Question about Kitchen Appliances - Others
My Ice maker is beeping and the indicator lights are flashing
catriver
  • 878 Answers
SOURCE: Ice maker sotp making ice / red light blinking
J, As you open the freezer door the LED on the right should flash 2X with a pause repeatedly. When you hold the left side emmiter down the light should stay on steady. If you have this, you know the optics are good unless the ejector blades are not home. First thing to check is where the ejector blades on the ice maker are parked. They should be resting in the 2:00 position. If they are not, you could have a broken module. If they are in the 2:00 positon the next thing to check would be the fill tube. You want to make sure it is not frozen over. You can disconnect it from the back and see if you can blow through the line or visually inspect it. If all of the above mentioned check out, jump start the ice-maker. Remove the quarter inch screw holding the harness cover on the right side. Remove the harness cover. Pull the ice-maker straight out but be carefull not to smash the emmitter flap on the left side. Leave the harness connected. Get a jumper wire with the ends stripped apout a 1/4 inch. Unplug the refer and place the jumper in test holes T&H. Leave the jumper in and place the ice maker on the shelf where you can close the door. Close the door and plug the refer back in. Wait 30 seconds and open the door. The ice maker should be cycleing. Pull the jumper and place the module cover back on. Put the ice maker back in the rails. It should fill at approx the 12:00 position. Let me know how you make out. Catriver.
Posted on Jul 08, 2007
  • 236 Answers
SOURCE: ice maker
poss a problem with a blocked filter?
Posted on Jan 20, 2008
localwonder
  • 6784 Answers
SOURCE: Kitchenaid built in refrigerator controls are beeping
Sounds like a water flow issue. Check to make sure your manifold is getting proper water flow.
Posted on Feb 14, 2009
SOURCE: Polar Ice Maker Portable
there is a little sensor inside on the top right, it is a little wire if there is anything on it it will not work, i took at small pair of pliers and gently cleaned it
Posted on Mar 06, 2009
blueextc3221
  • 15935 Answers
SOURCE: kenmore ice maker filled with ice, but not dumping. light blinking next to ice maker switch
unfortunately, the heater is molded into the unit.
without testing every part of the icemaker there is now way to be certain which of the following has failed...
USING THIS DIAGRAM -
#11 is the heater assembly
#17 is the thermostat that controls the heater.
An entire unit replacement is not necessary.
Hope this helps.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on May 27, 2009
Why isn't my Hoshizaki km 630 mkh ice maker not making any ice?
that could be a number of problems..is it making any beeps or flashing lights on the circuit board? Have you tried to reset the circuit boards reset button with the machine on. ? If the machine seems totally dead then the bin thermostat is most likely the problem..
Aug 02, 2014 | Hoshizaki Freezer Commercial Ice Machines...
The Ice maker does not fill with water and the red light on the wall of the freezer by the on/off switch is blinking red.
This light flashes a signal that indicates if the ice maker and boards are ok or if there is a problem. If there is a problem the flash changes. I'm sending you the diagnostics chart pertaining to this.
Aug 20, 2011 | Refrigerators
Hoshizaki ice maker beeps when in the on position and will not make ice.
the number of beeps indicates that there is a specific problem. Need model and serial numbers and number of beeps. On some models, the control board has a small white reset button on it. Just push it and see if unit will reset and run.
Jul 05, 2010 | Hoshizaki Cubelet Ice MakerDispenser Water...
Free standing ice maker not functioning
Have you got a slow flash or fast flash?
A slow flash is a problem with the sensor.
A fast flash is dirty condenser failed condenser fan.
See page 16
Mar 15, 2010 | Kenmore 51lb. Clear Ice Maker
Kennmore refrigerator is not making ice,but water
The control light flashes to indicate the infrared beam is being blocked. The flap on the opposite side blocks the beam when the door is open to prevent ice from being dropped on the floor rather than in the ice bin. If you pushe the flap in so it's flush with the liner (use care not to block the hole) the light should go from flashing to on in a steady state. If not, your electronics are bad and would need to be replaced. If the light does glow steady, then the problem is with your ice maker, water valve or ice maker fill tube.
Dec 23, 2009 | Refrigerators
Ice maker is not making ice, yet the red light that indicates the ice maker is "ON" is flashing..
KitchenAid KSGR25FTSSOO side by side one day just quit making ice. We have blown out the lines and replaced the filter. The red light does blick when we open the door. The water despenser as a flow of water that is real slow. How and what do we do next?
Oct 29, 2009 | KitchenAid KSCS25FKSS Side by Side...
Icemaker not working- red light flashes constantly
The red light should flash twice , pause then flash twice constantly . If you close the flap on the left side , then the light should go off . This shows the optics (ice maker cut off ) are good .
Check the black tube ( fill tube ) , which puts water into the ice maker , to see if it is iced inside . If so , then the water valve behind the refrig is bad . It seeps into the tube and freezes , blocking the water flow .
Pour about 2/3 cup of water into the ice maker . If it freezes and dumps , then the water valve needs replaced . If it doesn't dump , and stays frozen in the ice maker , replace the ice maker . Also , make sure the coils under the front of the refrig are clean , as this will cause warmer temp in the freezer and the ice maker needs 5 degrees to operate .
Sep 27, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker not working
try to reset the filter indicator light my [\pressing on the refrigerator light switch 5 times to reset the filter indicator.
Apr 04, 2009 | Kenmore Refrigerators
Ice maker quit working
good sign its flashing , woth door open depress the left side flap oppiste the blinkin light. does the light then go solid red??? i fso its an indication that the electricl eye is operating ok .
theres a screw 1/4 in. along the right side underneath the icemaker itself, youll need to removeit and the cover its holding down. you can then slide the ice maker assy foward and out of machine,There will be another litle tab along loeft side uder ice maker youll need to depress to ppulll unit out. pry off the white cover from front of the ice maker assy itself and have a look at the main gear 2 in. round, is it broken off, or on its way top breaking( sometimes the tabs that hold it on to the ice maker module itself break preventing operation, if this is the case youll need to repalce the ice maker assy.
Oct 31, 2008 | KitchenAid KSCS25IN Side by Side...
Ice maker not working flashing green
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
dfdf
Jul 28, 2008 | GE PSS29NHP Side by Side Refrigerator
Kitchen Appliances - Others Logo
18 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
