Question about E-Machines eMachines Desktop PC
Power_LED Buzzer on Mainboard continues to beep every 3 seconds fans are operating but system doesn't boot or show nothing on monitor(which is ok)
    Scholar:
  • 36 Answers
Well you didn't say what the beep code was, is it just one beep every three seconds? Or is there long beeps, short beeps, and long and short time between them before they repeat?
If it is one, beep, every three seconds and the beep is one second long, there is a problem with a connection somewhere. Typically it happens in older computers that are in dusty environments. You can try to (only if your comfortable with how to do it) unplug the memory modules from the motherboard and keep track which socket which is plugged into, and mix them up so they are in different slots from their original positions, then try to reboot.
If that does not work and there is no display at all (even POST information) it could be a bad card (modem, sound, video, etc.) remove all but the video cards and try a boot again, if you can boot then plug only one card in each time you try to boot and when you find the offender replace it with a new one (that is if you use that card, if it is a modem and you do not use dial up internet you do not need the modem card plugged in.
But one, one second long beep every three seconds typically means there is a connector problem somewhere, if the computer is older carefully clean out the dust and unplug and re-seat all of the connectors and hopefully that will solve your problem
Posted on Nov 17, 2013
SOURCE: booting problem
I CONNECT MY H.D.D WITH MOTHERBOARD BUT THAT CAN'T BE DETECTED
Posted on May 21, 2008
edrich629
  • 30 Answers
SOURCE: Unit will not Boot up
a long beep? what?
be specific!! so we can help
Posted on Jul 07, 2008
mumma_1
  • 903 Answers
SOURCE: 3 beeps wont boot
it is probably a ram error,
Unplug the computer and unclip the ram and remove it, clean the ram sticks and the slot that it goes into with a small dry paintbrush. While you have the unit open clean the dust away with a small paintbrush and a hoover at the ready. If you have more than one ram stick, replace one at a time to determine if you have a problem with both or one. If it boots with one, then shut down remove plug from wall socket and then replace the other one too. If it works okay then fine, if it causes problems then you know that the other stick is bad. If it does not boot on replacing first stick, then remove it and put the other stick in and try again.
I hope this helps
Posted on Nov 15, 2008
  • 62 Answers
SOURCE: old emachine T2642 will not
It sounds like a dead motherboard. Try removing the CMOS(BIOS) battery and replacing it. Then try removing and replacing the CPU as well. If you get the same result then you might be looking at replacing the motherboard.
Regards
Posted on Dec 20, 2008
  • 508 Answers
SOURCE: BUZZER GOES OFF ON POWER START WITH 3 SECOND PAUSE
Should be no beeps or buzzes when you first fire up your computer, if you do have any then something is wrong on the inside, could be a loose connection or the hard drive connection, I would suggest that you call e machines tech support and talk to them, while it doesn't sound to serious a fix i don't use your brand of computer so i don't want to say much about it, if your up to it then open up the computer and disconnect then reconnect the wires to your hard drives floppy drives and CD players and see if this does anything, also note that if you do this, do one at a time so this way you know what was causing the problem. Hope this helps
Posted on May 10, 2010
D845GVAD2 no bios screen no beep no boot
Hello here is the intel homepage:
https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+845+Chipset+Family+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+D845GVAD2
Try to renew the power supply, with one you know is working.
I think that`s the problem.
The problem could ofcourse also be the mainboard itselves failing.
There is not much to do about that, other than renew the mainboard or buy a new pc.
Good luck
Apr 08, 2013 | Intel D845GVSR Motherboard
The green LED light on the board is lighted. When I push on/off button the CPU fan moves for 1/2 a second .I tried a different power supply, but that did not work. I replaced the CPU fan, but that did not...
Hello here is the homepage:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+3+Series+Chipset+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+DG31PR
Any abnormal beeps at startup ???
http://www.computerhope.com/beep.htm
The problem could be a ram module failing, or the graphic card if installed on the mainboard.
Or a short circuit somewhere.
Look also here:
http://www.tomshardware.co.uk/forum/243625-13-turns-wont-boot
Try starting with only 1 stick of Ram, the monitor and the keyboard connected, no other USBs to be connected.
Look also for bad caps on the mainboard:
If they look like this, the mainboard is dead.
It does not pay, to let them be changed.
Good luck
Jan 28, 2013 | Intel DG31PR Motherboard
Alienware Area-51 Desktop PC No Video. Long Beep.
you my have a power problem,the beeping is a sign that your graphics card is not getting enough power ,check your power cord to your card .
have you upgrade any hardware in your pc.
try cleaning your fan they get loaded with dust or you may have to replace your fan.
hope this helps
Sep 21, 2012 | Alienware PC Systems Alienware Area-51®...
Dell inspiron 530 desktop won't boot, fan is running, no signal on monitor
It sounds like either your monitor or video card inside the computer is bad.
If the monitor is showing the "No Input Signal" message then the video card inside the computer is bad. The monitor is ok otherwise it would not be able to display the No Input Signal message.
When you plug in the power cord is there any lights whatsoever on the laptop, where the plug goes in or on the AC Adapter of the power cord?
When you press the power button do you hear fans running, hard drive spinning, lights on the computer, hear any beeps or lights constantly blinking, hear the DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the computer is trying to boot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the laptop and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous. Most times the problem is with the memory or Video Card. Count the Blinking Lights or Beeps and take note of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe you have a Static Charge Buildup. Remove the Power Cord, then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in and hit the power button to see if it boots.
Maybe your memory is bad or the memory slot is bad.
Remove the Power Cord, Open the Case and remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
Jun 06, 2012 | Dell Inspiron 530 Desktop Computer
My HP Pavilion dv9740us Notebook PC dosent start the screen is black
Doesn't start as in nothing happens when you hit the power button? Or are you saying the Desktop is black, but it seems like windows started and went through the boot process?
If nothing happens when you hit the power button:
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
Apr 20, 2012 | Computers & Internet
Blank screen
Did it boot all the way? Do you hear the fan running, disk drive spinning? If it sounds like it booted but the display is black, try this:
When you press the power button do you hear fansrunning, hard drive spinning, lights on the computer, hear any beeps or lightsconstantly blinking, hear the DvD/CD drive click and the light on the drawer ofthe DvD/CD turn on for a second or two? If so the laptop is trying toboot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Apr 14, 2012 | Computers & Internet
My 915-m5 mb starts but have no video. No sound except for fans and hd are noted, but no signal video is seen in monitor. Please answer to joitod@coqui.net at your earliest convenience. Thanks
do you get a single beep about 2 to 5 seconds after the system is powered up..? If no, then your mainboard IS NOT working. The fans and hard drives will still spin up even if the mainboard is not booting. You need to listen for that single beep as this tells you that the boards POST (power on self test) has completed and all is well. If it does not beep, then you have a mainboard issue. Reply to this and tell us if you hear this beep or not..
Jan 14, 2010 | EliteGroup 915-M5 Motherboard
LAPTOP, HP, PRESS POWER BUTTON, IT STARTS IT BOOT SEQUENCE, THEN 26 TO 27 SECONDS INTO IT, IT SHUTS DOWN MOMENTAIRLY AND RESTARTS IT BOOT SEQUENCE... NO MONITOR VIDEO, HEARING NO POST BEEPS, AND WILL...
it could be any of the two. problem with your power supply section and mainboard. the reason it shut down repeatedly, is the unstable supply of dc voltage on your laptop. try using another charger/adaptor.if the mainboard is the culprit. you have a serious problem. visit your local service center.
Jul 13, 2009 | Intel 430180-001 - HP Pavilion dv8200...
Ultra m923 mid-tower case won't stop beeping
The problem is the board on the case's display. It has temp alarms for your components(video card, hdd, cpu), there are temp probes for you to set so you can monitor these temps. However the board that controls these functions, or at least mine and many others I have read about, is defective. It will change display constantly and sometimes have garbage display. It is setting its own limits for what is considered a hi temperature. The limit it has set for one of your components is < room temperature so it thinks you are having an overheating problem. You can manually set the limit for overheat and it will fix it for a while, but it will prob happen again.
Jul 03, 2009 | Ultra Products Ultra M923 Full Tower ATX...
Make sure your monitor is plugged in and try again
Jul 07, 2008 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
69 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
