Question about RaidMax Computers & Internet
I got my Raidmax RX-735AP 735W ATX 12V today. When I plugged it in, the fan LED didn't turn on and the fan didn't spin. It wasn't plugged to the motherboard or anything. I just wanted to test it out. Will it work when everything is plugged in or is it a DOA?
  • 102 Answers
All new power supplies have a voltage sensing circuit. they need to have a load on them to start.
Posted on Oct 16, 2013
5 Suggested Answers
sparky1500
  • 1066 Answers
SOURCE: 3 pin female adapter on the ATX-1956f which was
leave it unplugged
Posted on Dec 28, 2009
JaxPlanet
  • 922 Answers
SOURCE: Dell ATX(12v) power supply
The fact that it is made by Dell is irrelivent.
ATX is a standard and so are 20 and 24 pin motheroboard connectors.
You should find what you need by searching for: power supply unit on Wikipedia and Google.
Posted on Apr 08, 2010
cyberfast
  • 155 Answers
SOURCE: Di I need a special device to test a Raidmax 12v
a volt a meter
Posted on Dec 27, 2010
  • 31 Answers
SOURCE: BST ATX - 250 - 12Z C7R it is a HP compaq 2290
Does your motherboard have a beeper? Does it emit any distinguished beeps?
First, to locate the problem, try to boot your system with only a bare minimum of components: motherboard, cpu, ram, videocard. Try your system with a known to be good power supply. Then, if possible, try it with other known to be good components. If possible, check power supply with a psu tester or multimeter (that takes some time). Every bit of description of system behaviour will be helpful.
Posted on Feb 22, 2011
Installed a GA H55M USB3 motherboard in a Raidmax Tornado case. When I go to turn it on their is power for about for about a 1sec and the fans turn a couple of times and a couple of seconds later their is...
I once had something similar happen to me. Triple check to see that all connections are secure to the motherboard - a loose 20 pin ATX cable was the culprit in my case.
Hope that helps. Good luck!
Dec 09, 2010 | RaidMax Tornado ATX238WRP Black SECC Steel...
920-fan command 2 pin connector from power supply not connected I have replace my power supply..but my new power supply didnt have the 2 pin..
Well thats not good, however if you can identify the Positive, usually RED, and Negative, usually BLACK. on the Fan, You can actually carefully insert the bared wire into a spare drive power connector, fans are all 12 V. You can use the YELLOW.. +12V & the alongside BLACK - 0V. This will power your fan. BE CAREFUL doing this. Once inserted use a piece of tape to secure the wires and fold them back against the Plug and secure. You may be able to buy a converter that plugs into that power connector & the fan?
Feb 22, 2010 | HP Compaq d530 SFF PC Desktop
Raidmax Sirius case not turning on
Recheck the wiring. Make sure the fans are all plugged into the proper place. Then try reseating the RAM, video card, & cpu. Make sure you have applied a good thermal paste between cpu & heatsink as overheating can cause the system not to boot. Hope this helps & please remember to rate my answer. Thanks.
Dec 28, 2008 | RaidMax SIRIUS (ATX-701WS) ATX Mid-Tower...
Raidmax 500w power slowly died, then wont turn back on.
1.-Your CPU fan is working?
2.-Your Power supply fan is working?
If not and following your description I think that you have to replace your power supply.
If you have the light on in the motherboard doesn't mean that your power supply is good.
Check the first to points above and if 1 and 2 are not working
Replace your power supply.
Let me know how it is going!
Thank you for using FIXYA!
Don't forget to rate my help
Pablo :-)
Oct 13, 2008 | RaidMax (ATX-612WBP) ATX Mid-Tower Case
I broke my temp probe on my raidmax
if by the probe you understand front fan controller,yes,there are controlers to replace yours..just pay attention to fit in the bay..
Jan 21, 2008 | RaidMax SIRIUS (ATX-701WS) ATX Mid-Tower...
CPU fan not turning with ATX 12V connector plugged in
With the fans on its drawing more than the PSU has.The PSU is bad. Replace it. If it still happens please let us know...It shouldnt.
Jan 06, 2008 | EliteGroup P4IBMS Motherboard
Raidmax fan+light
Fans are such a low cost item I would replace the fan or fans and take the troubleshooting from there.
Fans can be prurchased from www.newegg.com or best buy ETC..
Dec 07, 2007 | RaidMax NINJA 918 ATX Case
Red Light instead of a Blue one
I've seen this before. The power LED needs to be replaced. If you have the sales receipt, Raidmax will replace it. This won't affect any other part of your PC, so if you don't get it replaced, it's not the end of the world. =)
Jun 08, 2007 | RaidMax NINJA 918 ATX Case
Computers & Internet Logo
230 people viewed this question
Top RaidMax Computers & Internet Experts
David Payne
David Payne
Are you a RaidMax Computer and Internet Expert? Answer questions, earn points and help others
