My Toshiba tv has no picture or sound, it only tells me that the door is open.
    Top Expert:
  • 12,223 Answers
Please do the next test.God bless you
  • Reset component settings. Usually, the problems you encounter with a projection TV may be resolved through the resetting to its factory settings. If you experience inaccuracies in the color, reset the television's PerfectTint/PerfectColor capabilities. Simply press the Menu tab and then highlight "Perfect Color" using your right key arrow. After this, press "Enter" and then "Reset" in order to reset to factory settings. If you have audio / video problems (VCR or DVD player), simply press "Menu" and highlight the "Reset" option.
Reset television controls. In case you cannot fix your TV via its component settings, there are other ways of resetting. Just select "Menu", key in "1, 2, 3", and then press "Enter." In doing this, the TV's manufacturer's specifications will all be restored. If your TV's power system does not function, you should perform a complete system reset. You can do this by clicking on Reset System button located at the TV's control panel. Your television will be turned off and then a green light (LED) will quickly flash for approximately one minute. Once the light has stopped flashing, your TV should immediately turn on.
Posted on Aug 01, 2013
Toshiba 40xf355d 40inch Plasma tv won't turn on it just makes a clicking noise. thez no picture or sound? my tv powers on and makes a clickin sound but i dont get picture or sound its stays black i have...
That model is an LCD that uses a backlight. Probably with CCFL tubes. They are known to have bad inverter supplies. Its an old TV though. Keep that in mind.
Jan 05, 2018 | Toshiba Televison & Video
I have a toshiba 57h94 and when i turn on the tv i can hear a clicking sound, but no picture comes on. also, you can still hear a fan blowing.
You may want to check and see if the lamp is bad. On the left lower side there is a lamp door.
there is usually a knob screw or a phillips screw that keeps it in place. Open the door, remove the retaining screws for the lamp and pull the lamp out. Most of the time it is shattered and easy to tell it is bad. There is a part number on the lamp housing. If you can not find one local to you call
1800-631-3811. This the Toshiba customer service line and you can order one from them. I would expect to pay around 175.00 and 200.00 for the lamp.
I hope this helps,
skyassoc
Dec 09, 2010 | Toshiba 57H94 57" Rear Projection HDTV
Toshiba 46in DLP No Picture, but good sound.
Hi my name is Eric,
I hope I can help you with your issue ,
Sounds like a bad lamp assembly , search for one online by model# for between $100-$200
easy to install yourself
Hope this helps, if it has solved your issue please click accept
But if you have more questions please respond and I will reply asap
Thanks
Eric
Sep 09, 2009 | Toshiba 56HMX195 52" HDTV DLP Projection...
Picture on 36 inch toshiba tv out
I had the same problem on my 61" RCA TV... The switch for the power/channel changing buttons seems to be a faulty product... However if you are a little technical you can open up the front of the TV and disconnect the button panel from the tv and just use the remote to operate it.
Jul 02, 2009 | Toshiba Televison & Video
Why does my toshiba 72 inch projection tv picture freeze?
sounds like your dmd module. its the part of your optical block that processes the images that make up what is projected on your screen.. without a model # i can't tell you the part #
Mar 13, 2009 | LG Televison & Video
Toshiba projection tv
Sounds like it blew an "Internal Fuse"
if you want to fix it..simply open rear of TV and look for the fuse.
here is link for a manual if you do not have one.
Mastersage
http://www.devicemanuals.com/guide/Television/Toshiba/Toshiba-43H70-User's-Guide-TVRNME9EUT.html
Feb 05, 2009 | Toshiba 43H70 43" Rear Projection...
TOSHIBA TV NO SOUND NO PICTURE, POWER LIGHT IS ON
the lamp in the projector might have went. try replaceing it. to do so try
ADTECH SYSTEMS they may help
there in mass.
call David Crepeau at 978 261 1087 tell him Ryan Bolduk sent you
depending where you live. They maybe able to send someone out from there sub company
Sep 18, 2008 | Toshiba 42H81 42" Rear Projection...
No picture only sound, Toshiba 36A 36" TV tube type
my friend if you open the tv carefully look to see if the tube itself has light, or if you have high voltage i coulbe many different things.wish luck!!
caypianan@yahoo.com
Aug 10, 2008 | Toshiba 36A50 36" TV
Toshiba 32A33 no sound
your tv needs to be open,check the speaker if its good or not ,then the supply of the amplifier and the amplifier itself also.
Jul 25, 2008 | Toshiba 32A33 32" TV
Televison & Video Logo
Top Televison & Video Experts
