Question about Garden
Poulan hydrostatic drive
Our model riding mower has been having a belt drive problem. It keeps slipping off. Bought new belt still slips off. Looking at lay out off pulleys looks like we are missing one that would definetly add more tension. So, we like to know how to get one if we need it?
What is most likely the problem if i was cutting talk very wet grass?
Posted on Jul 31, 2013
  • 86 Answers
SOURCE: belts slipping and breaking
If you are putting on the mtd belts and installing them right then you need to check bearings in variable speed pulley Also check idler and that no other pulley has been bent from installation.
Posted on May 16, 2009
  • 19 Answers
SOURCE: Older model Ariens ride around lawn mower - drive belt slips off
it could be the belt has streched
check tensioner if has one and check all nuts and bolts tight
Posted on Jun 23, 2009
mowerman1857
  • 389 Answers
SOURCE: The mower deck drive belt slipped off the idler
Get the model number off the tractor, go to:
www.murray.com
enter the model number and you will find a manual with pictures of how to route the belts along with a lot of other good information
Posted on Sep 30, 2009
harlan301
  • 205 Answers
SOURCE: belt is slipping off pulley
your should have a tension spring on the idler pulley. that maintains the tension on the drive belt. check to make sure you have the right belt and that is not worn or stretched out. also check to make sure your variable drive assay is working
Posted on Oct 11, 2009
suzukiracing
  • 200 Answers
SOURCE: How do you replace drive belt on a hydrostatic
Its not a hard job just push in clutch and lock it, remove mower belt then replace drive belt and then put mower belt back on and release clutch.
Posted on Jul 19, 2010
MOWER WONT MOVE
Drive belt broken or slipped of pulleys, hydrostatic drive filter(s) plugged. Should be one or those, Roger. Follow the drivebelt with your hand (disconnect battery to be safe) and see if it hasn't slipped off the engine drive pulley, idler pulleys, or axle pulley. If you tractor is hydrostat, may be time to replace filter.
Aug 09, 2015 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
How to adjust tighten drive belt on Poulan riding mower with 18 hp b&s motor 42 deck
Probably needs a new belt.You can buy a belt dressing and spray the belt once in a while. Its a special sticky spray for belts that slip.
That will keep you going for a little while.
Apr 11, 2015 | Poulan Garden
How to change dive pulley for 944602660?
This is likely due to a worn and slipping belt. Replacing the belt should solve the problem
Aug 03, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
My riding lawn mower slips in and out of gear while going forward
Sounds like your transmission is shot if its a geared mower. If its a belt driven hydrostatic mower the belt is slipping and needs to be replaced.
Jul 18, 2013 | Garden
Husqvarna Riding Lawn Mower Yth24v48ls 48 Inch Cut hydrostatic transmission slipping
first i would check the belt tension also check the belt for oil is so look for the cause of the leak the repair the leak and replace the belt
Jul 30, 2012 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Drive belt keeps slipping off when clutch is pushed in
when you replaced the belt did you put the tabs bad into place that keep it from coming off the pulleys?is there a bad pulley?
May 29, 2012 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
My MTD 12.5 hp briggs and stratton ride on mower is losing forward speed as though a clutch is slipping especially going up hills or slopes. MIKE
You didn't indicate what model so I don't know if it is hydrostatic drive or not. If it is not hydrostatic drive, it is most likely a worn belt or clutch adjustment. If you don't have your manual you can download one here:http://www.mtdlawnmowerparts.com/manuals.php
If it is hydrostatic drive it stil could be the drive belt or low water in hydrostatic transmission, or even water in the oil in the hydrostatic transmission. Always list model number when asking questions.
Oct 03, 2010 | Mtd Garden
How do you replace drive belt on a hydrostatic transmission craftsman riding lawnmower that has slipped off or my be broken.
Jul 17, 2010 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
Garden Logo
43 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
