Question about Power Lid Air Filter - Honda TRX450R 2004-2005 - HA-4504-T
When i put my honda trx450r in gear it makes a grinding noise and wont move at all when i let the clutch out
  • 3 Answers
It sounds like your clutch is worn out and needs to be replaced. Your clutch is the mechanical connection between your engine and your transmission. It has a rough surface that, when let out, will "grab" the surface of the flywheel. If your clutch is worn out, it no longer has the rough surface and will no longer "grab" the flywheel. Because it can no longer grab the flywheel, there is no longer a good connection between the engine and transmission and you will not be able to move. I would suggest replacing your clutch either yourself or taking it to a shop and having them do it for you.
Posted on Aug 03, 2013
Pushed started my 06 Honda trx450r now it makes a grinding / ratchet sound when idling or when you ride it have I done something to the gears in the trans?
Either the starter gear is staying stuck in the flywheel or the synchronizers in the trans got damaged while pushing it off. Possibly the clutch basket was warped too
Feb 19, 2015 | Honda Cars & Trucks
Manual transmission grinding
Did you use the correct spline to align the clutch with the bell-hosing, and replace the throw-out bearing?
Aug 20, 2014 | Honda Accord Cars & Trucks
Car will not engauge into 1st or 2nd gear
the gear grinding noise is because the clutch plate is not fully disengaging and the input shaft is still driving. If you did not use the same length of push rod then the slave cylinder is not moving enough to disengage the clutch. Check it out that with the pedal on the floor the piston in the slave cylinder should be almost to the edge of the slave cylinder . That is where It should be to be working properly
Jan 13, 2014 | 2004 Pontiac Grand Am
Push down clutch makes grinding noise
cluch plate to be replaced, flaw in materail caused plate to shatter!
Oct 02, 2013 | Honda Civic Cars & Trucks
Clutch on my '91 ford explorer
Im pretty sure the vehicle has a bad throw out bearing. That's what's making the noise when you depress the clutch. It would need to be replaced, along with the clutch disc, and pressure plate.
Feb 17, 2013 | 1991 Ford Explorer
2000 civic wont drive
Sounds to me that you might have lost your pressure plate or the throw out bearing. The only way to check is to pull your trans out and see if the presure plate is broke or the throw out bearing id gone. Sorry no quick fix on this one. It;s not a bad job to change the clutch assem. but it is time consuming.
Dec 04, 2012 | 2000 Honda Civic
Will start but will not move
replace the clutch or transmission or both
Jul 13, 2012 | 1995 Honda Accord
I have a 1989 z24 cavilier and i just changed the slave cylinder and now when i start it and press the clutch it makes a grinding noise. When i try to put in gear it wont go in any gears and makes some...
hi i was wondering if anyone can tell me whats going on with my 89 z24 cav i just replaced two shifter cables on she's a 2.8l 5 speed and now when i starts her and lets the clutch out she dosen't engage at all but she has no noises and no grinding goes in gear fine but just won't move hope someone can help thanks
Jul 04, 2012 | Cars & Trucks
Hi there,i have recently bought an 1988 honda city and when i try to put it into first,but mostly reverse gear,it makes a horrible grinding noise,any ideas?
sounds like a clutch issue -- check to make sure that the clutch fork is moving and working,, and if it is then I would say that the clutch plate is worn out and needs to be replaced.
c...
Feb 01, 2011 | Honda Civic Cars & Trucks
My 92 honda accord will not go into 1st 3rd or 5th gear
check shift fork adjustment. make sure you bleed the slave cylinder.also check shift cable adjustment.
Apr 11, 2009 | 1992 Honda Accord
Power Lid Air Filter - Honda TRX450R 2004-2005 - HA-4504-T Logo
98 people viewed this question
Top K&N Products Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a K&N Products Vehicle Part and Accessory Expert? Answer questions, earn points and help others
