74DVP Direct Vent Liquid Propane...
Whirlpool top loader
You either have a defective pressure switch or water inlet valve. Start to fill the machine with warm water so that both solenoids on the water inlet valve (hot and cold) are activated. After about 30-60 seconds, push the timer knob in to stop water flow. If the water continues to flow, replace the water inlet valve. If this is the case, it may take a few times of starting and stopping water flow to allow solenoid to heat up and become symptomatic. If water flow stops abruptly each time knob is pushed in, you most likely have a defective pressure switch (water level switch).
May 09, 2008 | Whirlpool LXR9445JT Top Load Washer
Kitchen Appliances - Others Logo
188 people viewed this question
Top Scotsman Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Tim Whalen
Are you a Scotsman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
