Question about Universal Kreepy Krauly In-Ground Pool Cleaner
My Kreepy Krauly Kruiser works great for awhile & then floats to the surface & remains there.
  • 128 Answers
SOURCE: my Kreepy Krauly is working at half speed, any
You have an air leak. Check the lid oring, pull the plug on the bottom of the pump pot (where the pump basket is) and reseal with tephlon tape. Also check pipe going into pump for leaks. If you shut pump off and water squirts out or drips from the pipe it is not sealing.
Posted on Aug 23, 2009
  • 11 Answers
SOURCE: Hi my kreepy krauly wont stay flat on the bottom
Do you have any hose weights fitted to the kreepy hose? If you do,take it off and see if it makes a difference.Is this happening while the kreepy is operating?
Posted on Mar 27, 2010
Coastsider
  • 331 Answers
SOURCE: My kreepy Krauly will start up and within 5 stops working.
If it is a year old, replace the flapper valve. Also check your water flow and make sure it is adequate. These units are subject to wear on the foot and flapper and these should be changed each season
Posted on Apr 14, 2010
Testimonial: "Great thank you for this info...I believe that I need to buy another type....too many problems with this type of cleaner."
  • 990 Answers
SOURCE: Our kreepy krauly will not stay suctioned to the
Check for air leaks in your hoses, your pump or in the plumbing system. Also check for clogs in your pump impeller if you have any problems with your basket. Good luck.
Posted on Apr 24, 2010
Geekman
  • 32281 Answers
SOURCE: Kreepy Krauly In-Ground Pool Cleaner: my creepy crawler wont hammer...
This usually happens when there is a small stick jambing in the bottom of the openning in the Kreepy Krauly where it sucks in the water and rubbish. It is the rubber tube that has a ****, usually something is jambed in the **** to prevent it from thumping.
Posted on May 25, 2010
My kreepy krauly hose is always getting twisted what can I do
ive had great luck with installing a piece of non rusting wire curled up like a spring inside 1st 3foot of hose and keeping floats on last 15 feet of hose
aluminum welding wire works a charm
Oct 04, 2014 | Universal Kreepy Krauly In-Ground Pool...
What can i do to get my Zodiac Kreepy Crawley to submerge under the water to clean the bottom of my pool
Check to see that the hose weights are attached. There should be a weight in the middle of the fist 3 sections of hose from the cleaner.
May 16, 2014 | Universal Kreepy Krauly In-Ground Pool...
Kreepy krauly just floats wont sink to bottom
Kreepy kraulys usually come with a weight make sure you have it and its attached before launching into pool.
Jun 01, 2013 | Pool & Spa
Kreepy pleated seal keeps coming off
Does the Kreepy have its foot pad attached? This is the boot that pulls onto the end of the housing and makes contact with the pool surface where the debris goes in. (Part # k12059). The pleated seal should not be able to get past that part.
Feb 04, 2013 | Universal Kreepy Krauly In-Ground Pool...
Kreepy kraully not cleaning complete pool
If the pool hose has been connected to the Kreepy Krauly in the one position for a long time, the pool hose gets set is a position so the kreepy Krauly travels ith same path all the time. Try rotating the pool hose 90 degrees and or change the angle of the hose connector in the skimmer box.
Mar 07, 2012 | Pentair Kreepy Krauly Inground Automatic...
Kreepy Krauly is not staying sealed to pool surface but is cleaning
Check to make sure that you do not have debris in your flapper than could cause the lack of seal. If something gets lodged in the flapper of these pool cleaners, this problem can occur. As long as it is still cleaning, you shouldn't have any major problems.
Jun 11, 2010 | Universal Kreepy Krauly In-Ground Pool...
My Kreepy Krauly works for 10-15 minutes and then stops hammering and sits on the pool floor. I have replaced and checked parts and the pump runs well.
you may have a hose that allows air to get sucked in at times when the unit moves and the hose with crack is able to float to the surface and make contact with outside air. move hoses around and see if that helps you can also start from the closest connection at the suction port and lift the hose out of the water one section at a time hold it out of water for a moment and see if you notice any weird feeling or hear a slurping do this section by section until you get to the last hose section at kreepy head
May 14, 2010 | Pentair Kreepy Krauly Inground Automatic...
Our kreepy krauly will not stay suctioned to the bottom of the pool. What can we do?
Apr 24, 2010 | Universal Kreepy Krauly In-Ground Pool...
Mar 25, 2010 | Universal Kreepy Krauly In-Ground Pool...
Universal Kreepy Krauly  In-Ground Pool Cleaner Logo
67 people viewed this question
Top Universal Pool & Spa Experts
Bill Jordan
Are you an Universal Pool and Spa Expert? Answer questions, earn points and help others
