Question about E-Machines eMachines Desktop PC
My monitor is frozen on sleep - E-Machines eMachines Desktop PC
    Scholar:
  • 36 Answers
Most monitors if you unplug them from the computer and from power and left overnight will reset on their own, but if you try this and it still is locked, try another monitor to see if that one is also locked, if so then it is a operating system (windows) problem.
Posted on Nov 17, 2013
Monitor goes to sleep immediately after turning on the computer. How can I fix that?
go to start,then pc settings,then monitor or power options the to power and sleep and change on plug to 4 hours and on battery to 10 minutes
Jun 11, 2015 | Computers & Internet
How do i change sleep mode
Sleep Timer Mode
The Sleep Timer mode is an energy-saving feature that enables you to set a time for the monitor to
power on and off at the same time every day. This also extends the life of the backlight bulbs in the
monitor. The Sleep Timer has five settings:
? Set Current Time
? Set Sleep Time
? Set On Time
? Timer: On/Off
? Sleep Now
To set the timer:
1. Press the Menu button on the monitor front panel to display the OSD Menu.
2. Scroll down and highlight Management.
3. Press the OK button to select Management.
4. Scroll down and highlight and select Sleep Timer > Set Current Time.
NOTE: You must set the current local time before you reset the time for Sleep Time or On Time. Note that the time is displayed in a 24-hour clock format. For example, 1:15 p.m. is displayed as 13 hours 15 minutes. A power failure or loss of power to the monitor will cause the timer to reset to 00:00. If this occurs, you will need to reset the sleep timer mode.
5. Press the OK button once to enter the adjustment mode for hours.
6. Press the - (Minus) or + (Plus) button to adjust the hour.
7. Press the OK button again to enter the time for minutes.
8. Press the - (Minus) or + (Plus) button to adjust the minutes.
9. Press the OK button to lock in the time chosen.
10. After setting the current time, the highlight automatically skips to Set Sleep Time. Repeat steps 6 through 9 to set Sleep Time.
11. If you do not want to set Sleep Time, press the OK button twice, then select Save and Return to exit the menu.
12. After setting Sleep Time, the highlight automatically skips to Set On Time. Repeat steps 6 through 9 to set On Time.
13. Set the Timer mode to On to activate the Sleep Timer settings.
14. When you are finished, select Save and Return to exit the menu.
The fifth selection, Sleep Now, turns the monitor backlights off immediately and stays in sleep mode
until the next On Time activates or a monitor button is pressed.
May 27, 2014 | HP Pavilion 22bw Black 21.5" LED Monitor...
When the CPU switch on, the system running upto 10 minutes. after that the monitor screen automatically off.
Here is artical I found on how to disable sleep mode on a monitor, this would be for VISTA or 7, if you are using XP it's a bit different. ____________________________________________________________ How to Disable Sleep Mode on a Monitor
Your computer monitor or laptop screen will enter sleep mode after your computer remains idle for a set period of time. You can disable sleep mode if you prefer the screen to remain illuminated. You merely need to change a setting in the Windows Power Management properties box.
Difficulty: Moderately Easy Instructions
  1. Click "Start" and "Control Panel".
  2. Click "System and Security" and "Power Options". This will bring up a new dialog box.
  3. Click the menus to the right of "Turn off the Display" and set them both to "Never". This will disable sleep mode.
Read more: How to Disable Sleep Mode on a Monitor ' eHow.com http://www.ehow.com/how_6953659_disable-sleep-mode-monitor.html#ixzz1CiGFFyLk
Feb 01, 2011 | Acer AL1916W 19" LCD Monitor
Monitor going to sleep problem
  • Hi, The Monitor as well the Computer have "Power Saving Modes," [Sleep, ScreenSavers, and Hibernation]; so what you want to do is "Change the way the Computer / Monitor Sleeps!" From the Desktop Screen, click on the "Start Button," next in the [Start Search Window], type: power. In the next [window] that opens, you should see, from your point of view; a "list" in the (left column) "Change when the computer sleep, the wording may be different, but it will be clear enough. Now all you have to do is change the way the Computer and Monitor "Sleep, or Turn-off." If the Monitor have its own "settings;" just find them by the [button on the monitor], and do the same thing as above; but I'm sure the computer will take care of both. If this solution to the problem was of help? Let me know by giving a "Helpful Rating", thanks, and have a "Great Memorial Day!"
May 30, 2010 | HP 2009M Monitor
I have an HP w2207 flat screen monitor. I have to
I stoped the monitor from sleeping by going into the montitor's menu, management, then sleep. Turn on the never allow to sleep mode. We were having some of your mentioned issues with the icons and with the monitor not waking up. This fixed that. Now the computer will go to sleep and when started the monitor comes on instantly.
Mar 23, 2010 | HP Computers & Internet
Monitor says it is going to sleep and there is only a black screen.
Monitors go to sleep when there is no computer activity it detected. Also, when your OS is working and somehow you have set a "sleep" time, then the monitor goes to sleep at the appointed time. Just press ENTER or press the POWER BUTTON to bring it back to life without losing your computer work.
Oct 29, 2009 | HP f2105 21" LCD Monitor
Please look at the video card of your computer,did you set it correctly?
Apr 01, 2009 | HP Vs17 17" LCD Flat Panel Monitor
Monito going to sleep
I have the same problem. Monitor states going to sleep and the pc goes dead
Jul 03, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Works when it wants to then turns whie with grey line in it
Hi
If only the monitor is going to sleep, then it could be a problem with the connection from the monitor to the computer or with the cable.
If the computer goes to sleep and if you are not able to wake it from sleep then check the sleep mode settings and also the power management settings for the keyboard and mouse.
You may also do a system restore if you are not able to wake the computer from sleep.
Feb 24, 2008 | Sony SDM-HS73P 17" LCD Monitor
When I select sleep or hibernate mode - the monitor stays black...
Hit the keyboard keys. It is better to just turn sleep and hibernate off and just use a screen saver or tun it off.
Aug 24, 2007 | ViewSonic VX910 19" LCD Monitor
E-Machines eMachines Desktop PC Logo
27 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
