Question about Acer Aspire One PC Notebook
My screen is hung on a game....can't close it or restart the computer.
    New Friend:
Try removing the battery and restarting :)
Posted on Jul 31, 2013
When playing a game like candy crush saga it opens and starts to play then closes back to main screen?
I would uninstall it then shut down the tablet & restart it then reinstall the game you may have had a iffy update
Jul 22, 2014 | Samsung Galaxy Note 10.1 N8000 Black...
Tip
Laptop or computer restarts or reboots for no reason?
If your laptop or computer restarts for no appartent reason, the most common culprit is overheating. Take the following steps to address the problem:
1) Download and install CPUID's Hardware Monitor (it's free). Download from http://www.cpuid.com/hwmonitor.php, install and run at startup. Check for overheating especially when running 3d or online games.
2) Clean up the dust and lint often, at the very least once a month. Remove the laptop or computer cover, vacuum or blow compressed air all over the motherboard, expecially around the fan(s), CPU and GPU (video card).
If overheating is not the problem, you can check if a particular software or driver is causing the hung-up. Your best bet is to check the Event Viewer. To run the event viewer, folow the following steps:
A) Click start -> control panel -> performance and maintenance -> administrative Tools. Then click on the Computer Management.
B) In the console tree, click Event Viewer.
C) Click on "application errors". Any commands or errors just before the "Winlogon" will be the last commands before a restart (Winlogon is run only when the computer restarts). Check the error history to see if the same command is the conistently causing the hung-ups
Hope this helps ya'all
Alex
on Mar 19, 2010 | Computers & Internet
How do i unfreeze my scrabble game
Programs occasionally freeze-up and become unresponsive because an error takes place that can't be handled. Unfortunately, the only solution is usually just to close the window, which means losing your game session.
Click the X button on the top right-hand side of the window to close the window. If it does not close on its own, you'll need to restart your computer. Click the Start button, then click on Restart. Once your computer is back up and running, try playing your game again.
Jun 10, 2014 | Microsoft Windows XP Professional for PC
Hp 4250(on a network) is hung up on processing job. I restarted the print spool and physically restarted the printer put the problem still exists.what should i do
you may need to turn off your print services on your pc. pull up the printer que on the pc. delete the jobs in the que. right click my computer. go to mange. go to services and applications .go 2 services. double left click. look for print spooler. right click. choose stop. then go to printer and reset job. turn off printer. turn on printer. restart your print spooler. close all windows and try to print
Jan 07, 2011 | HP LaserJet 4250n Printer
I WANT TO ASK ABOUT A PROBLEM WITH MY SYSTEM
1. Click Start, Right click computer and click properties.
2. Click advance system settings, click advance tab and click the settings button under startup and repair.
3. Uncheck automatically restart under system failure.
4. Please provide us the error code, eg: 0x0000000 if the Blue Screen reoccurs.
5. Run hardware diagnostics for possible hardware issue.
6. Run "Chkdsk /r" under command promt and restart pc after scheduling it.
7. Run "sfc /scannow" under command prompt after the computer restarts.
8. Update your system drivers by going to your OEMs website.
Jan 20, 2010 | Computers & Internet
Vista hangs on restart at end of sp2 upgrade
Take advantage of Microsofts offer to go to Windows 7. You will solve this one problem now only to encounter more later.
Jan 09, 2010 | Lenovo ThinkPad T500
After installing WinXP SP3 in my laptop it did not starts normaly
Start in safe mode,Click start,Run,Type msconfig,and on the first screen choose startup normally,click apply or ok and it will restart the computer
Jul 22, 2009 | Acer Aspire 3680 Laptop
New z2400 will not print a page (worked fine for the last couple of days), pop ups state in process of printing 2 pages, printer is diconnected and power off, but unable to delete printing process on the...
This may help you
How to force delete print jobs Fortunately, there is a way to delete the hung print job without having to save all your work, close all your applications, and restart your computer. Here's how (note that this is intended for Windows XP systems, but a similar approach works on other systems - if this doesn't work for you reply below with your Operating System and version):
  • Browse to Start -> Run... and type in "NET STOP SPOOLER" (this will stop the print spooler service)
  • Browse to your windows\system32\spool\PRINTERS\ folder
  • You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
  • Browse to Start -> Run... and type in "NET START SPOOLER" (this will restart the print spooler service)
  • Double click the printer icon in the lower-right corner of your taskbar to examine your print job queue and browse to View -> Refresh.
Voila :) You should see that annoying hung print job finally disappear completely and you should now be able to resume printing without having to restart your computer.
From http://community.contractwebdevelopment.com/how-delete-or-cancel-hung-print-jobs-windows
Dec 12, 2008 | Lexmark Office Equipment & Supplies
Nintendo wii
Looks like you may have a brick. You could send it back to nintendo.
Jun 22, 2008 | Nintendo Wii Console
Acer Aspire One  PC Notebook Logo
13 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
