I have the hybrinetics dmc 3 fan control + light dimmer in a 2 gang set-up (that is this one, plus another switch control the fan). I need to first get rid of the other switch, so that I have a 1 gang system, with only the hybrinetics.
Then I need to replace the Hybrinetics DMC 3 with a newer fan control + light dimmer from Leviton.
So, I am looking for a wiring diagram that I can use. The current set-up is a complete mess, because the wires weren't used in the correct manner per color-coding.
I had an ETC Unison DR rack with house lights and spot lights, wall controls and a DMX input dimmer...
(More)
I had an ETC Unison DR rack with house lights and spot lights, wall controls and a DMX input dimmer system but it broek down. So now I'm looking for a new dimmer system. What I', looking for is:
- 2 or 4 chan
- dmx in and out or through (I can work with whatever connectors, 3/5 pin etc)
- each chan able to handle a S4 with 575W lamp
- Pack able to handle all lights all the way on.
Any recommendations on approach or specific packs or brands (or packs/brands to avoid)?
I have installed a 3-way Lutron Maestro Duo (600w) and the control dimmer broke. I ordered a...
(More)
I have installed a 3-way Lutron Maestro Duo (600w) and the control dimmer broke. I ordered a replacement but when I received it the package said it was a "single pole" dimmer. Can I install this or do I have to order a 3-way control dimmer. If so, does someone sell just the control dimmer and not the slave? Thanks, Mark
i need instructions on how to install a 3 way lutron dimmer switch to an exhaust fan motor that will...
(More)
i need instructions on how to install a 3 way lutron dimmer switch to an exhaust fan motor that will be plugged into an electrical outlet
we bought a home with a pass seymour dimmer switch in the dining room for an ceiling fixture over...
(More)
we bought a home with a pass seymour dimmer switch in the dining room for an ceiling fixture over the table. It was supposed to be a three way operation with a switch at one side of the dining room and the dimmer at the other end. Can the pass seymour dimmer act as a part of a three way operation?
