Question about Cub Cadet Garden
Turns over but won't start
Was mowing and engine stopped (was running a little rough from the start of mowing). We've changed spark plug and fuse, and checked to be sure fuel is flowing as it should. We checked to see if it is sparking, and it doesn't seem to be. Now what? Thank you!
  • Marsha Morris Jul 31, 2013
    I should have mentioned that the LT-1042 motor will turn over fine but won't start.
    Novelist:
  • 212 Answers
Hello Marsha, 3 things needed for an engine to run are; compression, spark and fuel. You said you checked spark and you have none. Did you check with spark tester or by grounding the plug to engine block? If you don't have any spark check fuses and wiring to make sure all is good. Then if you have a multimeter you will have to check coil for resistance. If your not sure you should take to a qualified technician. Hope this helps. Good luck!
Posted on Aug 01, 2013
02 mitsubishi lancer oz rally automatic and when I turned it off the engine sputtered a little so I turned it back on started up back fine and shut it off and it sputter again Its neverdone thisHelp?
I think what you are describing may be "run on" or Dieseling" which is a way of saying that an ngine with spark plugs that should stop when the key is turned off, continues to run in a rough manner. This is typically caused by glowing carbon in the cylinder, often on the head next to a fouled spark plug tip.
I would recommend changing the spark plugs and spending the $ for some "tune up in a can" that removes carbon deposits from inside the cylinders.
Hope this helps.
Apr 04, 2015 | 2002 Mitsubishi Lancer OZ Rally
Zafira 1.8 petrol 03 runs rough for 30/50 seconds when started then ok but a little sluggish
The "won't rev" part sounds like a preventative so you won't destroy the engine from cold start-up. The sluggish part sounds like bad fuel or spark plugs. Where do you buy your fuel and what octane is it? and have you Changed your plugs?
Jun 25, 2012 | Cars & Trucks
My mower won't start
try running it with the gas cap loose the vent might be plugged
Apr 13, 2012 | Garden
Kawasaki 17hp fh500v won't start.
Did you try to use a little starting fluid to get it going. If you did and it would not fire, then you have no spark at the plug. If you did and it did fire, then you have no gas getting to the carb.
Mar 10, 2012 | Garden
1997 mazda 626 won't start.
Are the plugs wet with fuel?
Check for spark. No spark? it may be the ignition module.
Plugs dry and spark present? No fuel?Spray a little starting fluid and see if it will run on that.
Then check pump fuses and for fuel pump noise.
Jun 01, 2017 | 1997 Mazda 626
Troy Bilt self propelled lawmower won't stay on. It's been fine this year, today all I did was add gas and added the mulch shoot. I turned it on, it was fine. Started mowing, got halfway across...
The trouble you are experiencing could result from several different things. First, check the oil when the engine is cold and completely settled in the sump. You do not want to overfill the engine with oil. If the oil is on the full line (not above it),then the low oil sensor is not shutting off your engine. The oil level should be exactly on the full line-not above or below. Second, remove the spark plug and clean it with a small wire brush or sandpaper. If you are unsure about how to clean the spark plug, replace it with a new one. If both of these procedures have been performed and the mower still doesn't run correctly, the problem is almost certainly with the fuel supply, fuel quality and/or carburetor.
Jul 30, 2017 | Troy Bilt 5.5hp Self Propelled Mower
I have a riding lawn mower. i hit a rock while mowing and it ran a little rough after. i was able to finish the lawn, but when i tried to start it later, it just turned over and wouldn;t start. i...
You may have damaged the flywheel key. This affects the timing of the engine, which results in among other things, hard starting and when running will not run as smooth. The flywheel key is the little metal piece that keeps the motor crankshaft engaged to the flywheel. It is designed to shear or partially shear to protect the engine from more sever damage from impacts.
I hope this helps, please let me know how it goes.
Aug 19, 2011 | Garden
Engine turns over but doesn't fire.
check it for spark then check if it is getting fuel cuz that might be the problem
Jun 07, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Have 2000 limited 4.7. Has engine light on and checked codes,says #3 & 6 misfire. changed coils. but still have light and runs rough at 65-69 mph. A little rough at stop.
why would someone even start with changing the coils...usually a misfire is due to bad spark plugs..replace spark plugs, then go from there...just for a personal reference, the next time you want to see if your coils are bad, simply change out your bad two coils with two coils on the other side of the engine that are good...if they misfire code changes, then you know its a coil...if not, plugs...
Nov 16, 2009 | 2000 Jeep Grand Cherokee
Mower stops running after I've been mowing for about 30 minutes. I changed the spark plug and fuel filter. It seemed to work and I was mowing the lawn then it just started acting like it was running out of...
Mower stops running after mowing about 5 minutes. acting like it was running out of gas unitl eventually stops. I wait 10 minutes and then it restarts, runs good, then erratic...then quits again?
Aug 23, 2009 | Garden
Garden Logo
94 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
