Question about Helen Of Troy 1 in. Ceramic Straightener 1 Plates RVST2046CN2
How long does the flat iron stay on if forgot to turn off?
SEDU flat iron won't turn on when i plug it in...
flat iron has large metal foil so change the procdure
Jan 24, 2014 | Sedu Pro Ionic Ceramic Tourmaline Flat...
Tv won't stay on
Internal capacitor(s) are weak/failing. Could replace entire control board, or if electronically inclined, replace leaking/bulging capacitors using soldering iron.
Dec 22, 2013 | Philips 46PFL3705D 46 in LCD TV
Sedu flat iron
because it is automatic so it turns on and off after heating at a certain temperature it turns off automatically.
May 16, 2013 | Sedu Pro Ionic Ceramic Tourmaline Flat...
Error code on ion gator flat iron the temperature won't stay in the window
Yeah even I think that you should buy new flat iron instead of getting old one repaired. There are some fantastic offers on flat iron on folica.com. You'll definitely like their offers as I found them mind blowing always.
Oct 30, 2012 | ION Irons
Gets hot then shuts off
Most flat irons come with a safety setting where as soon as they get to a certain temperature, they shut off (to keep the customer safe). Try turning the setting down to a medium-hot. Also, if it stays on for a long time it will shut off by default to help with accidentally leaving it on. 1. Try turning the heat down 2. Don't let it set for long 3. Try hitting the reset button. Sometimes the settings get shifty, so resetting the device can sort out the problem. 4. If none of the steps work, take it back. There is something wrong with the flat iron, like a short in it.
Apr 08, 2011 | Chi Ceramic 1 inch Flat Iron GF1001USA
Where can I get my Chi Flat Iron fixed. I only used it 3 times but had the iron over a year because I have my hair ironed at the beauty shop due to its length. I bought the Chi to do touchups and am...
Chi Flatiron Repair Fix it Yourself User Photos
Most appliances come with manuals that give you company contact information. My guess is the iron is out of warranty. As irons have high voltage components, do it yourself is not advised. Staying alive is better than fixing an iron. That said, the above link even tells you how to take it apart. I have a hunch that good parts would have to come from another broken Chi iron. And where would you get that! Maybe someone on the above link can be contacted. Alas, you simply wanted a reliable business that might check this out. I doubt you want to pay a technician for his time in taking this apart. I wish you well.
Jun 04, 2017 | Chi Nano Digital Ceramic Flat Iron 1.25...
Have to keep turning tv swith on and off before it finally stays on
Just fixed mine, similar problem, it was the capacitors in the power board. The fix cost me a total of $21. $15 of that was for a soldering iron, and a de-soldering iron, the other $6 was for the new capacitors.
If you pull the back off look at the power board, take a look at all the capacitors, if any of them are bowed out in the back (should be flat) then they are blown. I had 7 blow. The new capacitors I got at a higher voltage, hoping to thwart the problem in the future.
Hope this helps!
Nov 19, 2010 | Zenith Z50PX2D 50 in. Plasma HDTV
My 40"samsung LCD turns on/off 3-4 times before staying on
You need to change the 1000uf caps in the power supply. only if you are handy with a soldering iron. Take back of remove psu. You will see them bulging at the top. Think there is 5 to change :)
Jun 16, 2009 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Helen Of Troy 1 in. Ceramic Straightener 1 Plates RVST2046CN2 Logo
223 people viewed this question
Top Helen Of Troy Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Helen Of Troy Health and Beauty Expert? Answer questions, earn points and help others
