Evaporative cooler ac 120 g owners manual - Heating & Cooling
3 Suggested Answers
jas247
  • 844 Answers
SOURCE: Need an owners manual for
Welcome to FixYa.
Click >>HERE to download the manual. It opens in Acrobat (PDF). If you do not have an Acrobat Reader, you can download the Adobe Acrobat Reader from this link http://get.adobe.com/reader/
Thank you for using Fixya. Have a great day.
Jas247
Posted on Jul 17, 2011
  • 449 Answers
SOURCE: how is the labor cost for replacement of
cheaper to replace
Posted on Sep 03, 2010
What size room can a Hampton Bay HB 30 window evaporative cooler cool
I checked the owners manual and can find nothing about what area this cooler will service, however based on the size I doubt it will have any trouble with a small room like this.
May 20, 2016 | Hampton Bay Heating & Cooling
I have a Taiwan evaporated cooler, 120 vac 60 Hz 85 w. Does this unit cost a lot of electricity to run, or is it fairly energy efficient
evaporative coolers use a principle of blowing air though a filter that is water moist
the air passing through the water uses a heat exchange process as the water boils off, the air is cooled and so you get cooler air
very efficient in places where the humidity is under 80% but over that the water doesn't evaporate all that readily and so the effectiveness is reduced
basically the hotter the day and the lower the humidity the more efficient they are.
Cheap --yes as it only runs a small motor for the fan and an even smaller motor for the water pump, but you will need a regular water supply some units have a small tank which needs regular filling and others can be connected to the home water supply
it is not an air conditioner , simply an air cooler.
Jun 15, 2015 | Heating & Cooling
How to change the filter for vulcan evaporative cooler
I suppose you meant Vulcan Bonaire evaporative cooler.
By filter, I suppose you meant Filter Pads. Here is extract from the Owner's Manual.
Filter Pads: Visually check CELDEK pads for damage or blockage. Hose down pads from both sides to remove any build up of salts, dust and pollen. In dusty areas more regular
cleaning is recommended. Check the water distributor, making sure it is clear and free from blockage. Failure to do so may lead to uneven water distribution and therefore less efficient operation. Do not hose Celdek with high pressure.
Dec 21, 2013 | YouTube Videos
Owner manual onix evaporative cooler
The Onix (Sold at Coles) is identical to the Home Maker FSH-90R (Sold at K-Mart). You can download the Home Maker FSH-90R/Onix user manual at the address below; just search for FSH-90R in the manuals section option under cooling products.
http://www.tempoaustralia.com.au/onix-products/cooling/evaporative-air-cooler
Direct PDF link as of May 2013:
http://www.tempoaustralia.com.au/manuals/onix//Cooling/FSH-90R.pdf
Hope this helps.
Nov 14, 2011 | Heating & Cooling
Air evaporative cooler
The motor is over Amped and is cycling on the thermal overload protector. Make sure the original panels of the cooler are all in place for both inlet and outlets. if that is ok ensure that the voltage is adequate when the motor is running and drawing electricity. Most are not rated to run under 105 volts AC.
Jun 07, 2010 | Mastercool 67680 Evaporative Cooler Air...
User Manual
You should be able to to the information from this link
http://www.climatehouse.com.au/
Dec 12, 2009 | Mastercool 67471 Evaporative Cooler Air...
I need a wiring diagram for a mastercool evaporative cooler
Here is a link to the owners manual for the new Symphony brand evaporative cooler. Symphony is the new name for the old Adobeair brands Mastercools.
The owners manual will have the motor and pump wiring schematic.
Sep 03, 2009 | Mastercool 67471 Evaporative Cooler Air...
I need to install an evaporator core in 1997 xj6. Any tips or suggestions?
Ok , I will try to guide you as simple as I can :
1- Remove the Heater / Cooler unit this is how : * Disconnect Battery ground cable
* Recover AC gas or empty it in open space
* Drain radiator coolant only
* Remove instrument panel for access
* From under the hood disconnect AC pipes at the evaporator , by removing bolts , discarding O-Rings and make sure to install blanking plugs so that no dirt goes in.
* Disconnect heater hoses from heater matrix pipes , by releasing the spring band clips and make sure to blank the pipes
* From inside the car , remove driver footwell duct , by removing the screw and then removing the duct
* Remove upper steering column lower fixing , nuts and bolts
* Remove upper steering column upper fixings (Bolts) , and allow column to rest down o the floor
* Cut cable tie which secures console harness to LH blower duct
* Remove LH fan motor duct (screws)
* Remove passenger side footwell vent (nut)
* Cut cable tie securing console harness to RH blower duct.
* Remove RH fan motor duct (screws)
* Disconnect Heater/Cooler Connector
* Disconnect drain tubes from Heater/cooler assembly
* Disconnect A/CCM connectors
* Remove evaporator pipe support bracket fixing.
* Remove Heater/Cooler assembly fixing , by removing lower nut and upper nut
* Remove tape securing RH rear footwell intermediate duct joint. Remove duct to clear access
* Remove tape securing LH rear footwell duct
* Remove Heater/Cooler assembly from car.
2- Remove AC control module 3- Remove evaporator pipe seal plate 4- Disconnect heater tempreture sensor 5- Remove footwell servo motor from heater/cooler unit * Disconnect connector
* Remove screws
* Remove motor complete with bracket
6- Disconnect evaporator sensor connector * Detach heater/cooler connector
* Detach evaporator sensor connector
* disconnect connector
7- By now you can see one upper and one lower case * Remove heater/coolent unit upper case from lower case
* Remove screw
* Remove 15 clips
* Remove upper case from lower
8- Remove evaporator from case * Remove sensor and clip
You are done , make sure to replace all seals that you see to make sure that every thing is ok and you do not have any leaks after installation.
Installation : Reverse order and after installing make sure to do a pressure test to make sure that there are no leaks
Jul 12, 2009 | 1997 Jaguar XJ6
Nor-Lake walk-in cooler water leak
The evaporator drains into pan with a coil from the discharge line. The design is intented to sub-cool the liquid refrigertant as well as evaporate the condensation from the coil. Unfortunately the engineer started as career a shipping clerk and never received any further training.  There isn't enough heat or running time to evaporate the condensation from the coil.
The solution is fairly simple
A plastic tube  drains water out of the evaporator in the pan. You can extend the tube and add a defrost pan handled by your refrigeration wholesaler. Wire it so it is on whenever there is power to the unit.  This should get rid of the excess water. These pans are also used on some self contained coolers and freezers. They come in either 120 volts or 220 volts. kasgirls@tds.net
Jul 12, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Heating & Cooling Logo
35 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
