32" technika sky red eye picture is perfect remote works perfect but after 10 to 15 mins picture flicks of for a second then on again this happens randomly . Red eye works fine have installed loads of these red eyes an never a problem. Checked end at coax ok changed coax problem still happening. Try old style tv working fine. Noticed on back of tv were red eye goes in 5volts DC never seen this on any previous TVs when fitting. Sky rf outlet 9 volts could this b causing my problem. Can't think of anything else. Fitted dozens of these red eyes never had this problem only problems I've had have been with tesco technika TVs no mater wat I did picture bad on portable tv spoke to an independent repair shop told me problem said it simple wont get a good picture because tv is cheap think he's right .............
    New Friend:
Log in new account
Posted on Jul 31, 2013
3 Suggested Answers
  • 65 Answers
SOURCE: Sharp Aquos 32
Sounds like one of three things:
1) Mainboard/Tuner problems - although I'm really only saying this because you guys seem to think its associated with your over the air channels.
<br>
2) Power board problems. You power board/inverter may be damaged in some way - blown capacitor or other malfunctions. This is very possible as this could result in the backlight turning off and the screen going black but keeping the keeping the sound. If this is the problem, it will at some time start to happen constantly. Have a pro open it up and look at the power board.
3) The backlight is defective/dying. The backlight is a set of lights that reflects through the LCD panel. If the screen looks black, but you might see a faint picture or you still hear sound, then the backlight is not on. The panel itself could be defective. You can fix it by replacing the whole LCD panel (expensive), replacing the backlight panel itself (need a busted LCD of the same size with a working backlight), or fix the backlight, which is tough and risky.
Most likely its either the power board or backlight. Either way, you need someone to open up the TV and take a look inside. Good luck! Hope it works out.
Posted on Aug 14, 2009
SOURCE: LG 26 inch lcd. Recently it loses the signal from sky remote eye
hi! maybe there is a problem on power supply section or loose connection.
Posted on Sep 01, 2009
Sky Magic Eye not working over SLX 8 way booster/spliter
have you got it set on second out put on the sky box as number one is just normal. all cables have to be set to second output using a splitter box . so its like this.
arial in booster.
out booster to sky box.
out to tv/etc on first output on sky box.
second out put to spliter linc. ( eg 4 rooms out four way splitter)
each room with sky eye fitted to end of the aerial from number feed from sky box.
with each room with Eye sky can be controlled
also check that RF outlet power supply is set on sky+ or HD in settings menu.
access this.
settings
select ( remote)
type 01 (select on remote)
RF outlets.
RF outlet Power Supply ON
RF channel 25 ( is best for most areas)
Feb 01, 2014 | Televison & Video
Sky eye red light on but remote won't work
You are using the new remote and not the old Sky remote aren't you
Oct 12, 2017 | Televison & Video
Technika lcd 32-270 sky remote code
sky/sky +/sky+ HD remote code - 2134 (revision 9 or later only)
worked on mine which i just bought today 01/11/2011
Feb 13, 2011 | Televison & Video
I need a code for my sky remote for my sanyo tv in order to get the volume working It is a sanyo 32" Model CE32LD33-B-01
with the tv on and sky off, press red button & select together, remote blinks twice.press tv then standby repeat this action until the tv turns off. when it goes off press select. press standby again and tv should start. your sky remote should then work perfect. as a tip with tv on and sky off press tv then back up this should then go to the freeview setup and you can watch those as well for free
Sep 09, 2010 | Sanyo Televison & Video
Cannot get my sky guide to respond on my Loewe Articos 32,i think the kids have scrambled the tv remote! Any ideas?
There are several things that can stop your Sky remote from working.
step one:
get a mobile that has a camera on it. point the remote at the camera and press the TV guide button on the remote you should see a little light by looking through your camera. This is because cameras dont like infrared
if you see the light whilest looking from the camera phone then the remote is working.
Step 2:
There can interfearance from devices like WII's or if your television has a back light you can turn this down and see if this is going to make any difference to the sky box.
If it does you know what is casuing the problem.
Step 3:
There may be another solution to your problem. Go onto Ebay and type in there Magic eye. you can get them from Argos but you will be paying 3 times if not more then you can get them off ebay.
once you've got the magic eye. plug this into the back of your sky box into RF OUT 2 this must be in 2 due to it providing 9v to the eye.
on your sky remote press services, 4, 0 1 select. go to Rf setting and turn this option to ON and then go down to save. you should see a little red light on the magic eye come on this is all done.
Now try your remote as normal.
I fit sky and a lot of the HD sky+ boxes have rubbish IR (infrared) so this sorts out a lot of problems.
Hope this helps
Little Dish Fitter
Sep 01, 2009 | Loewe ARC332 32" TV
Sep 01, 2009 | LG 26LG30 26 in. LCD TV
Technika sky code volume needed 42-502
0246 is the code 1st cover the top of the remote with your hand press TV you can now move your hand, now press and hold select and the red button togeather the remote light will flash twice enter the code 0246 then press select cover top again and press SKY button it should now control your tv
Jun 03, 2009 | RCA DIRECTV Satellite Remote Control
Stopped receiving sky on second tv - does my samsung need a reset
I install a lot of magic eyes etc.
You have checked that the magic eye lights up when it is connected directly into the sky box. So your eye is working correctly.
the next step I would take is with your sky remote in your main room. press SERVICES, 4, 0,1, SELECT go to RF settings and check the rf channel and make sure the power is on. Take a mental note of the channel number.
Now go into the room where the link is feeding. Turn on the TV and go to channel number 6 press your MENU button and then go down to setup. go across to manual install and then down to the channel number type in what you retrieved from you box ie rf channel and then type it in and STORE.
If you go into your main room and just put the normal tv guide on ie blue screen. then check that your getting the sky into the other room. IF you are then great it just needed tuning in. IF not I would remake the coax connectors. as there may be a bit of copper braid touching the centre core. once this is done your sky should be on all you need to do now is put the eye back on. Once you have done this the red light should appear on your magic eye. if not go to your main box and follow the first instructions I gave you and turn the power off on the RF and then save and then go back in and turn it back on and save.
Hope this sorts out your problem
Cheers
Little Dish Fitter
Feb 27, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
TV REMOTE CONTROL NOT WORKING
1. Turn your TV on.
2. Press tv on your Sky remote control.
3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
4. Press tv on your Sky remote control again.
5. Key in the four digit code for your brand of TV. The light on the Sky remote control blinks twice. If the light blinks once only, recheck the code for your brand of TV and start again at Step 1.
6. Press the standby button on your Sky remote control. If your TV switches off, press select. The light on the Sky remote control blinks twice (code stored). If your TV does not switch off, press tv, then press the standby button. Repeat this (press tv, then standby) until your TV turns off, then press select (stores code).
If at this point the LED on the Sky remote control blinks three times then all possible codes for that make of receiver have been checked. Repeat from step one, ensuring that you enter the correct manufacturer code.
At the end of the sequence, if you see the TV Guide screen, the remote control setup process is complete. If you did not see the TV Guide screen, you must now complete the following steps.
8. Press tv on your Sky remote control.
9. Hold down select and the green button together for about two seconds, until the red light on the Sky remote control blinks twice.
10. Key in the number of the channel on your TV that you use for watching satellite TV.
11. Press select on your Sky remote control. The red light blinks twice. The remote control setup process is complete.
Oct 17, 2008 | Philips HDD065 MP3 Player
Televison & Video Logo
69 people viewed this question
Top Televison & Video Experts
