Question about Goodman Heating & Cooling
PGB036100-1A I need to remove the blower motor housing and I can't seem to find how you remove it. It appears it slides up into place because it is at an angle but there are no screws to remove it. There is a cross bar under it that I've removed but the housing won't slide down.
  • 4 Answers
SOURCE: frigidaire air conditioner
remove cover .It might have two screws on the side or just pops off. Pull unit out from cover. if it does't move remove screws in back of unit near condensor
Posted on Dec 29, 2007
  • 9 Answers
SOURCE: Replacement Blower Motor
Refer to model number of unit.
Posted on Aug 21, 2008
pierre1811
  • 144 Answers
SOURCE: Blower Pully slides off shaft.
Tighten away.
Posted on Apr 14, 2009
boysor2933
  • 293 Answers
SOURCE: fan sliding
Tha fan is fixed to the shaft (bar) with a set screw. It is located at the hub at the back of the fan.
Posted on May 28, 2009
co7196
  • 3433 Answers
SOURCE: trouble removing fan motor
Don't forget your wiring if you haven't disconnected it.
Posted on Aug 03, 2009
How to replace blower wheel on Friedrich SL28M30 AC unit
follow this steps and fix it. God bless you
    • 1
      Turn the electricity to the air conditioning unit off at the
      service disconnect box. Follow the wires from the AC unit to the
      disconnect box, usually located next to the unit. Open the disconnect
      box and, depending on the type, either pull the buss-bar or flip the
      disconnect switch.
    • 2
      Open the air handler\'s access panels with the correct size of nut driver, usually 5/16- or 1/4-inch. Save the screws.
    • Remove the control panel\'s cover, if equipped, with a nut
      driver. Some models have a flat metal cover over the electronic
      controls, and some control panels butt up to the unit\'s access cover.
      Save the screws and access cover.
    • 4
      Follow the wires from the blower motor. Two wires will go to
      a capacitor located on the blower\'s housing. The rest of the wires will
      go to the control panel.
    • 5
      Cut the wires leading into the control panel with wire cutters. Leave the cut wires connected inside of the control panel.
    • 6
      Remove the retaining bolts with either a nut driver, usually
      3/8-inch, or an adjustable wrench. The retaining bolts, found on the
      mounting brackets that the blower\'s housing slides on, keep the blower\'s
      housing locked into position. Save the bolts.
    • 7
      Slide the blower motor\'s housing out of the AC unit. The housing will slide straight out along the mounting brackets.
    • 8
      Disconnect the two wires going to the capacitor. They will pull straight off the capacitor\'s terminals.
    • 9
      Unscrew the squirrel cage\'s locking-screw with an adjustable
      wrench. The squirrel cage, the bladed wheel, connects to the blower
      motor\'s shaft inside of the housing. The locking screw holds the
      squirrel cage to the shaft.
    • 10
      Unscrew the blower motor\'s mounting screws with either a nut
      driver, usually 3/8-inch, or an adjustable wrench. These screws hold
      the motor to the housing and are found on the opposite side of the
      squirrel cage, the same side that the wires leave the motor.
    • 11
      Pull the motor from the housing. A drop of oil on the shaft
      will aid in removal. If the squirrel cage sticks to the shaft, then hold
      the shaft still with an adjustable wrench while spinning the squirrel
      cage on the shaft.
    • 12
      Slide the new blower motor into the housing. The blower motor\'s shaft will slide into the squirrel cage\'s hole.
    • 13
      Tighten the blower motor\'s mounting screws.
    • 14
      Spin the blower motor\'s shaft until the flat part of the
      shaft lines up with the squirrel cage\'s locking screw. Move the squirrel
      cage in or out until it does not touch the housing or the blower motor.
      Tighten the locking screw.
    • 15
      Connect the blower motor\'s capacitor wires, usually brown or
      brown with white stripes, to the capacitor. Direct replacement motors
      use the same color-coded wires as the original.
    • 16
      Slide the blower motor\'s housing into the AC unit along the mounting brackets. Install the mounting bracket\'s retaining bolts.
    • 17
      Connect the new blower motor\'s wires in the control panel
      one at a time. Disconnect one old wire in the control panel. Determine
      its color and connect the new wire, of the same color, to its place. Do
      this for all wires.
    • 18
      Replace the control panel\'s cover, if equipped, and the
      unit\'s access cover. Turn on the power to the unit at the disconnect box
      and test the blower motor.
Jul 17, 2013 | Friedrich Kuhl Series SL28M30 230 Volt,...
Hi, my 1998 dodge durango front AC/Heater blower motor run on and off, after the fan shuts down and stops running if I reah under the dash and hit the plastic fan housing it will start-up running but it...
If you can hit on the blower motor housing and the motor starts, your brushes on the motor are bad and the blower motor needs to be replaced. Used tested unit $30.00 at a junkyard. New rebuild $54.00.
Many posts have stated that the dash must be removed to replace the blower motor. It can be done without removing the dash. I know as I replaced the blower motor on my kids 99 Durango last night but it took about 4 hours. Now that I know how to do it, it would estimate 2 hours.
Remove glove box by opening glove box all the way. Press inward on the both sides of the glove box to allow the rubber stops to clear the catches and lower the box The two outer hinges (plastic) will come off by slightly twisting the glove box upward leaving only the center hinge (plastic) in place. Reach in and push down on the hinge to pull out glove box. Set aside.
Remove side trim panel by pulling back carpet and remove one Phillips screw. Remove panel by pulling back on upper portion to remove clip from frame, then slide forward to remove from lower plastic trim.
Use 1/4" nut driver or socket to remove two screws holding vacuum canister on lower right side of blower shroud. Remove two vacuum hoses noting which hose goes to which side of the vacuum canister (both were green in color on my Durango). Disconnect connecting rod from vacuum canister to vent control by removing lock washer (you may be able to get away with not removing the rod, but the plastic "fin" may break if you stress it while removing the blower shroud.
Use 5/16 nut drivers/sockets with extensions to remove the blower shroud hex bolts. The hex bolts are located in several areas around the shroud (use your finger to follow shroud edges to locate all 8). Some of the hex bolts are very tricky and may require odd positioning of your body to locate and remove them.. I also put several extensions to use in order to reach the various hex bolts. Once the hex bolts are removed, pull the plastic blower shroud down exposing the blower motor squirrel cage.
Remove two of three hex nuts holding blower motor in place. Loosen the third one and the blower motor should come free. I was not able to remove the squirrel cage from the old motor so I broke the squirrel cage allowing me to expose the wire harness and grommet that went through the back of the shroud.
Feeding the wire harness back through the assembled wall appeared to be a real challenge, so I cut the green and black wires at the motor for splicing into the new motor later. Remove the motor and broken squirrel cage and throw the dam thing away.
Remove squirrel cage from new motor by removing retention clip with a pliers. Pull off the squirrel cage carefully by applying WD40 (or other lubricant) to the shaft. You may have to place two large screw drivers or other pry bars underneath the squirrel cage equally across the underside of the squirrel cage slowly prying up the cage. I accomplished this with a helper to hold the motor in place to allow equal pressure from both pry bars.
Cut green and black wires on new motor leaving enough wire to work in the tight area of the motor housing. Strip wires from old harness and new motor and apply **** splices for green to green and black to black. Add electrical tape for extra mechanical strength and insulation.
Place new motor into housing and secure the three mounting hex nuts. Turn on key and run blower to make sure it works. Install squirrel cage and retaining clip on motor shaft. Run again to make sure it works.
Install the balance of the items in the reverse order you removed them.
Now on to replace the rear wiper motor on the same Durango. Junkyard parts $54.00. Time: Unknown?
Jul 31, 2011 | 1999 Dodge Durango
I have a Goodman GMPN furnace and the motor that runs the twin blowers has quit. How do I take it out and replace it?
If you mean the blower wheel, I wonder how you diagnosed this problem so you were 100% sure the motor is bad. I recommend to make sure of the diagnosis before spending to buy parts.
The blower wheel is shaped like a twin blade. But it's only one wheel.
However, to answer the question; Step one is turn the power off.
Then; Find the blower housing in the lower compartment on an upflow configuration.
  • Remove 2 screws on the blower housing, on the upper inside of the blower compartment to slide the blower housing out.
  • Disconnect blower motor wiring at the harness and at the control board if connected. You can cut them if you have exact replacement motor and wire nuts.
  • Slide the housing out, turning it on the side that exposes the motor.
  • Remove the 3 mounting screws holding the motor to the housing.
  • Loosen the lock nut holding the fan blade (wheel) to motor shaft.
  • Slide motor and shaft out and away from the fan blade, as they are connected together and cannot be separated. Use penetrating oil SPARINGLY.
Installation is the reverse of the removal instructions.
IMPORTANT. Make sure to leave equal space between both sides of fan blade and housing when re-installing the wheel.
Luck to you. Let me know how that turns out.
Russ
myairfixer@gmail.com
Dec 23, 2010 | Goodman GMS90703BXA Heater
How to replace rear blower motor motor in 2006 chrysler town and country van
from autozone.com:
Removal & Installation
  1. Disconnect and isolate the negative battery cable.
  2. Remove the right quarter trim panel as follows:
    1. Remove first rear seat. Remove the second rear seat, if equipped.
    2. Remove the sliding door sill plate.
    3. Remove the quarter trim bolster.
    4. Remove the upper C-pillar trim and D-pillar trim panel.
    5. Remove the first and second rear seat belt anchors.
    6. Remove the screws securing the quarter trim to quarter panel from the bolster area.
    7. Remove the screws securing the rear edge of the quarter trim to the support bracket.
    8. Carefully disengage the hidden clips securing the front of the quarter trim to the quarter panel just rearward of the sliding door opening.
Fig. Removing the trim panel to access the rear blower motor
i. Disconnect the wiring harness connector from the accessory power outlet, if equipped.
j. On long wheelbase wagons only, remove the quarter trim from the quarter panel and pull second rear seat belt through access hole.
k. Pull first rear seat belt through the access hole.
l. Remove the quarter trim panel from the vehicle.
3. Remove the 5 screws mounting the A/C-heater blower motor housing to the rear HVAC unit (one mounting screw located on evaporator cover).
4. Twist the blower motor out of scroll housing.
5. Disconnect the blower motor wiring connector.
6. Remove the blower motor from vehicle.
Fig. The rear blower motor is held in place by four screws
To install:
  1. Install the blower motor unit into the vehicle.
  2. Reconnect the blower motor wiring connector.
  3. Secure the blower motor into scroll housing.
  4. Install and tighten the 5 screws mounting the A/C-heater blower motor housing to the rear HVAC unit (one mounting screw located on evaporator cover).
  5. Install the right quarter trim panel as follows:
    1. Install the quarter trim panel in position in the vehicle.
    2. Insert and pull the first rear seat belt through the access hole in quarter trim panel.
    3. On long wheelbase wagons only, insert and pull the second rear seat belt through access hole in quarter trim panel.
    4. Reconnect the wiring harness connector to the accessory power outlet, if equipped.
    5. Engage the hidden clips to secure the front of quarter trim to quarter panel rearward of sliding door opening.
    6. Install the retaining screws that secure the rear edge of quarter trim to support bracket.
    7. Install the retaining screws that secure the quarter trim to the quarter panel in bolster area.
    8. Install the second rear seat belt anchor (if equipped), and the first rear seat belt anchor.
    9. Install the D-pillar trim panel and upper C-pillar trim.
    10. Install the quarter trim bolster.
    11. Install the sliding door sill plate.
    12. Install the second rear seat, if equipped, and install the first rear seat.
  6. Reconnect the negative battery cable. Check blower motor operation.
Nov 04, 2010 | Chrysler Town and Country Cars & Trucks
How to replace the blower motor in a dodge 2001 caravan
    9. Disconnect the wiring harness connector from the accessory power outlet, if equipped.
    10. On long wheelbase wagons only, remove the quarter trim from the quarter panel and pull second rear seat belt through access hole.
    11. Pull first rear seat belt through the access hole.
    12. Remove the quarter trim panel from the vehicle.
To install:
Hope helps (remember to rate this).
Nov 01, 2010 | 2000 Dodge Caravan
How to replace blower motor system pack on 2001 chevy malibu
first, remove the lower right dash insulator panel from below glove box. slide bcm aside for access to blower motor.(slide to right). remove 3 screws from blower housing, pull blower motor and fan straight down. if putting in a new motor, use cage from old blower. the resistor for fan speeds is located beside motor. good-luck!!
Jul 29, 2010 | 2001 Chevrolet Malibu
Where is the blower motor resistor in a 2001 dodge caravan se. I do not see it behind the glove box. I do see soemthing similar under the hood on the passenger side aginst the firewall but it is not...
Caravan, Grand Voyager, Town and Country, Voyager, 2000-2004
Blower Motor - Removal & Installation
  1. Disconnect and isolate the negative battery cable, then wait 2 minutes before proceeding with the removal. This will effectively disable the air bag system preventing possible personal injury.
  2. Remove the glove box from the instrument panel.
    Fig. The blower motor is located behind the glovebox, behind the blower motor cover
  3. Remove the A/C-heater blower motor cover.
  4. Disconnect the blower motor wiring connector.
  5. Remove the blower motor wiring grommet and feed the wiring through the blower motor housing.
  6. Remove the blower motor mounting screws.
    Fig. Once the cover is removed, unplug the electrical connector and push it through the opening in the housing
    Fig. The blower motor is secured to the housing with three small screws
  7. Allow the blower motor assembly to drop downward to clear the instrument panel and remove from vehicle.
To install:
  1. Place the blower motor assembly into position on the A/C-heater unit and tighten the mounting screws.
  2. Route the blower motor wiring through the blower motor housing and seat the wiring grommet in the hole of the blower motor housing.
  3. Reconnect the blower motor electrical connector.
  4. Install the A/C-heater blower motor cover.
  5. Install the glove box into the instrument panel.
Auxiliary Heater and Air Conditioner
To install:
Hope helps (remember rated this).
Jul 11, 2010 | 2001 Dodge Grand Caravan
How to install a front blower motor in a 96 ford explorer
Blower Motor - REMOVAL & INSTALLATION
(see Figures 1 and 2)
Fig. 1: Exploded view of the blower motor mounting
Fig. 2: Exploded view of the blower motor and wheel (fan) assembly
Without Air Conditioning
  1. Disconnect the negative battery cable.
  2. Remove the air cleaner or air inlet duct, as necessary.
  3. If necessary, Remove the speed control module and the washer fluid reservoir.
Fig. 3: To remove the blower motor, first disconnect the electrical wire harness plug...
Fig. 4: ...then remove the blower motor cooling tube from the motor
  1. Disconnect the wire harness connector from the blower motor by pushing down on the connector tabs and pulling the connector off of the motor.
  2. Disconnect the blower motor cooling tube at the blower motor.
Fig. 5: Remove the blower motor attaching screws and the washer fluid reservoir...
Fig. 6: ...then slide the blower motor from the housing. Take care to not damage the blower wheel (arrow)
  1. Remove the 2 screws attaching the blower motor and wheel to the heater blower assembly.
  2. Holding the cooling tube aside, pull the blower motor and wheel from the heater blower assembly and remove it from the vehicle.
  3. Remove the blower wheel push-nut and/or clamp from the motor shaft and pull the blower wheel from the motor shaft.
To install:
  1. Install the blower wheel on the blower motor shaft.
  2. Install the hub clamp and/or push-nut.
  3. Holding the cooling tube aside, position the blower motor and wheel on the heater blower assembly and install the 2 attaching screws.
  4. Connect the blower motor cooling tube and the wire harness connector.
  5. Install the vacuum reservoir on the hoses with the 1 screws.
  6. If removed, install the speed control module and the washer fluid reservoir.
  7. Install the air cleaner or air inlet duct, as necessary.
  8. Connect the negative battery cable and check the system for proper operation.
With Air Conditioning
  2. In the engine compartment, disconnect the wire harness from the motor by pushing down on the tab while pulling the connection off at the motor.
  3. Remove the air cleaner or air inlet duct, as necessary.
  4. If necessary, remove the solenoid box cover retaining bolts and the solenoid box cover.
  5. Disconnect the blower motor cooling tube from the blower motor.
  6. Remove the blower motor mounting plate attaching screws and remove the motor and wheel assembly from the evaporator assembly blower motor housing.
  7. Remove the blower motor hub clamp from the motor shaft and pull the blower wheel from the shaft.
To install:
  1. Install the blower motor wheel on the blower motor shaft and install a new hub clamp.
  2. Install a new motor mounting seal on the blower housing before installing the blower motor.
  3. Position the blower motor and wheel assembly in the blower housing and install the attaching screws.
  4. Connect the blower motor cooling tube.
  5. Connect the electrical wire harness hard shell connector to the blower motor by pushing into place.
  6. If removed, position the solenoid box cover into place and install the 2 retaining screws.
  8. Connect the negative battery cable and check the blower motor in all speeds for proper operation.
Hope this help (remember comment and rated this).
Apr 23, 2010 | 1996 Ford Explorer
2002 Chevy Impala Blower resistor location
It is on the passenger side, you have to remove the black plastic kick plate, below the glove box, to expose it (held in place with 2 latches and 1 push pin). The resistor is in front of the blower motor ( sandwiched between the motor housing and the firewall) it is tricky to get to, i think when i changed mine i didnt replace all the screws as they were difficult to remove and even harder to replace. Good Luck, Mike
Mar 30, 2009 | 2002 Chevrolet Impala
PREVIA 1992 NO HEAT
If you have 150k on it, you may need all three. Run the engine, turn on heater, and get out and slam the hood a couple of times. In extreme cold or hot weather, this may get you by for a few days. I went 3 or 4 months with a bad blower by doing this, when the brushes inside the motor went bad. If it does not work, your blower is probably bad. The switch can have bad contacts, and you may try moving or holding it vertically to see if you can get any activity out of it. Put a resistor in too, if you have to replace the blower motor.
Mar 28, 2009 | 1991 Toyota Previa
Heating & Cooling Logo
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
