Question about Toshiba 62HM95 62" DLP HDTV
My 62 in projection Toshiba tv, has not picture or sound, what can it possibly be? Please help.
    Top Expert:
  • Toshiba Master
  • 12,223 Answers
Please do the following. God bless you
  • Reset component settings. Usually, the problems you encounter with a projection TV may be resolved through the resetting to its factory settings. If you experience inaccuracies in the color, reset the television's PerfectTint/PerfectColor capabilities. Simply press the Menu tab and then highlight "Perfect Color" using your right key arrow. After this, press "Enter" and then "Reset" in order to reset to factory settings. If you have audio / video problems (VCR or DVD player), simply press "Menu" and highlight the "Reset" option.
Reset television controls. In case you cannot fix your TV via its component settings, there are other ways of resetting. Just select "Menu", key in "1, 2, 3", and then press "Enter." In doing this, the TV's manufacturer's specifications will all be restored. If your TV's power system does not function, you should perform a complete system reset. You can do this by clicking on Reset System button located at the TV's control panel. Your television will be turned off and then a green light (LED) will quickly flash for approximately one minute. Once the light has stopped flashing, your TV should immediately turn on.
Posted on Aug 01, 2013
4 Suggested Answers
  • 8 Answers
SOURCE: toshiba TP43H95 projection tv has power but no picture
If it shuts off and then the power light starts blinking red or it never comes on but the power light just blinks red continuously that is usually indicative of the convergence ICs (STK 392-110). You never want to replace the ICs without also replacing the resistors that are associated with them. There are usually 6 resistors, one for each of the colors and there corresponding direction, IE Red horizontal, red vertical, blue horizontal, ect. In the case of this model tv all of the resistors are 2.2 Ohm and 2watts. You will find them right where the STK 392-110 ICs are. Right in front of them. They are blue and have this color code on them. Red, red, gold, gold. These are represented by stripes on the resistors. You can get the parts from www.bdent.com They carry the ICs and the resistors. If you do not feel comfortable completing this repair I could do it for you if you send me the board. My email address is: missionelectronics@sbcglobal.net The cost is 375.00 and that includes parts.
Good Luck.
Posted on Jun 26, 2009
  • 277 Answers
SOURCE: 65" toshiba projection tv no picture but has sound..
if you could hear only sound in tv and not picture means it might be the picture tube problem just check it.
Posted on Sep 17, 2009
  • 81 Answers
SOURCE: Toshiba 62HM84 Starting Problem
you need a balist.
olso in the cust menu is a quick start mode . turn it off
Posted on Nov 18, 2009
Toshiba 62 mx 195 picture frozen sound ok lamp ok cooling fan ok
set is locked up, if frozen the microprocessor is locked up---only simple thing is unplug set and a box if being used for a while and plug b a c k to see if the units will reboot.
Jun 07, 2012 | Toshiba 56HMX195 52" HDTV DLP Projection...
I have the toshiba 62"
The tv projection Lamp shutdown 3-4 mins,than u hear alot of clicking noises sound too?Yes,than the board that call the Ballast board it is dead too.The Ballast board only job are to help to ignite the projection Lamp only.
Jun 07, 2011 | Toshiba 62HM95 62" DLP HDTV
62HM 95 TOSHIBA. HAD THE PICTURE JUST GO BLACK THE OTHER NIGHT. I HAD A LAMP FOR IT GIVEN TO ME BY A BUDDY IT MAY BE A USED ONE NOT SURE. REPLACED BULB TV CAME BACK ON BUT PICTURE IS TO DIM TO WATCH. DONT...
These Toshiba DLP's were lemons.
There was a class action lawsuit in the US and Toshiba were forced to issue a recall on the lamps. Toshiba replaced the first lamp for free but when the lamps are burning out every 6 months at a replacement cost of $200 these tv's are expensive to run.
Sounds to me like the light engine has failed. This will probably be a $800-$1000 repair.
Scrap it and take the hit.
Nov 01, 2010 | Toshiba 62HM95 62" DLP HDTV
Just replaced the lamp on my Toshiba 62HMX84. Picture still is not coming on I have sound. When you turn on the TV you hear a clicking sound that goes away and then the TV try's to restart itself Thinking...
I have a 62HM84 Toshiba TV. I lost picture on my TV in the past i have bought the lamps and i just put it on and the picture comes on. This time when i replaced the lamp nothing happens no picture. It tries 8 times to turn on, but nothing happens. Can you help me with is what is the problem.
Dec 15, 2009 | Toshiba 62HMX84 62" Rear Projection HDTV
you need a balist.
Nov 18, 2009 | Toshiba TheaterWide 62HM84 62" Rear...
Picture loss after picture begins to flash. blue and yellow light
Most likely the lamp is dying. Try replacing the lamp before calling a repair tech. What does the Owners manual say about the blink lights?
Oct 01, 2009 | Toshiba 62HMX84 62" Rear Projection HDTV
Are there more than one lamp or bulb in a 62 in projection tv. Lights on base of tv flashing.... No picture just sound.
no there is not, look in several retail merchants here at techlore who will sell you the correct bulb! just look around
Techman
Sep 03, 2009 | Toshiba 62HMX84 62" Rear Projection HDTV
Toshiba Rear Projection Screen Problem
It's a DLP right?
I think ur TV's bulb is dying...check the running hours of the bulb in the menu.
Rifaa
Nov 19, 2008 | Toshiba 62HMX84 62" Rear Projection HDTV
Toshiba 62HM95 62" DLP HDTV Logo
106 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
