My up laptop. Won't stay on when I press the power on button the the lights flash. Then it shuts down. Please help
    New Friend:
When i power on the green lite shows power but the screen stay on the infotmic
Posted on Jul 31, 2013
vincebeach
  • 37 Answers
SOURCE: Dell XPS M140 laptop shuts off after powering on
Most laptops that I have worked on that power off that quickly turned out to be an overheating problem. Is the cooling fan running for the brief period that you can hear the hard drive before it powers off ? If the fan is running another potential resolution might be to remove the processor and apply new thermal paste.
Posted on Nov 11, 2008
Clockwire
  • 72 Answers
SOURCE: dell inspiron 5160 wont start
It sounds to me like your Laptop over heated... I cannot be for sure But I would get your Motherboard check because it sounds like its shot.
Posted on Mar 18, 2009
  • 104 Answers
SOURCE: laptop not powering on
the power IC on the mainboard is damaged. maxim 8724e or any mosfet around that. u hve to change the main board or send to pro for repair. davidco18@yahoo.com
Posted on Jun 09, 2009
Shereena_M
  • 601 Answers
SOURCE: dell d400
Take the battery out and press the power button for 30 sec and connect the power cord and reboot.
This should work fix it else the issue seem to be with motherboard.
Thanks
Kindly rate the answer
Smith
Posted on Jul 09, 2009
Damilare
  • 358 Answers
SOURCE: LG x110 laptop power supply problem:
To be very sure of what the problem is, try to test the your laptop with a another friend's battery, or through a technician first. If it powers, then try and test the laptop again with another AC Adapter, from someone who uses the same type, or a technician.
Trying out these two things will give you a clearer and better idea of what might have gone wrong.
Hope it helps you out.
Posted on Jul 13, 2009
Why is my laptop screen black during startup?
I recommend you to connect an external monitor and check if there is display on it. Press 'Windows' + 'P' on the key board to get display on the external monitor.
I also suggest you to run diagnostics on display. To test the display shut the system down, next press and hold the letter 'D' on the keyboard and press the power button. This will initiate diagnostics on the display. Please check if the colors are displayed across the screen without a problem.
You may also try this step that is shut the system down, remove the battery and disconnect the ac adapter, press and hold the power button for 20 to 30 seconds. Now connect only the ac adapter and wait for 30 seconds , press and hold the Fn key on the keyboard and power on the system. This will run diagnostics on the hardware components and also the display.
check also:
Please let me know if there is any light on the keys shows below:
5557.led-status.png-
if any of these are flashing in a sequence
please reply back with results
Jun 08, 2014 | Dell Latitude E5500 Laptop
Laptop wont boot up, black screen, has power
You didn't post the Make, Model of Laptop or the OS you are using. I'll use a Win 7 solution. Boot the Laptop, open the Control Panel, select Power Options, set to High Performance, select Change Plan Settings, set SLEEP to Never, select Change Advanced Power settings, go through the settings , set SLEEP and Hibernate to Never, Power buttons and Lid to shut down. Always shut down and unplug your laptop when not in use to prevent damage from power surges and possible Fire hazard IF the battery malfunctions. A reboot every day will reset the computer.
Apr 21, 2013 | Computers & Internet
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
Gateway M-6862 laptop will not turn on; battery light flashing re
Seems to be a problem of not enough power.
First check the voltage output of the charger(adapter) and match it with its specs.
Also try to reset the hardware using the following steps:
1 Disconnect battery and the charger
2 Let it sit for 1-2 minutes.
3 Press and hold down the power button for 30 seconds.
4 Reconnect battery and charger and try to start by pressing the power button.
Mar 07, 2010 | Gateway Computers & Internet
I have an extensa 5420-5687. 1 day my laptop just
the power cord has shorted out you will need to buy a new one
If I have helped you please click the yes this was helpful button
Dec 03, 2009 | Acer Extensa 5420-5687 Notebook
Shut down computer but some lights stay on
Your are not "shutting down" the laptop. It is going into "Stand-by" mode.
#1:
When you want to shut down,
select [Start]
then select "Shut down" and not "Stand-by"
The power button will also work.
#2:
Press the power button and nothing else.
The laptop will log you OFF and "shut down"
Nov 08, 2009 | Toshiba Satellite A135-S2386 Notebook
Power button failure
  • Power Light Shuts Off
    If the power shuts off during game play (even as much as 30 minutes after the system is turned on), then turns off and won't turn back on or the fan isn't working, the system needs repair.
  • Power Light Flashes
    If the power light flashes once when power button is pressed, then turns off and won't turn back on, the system needs repair
  • Sep 11, 2008 | Nintendo GameCube Console
    Compaq presario 700 no picture
    u just try for the buttons in the down of ur pc or may be at the sides..............just press it an enter the menu for adjustments...........there will be an option called DEGUASS just press it once.......ur pc's screen will shake for a while and then stops.........then u will get an clear display.or press F8 and change the settings.
    Sep 08, 2008 | Compaq Presario 700 470024-192 Notebook
    The hp altec lansing laptop wont turn on, you press the power button and you get this flashing electric looking icon that comes on and it's pluged into the wall. what could be the problem?
    my hp altec lansing laptop doesn't opwer on, the button lights up for 1 second and then shuts down,nothing happens to the screen, it stays blank
    Aug 27, 2008 | Sony VAIO R505JL Notebook
    Laptop power light is on, wont shut off and screen is blck
    You could shut down your by forced shut down. to do this, press and hold the power button for 5 seconds, during which a long beep is heard. The system will shut down.
    Try reinstalling the operating system to resolve this problem
    May 13, 2008 | Dell Latitude D600 Notebook
    Computers & Internet Logo
    David Payne
    David Payne
