Question about Health & Beauty
My seca 862 scales are saying error 111 when switched on any one help please ????
4 Suggested Answers
reyjoshua07
  • 1157 Answers
SOURCE: Hi i have a Seca
Hi pethkars,
You may do the following to helps you solve the issue with the Error that you are getting:
1. Switch off the scale with the Start key and start the scale again. The scale will then
work normally again.
2. If this is not the case, disconnect the power supply by briefly removing the batteries.
If this measure is equally unsuccessful, the last option you have is to inform the Service department. This will require advance troubleshooting that only people from Seca can provide. You may reach them through this.
Hope this helps.
Thank you for using FixYa.
Posted on Sep 19, 2011
SOURCE: I have a Seca 703
This could be a power issue. Make sure your battery pack wire connections are good. If they are loose, I suggest purchasing the Seca 400 power adapter, which works with this model.
Posted on Jun 14, 2012
rickbrashear
  • 176 Answers
SOURCE: what to do if my weighing scale seca 220 appears error 10:12? i have restart the machine, but still the error appear
i repaired one that did not have batteries installed and ran on ac only the problem was in the power supply. it had a couple swollen capacitors they should be flat on top but bad when bulged out
Posted on Jul 08, 2012
Seca 769 error code e.10.11
showing error code " Seca 769 error code e.10.11" how can i solve this problem.pls help me.
Oct 07, 2013 | Seca 769 Digital Scale 400 Lb with Bmi and...
Error message
check where u put your machine that place should be well equally balance and check some point should the there backside of this for resetting the machine
Sep 20, 2013 | Seca 354 Dual Purpose Baby Scale
I have E10.11 code on Seca 869 scale what does it mean?
I have the same problem. I sent an email to the company and got no response, frustrating considering how much this scale costs for professional use. The manual says "Excessive weight has been applied in general or on one edge. Reduce load on scales or distribute weight more evenly. Restart scales."
I've done this, and it always starts with E10.11, making it unusable. If anyone has help or suggestions, please post.
Mar 12, 2013 | Seca 869 Portable Flat Scale W Cabled...
I have a Seca 703 digital scales, When I turn on it says Er:1:40 Can you help me?
Sep 18, 2011 | Seca 769 Digital Scale 400 Lb with Bmi and...
Seca 769 error code e.10.16
What does this code mean? How do I fix it?
Thank
Jun 03, 2010 | Seca 769 Digital Scale 400 Lb with Bmi and...
How to calibrate seca 354???please help me...
I don't know if the 354 can be calibrated.
Here are calibration instructions for the 374. It includes a toll free number to call seca in case this doesn't work.
http://ons.wvdhhr.org/Portals/20/PDFs/policies/2.12%20Anthropometric%20Measurements%20Attachment%20-%202.pdf
May 19, 2010 | Seca 354 Digital Baby Scale Pediatric...
Balance beam wants to stick at about 300 lbs. not smooth moving
I contacted the manufacturer and here is there reply.
No need for oiling or grease, but tip the scale on its side, and look
under the base. There will be four "connection points" where pivot pins
connect to the linkage assembly; see if any of those pins or linkage
points are bent or look different from the other ones.
Then, note down the serial number of the scale located on the side of
the base, or behind the column of the scale at the top or bottom of the
column, and call our Maryland repair center at 800-542-7322 ext. 111 and
speak with Tyson Long from 9:00 AM - 4:00 PM Maryland time to describe
the issue and for further troubleshooting over the phone.
I have attached our new catalogue in PDF format as well. FYI: The model
703 is a very popular, extremely heavy-duty, high-capacity digital
column scale that is a popular alternative to the mechanical physician
scales in the gym and schools environment.
Kind regards,
William Morris
Sales Support
seca north america west
Medical Scales and Measuring Systems seca corp.
3401 Centrelake Drive, Suite 320
Ontario, CA 91761
USA
Telephone +1 909 605 7600
Telefax +1 909 605 7654
E-Mail william.morris@seca.com
Internet www.seca.com
Jan 26, 2009 | Seca 700KG Balance Beam Scale With Wheels,...
Err 12 and Err 16
Dear FixYA
Was advised to send to Scales to another company to be fixed. Therefore no longer need your assistance.
Thank you
Julia
Jan 22, 2009 | Seca 354 Digital Baby Scale Pediatric...
Health & Beauty Logo
212 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
