Question about Goodman CLQ36AR49 Air Conditioner
Warm Air in Cooiing mode
I need support on a new Goodman 16sx heat pump. Wiring this beast seems to be a problem . I can be reached at 570 801 1507 thank you
  • 50 Answers
Warm air in cooling mode usually means that the thermostat needs to be set to energise the reversing valve in cooling. To do this is simple just by opening the stat and moving the selector switch to o. Everything else will wire color to color. r-r, g-g, y-y, o-o, w-w and brown. If you want the heat strips separate wire brown to emergency heat on thermostat. Hope this helps, RepairUSA
Posted on Sep 01, 2007
SOURCE:
I am getting hot air instead of cool air from my heat pump when it is in the cooling mode.
The problem is in the thermostat wiring. Y1 on an air conditioner, brings on the cooling. On a heat pump, it brings on the compressor, which generally fails to heat mode. The O wire operates the reversing valve, which brings on cooling. If these wires are reversed, or not hooked up, you will not get cooling.
Jul 12, 2010 | Goodman CLQ36AR49 Air Conditioner
I am installing a condenser instead of replacing a heat pump and need the new wiring diagram
Same as heat pump with the exception you will only be using two thermostat wires. C & Y. They will power the contactor coil.
Apr 28, 2010 | Goodman CKL36AR36 Air Conditioner
What does aux mean on a honeywell Thermostat? the heat doesn't seem to be working but warm air is comming from the vents and the heat pump fan is spinning just not enough to match the temp. it's set too....
The aux switch is for electric heat banks installed in the air handler. Depending on the outside temp. it may not be efficient to run in heat pump mode but in aux. or emergency would run the electric heat in the air handler.
Dec 11, 2009 | Goodman Heating & Cooling
My goodman air handle is run on e-heat only and will not turn off ,also the outside unit will not turn on , I put a new themostat this didn't help I have a goodman heatpump
Heat-Pumps can be temper mental. Sounds to me like your air handler is running on emergency heat, due to a problem with the condensing unit.You have heat strips in the air handler in case the outdoor temp. gets to cold and the heat pump cant keep you're home warm.Also, if you loose a compressor, it will go into emergency heat. If you have lost the compressor for one reason or another, lets say a locked rotor, the compressor would draw L.R.A. (Locked rotor amps) and cause the circuit breaker to trip. Check this.As for the air handler running all the time, you said you replaced the stat? When you removed the control wiring from the stat, did the fan shut off? I wish I were on site to help you, but all I can do is offer you some advice. With the power off to the air handler, go to the stat and remove the red and green wires. Turn power back on and see if it stops running. If it stops, then it sounds like the new stat is also faulty? If it continues to run, check the wiring in the air handler to make sure the red and green are not touching somewhere, and also check the control wiring on the outdoor unit for the same problem. Do you have any dogs that may have chewed into wiring? If so, check all outdoor t-stat wiring. There are so many things it could be and I hope very much I have helped you with solving this online, which can be difficult. You may also have a faulty defrost board. Try to do what I have asked of you.
Good Luck, Sincerely, shastalaker7
Oct 16, 2009 | Goodman GMS90703BXA Heater
New goodman pkg heat pump i wired up 2 brand new
You may have defective tstat wiring, or a bad control fuse. Check both.
Jul 30, 2009 | Goodman CKL24AR24 Air Conditioner
Electric furnace won't shut off
It sounds like a bad or badly miswired T-stat
Jan 20, 2009 | Goodman CLQ36AR49 Air Conditioner
Electric furnace runs but won't shut off on heat setting
I would insist that Sears either have a Senior tech come out and fix it or return it to the state it was prior to them touching. Then call some one else. Have them involve the Goodman rep in your area.
Goodman ac / heat pump
I just had a new unit installed and I am surfing for troubleshooting tips too. My unit is doing the same... cools well heat sucks. my problem has been isolated down to the reversing valve... It is constantly energised which means it is constantly in a/c mode even when kicking on the heat strips... We disconnected a line at the thermostat and it is working well as a heater now. You may want to check yours to see if it is actually kicking over into to heat mode... -rob
Nov 25, 2007 | Goodman CLQ36AR49 Air Conditioner
Goodman CLQ36AR49 Air Conditioner Logo
174 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Paul
Paul
Tom Palicke
Level 1 Expert
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
