Question about Plantronics CS60 Professional Headset
I have a Plantronics CS60 at work. I can hear but can't speak. The other person on the line hears nothing. I tried to reset, reboot, reconnect, unplug/replug the battery... Nothing worked. My plantronics used to work. Solution?
  • 32 Answers
SOURCE: Best Buy: Plantronics Problem
James, plug the phone cord that comes out of the back of the CS55 base into the handset port of the Cisco phone, not the headset port.  Then plug the coily cord from the cisco receiver into the front of the CS55.  Don't use the "Headset" button on your Cisco phone, just lift the receiver off.
Posted on Apr 28, 2009
keekus
  • 83 Answers
SOURCE: Plantronics CS60
1. Check the configuration dial on the left hand side of the base to see if another setting works better. The recommended setting for most phones is 1.
2. Make sure your speaking (transmit) level is not too low. First, try increasing the volume on the telephone. Secondly, the master transmit controls are the ABCD switch settings on the bottom of the base. A is the lowest and D is the highest setting. You can fine tune this setting with the Plus (+) and minus (-) buttons on the back of the base that are above and below the picture of the microphone.
3. Double check the battery has a full charge. To check press down on the headset into the base station to ensure it is in the base in the correct position.
The Amber Charge light on the base will flash while charging and will stay solid amber when fully charged.
3 hours = full charge
Posted on Jul 18, 2009
keekus
  • 83 Answers
SOURCE: plantronics CS55. When using the wireless headset
Echo is usually caused by the transmit (speak) level on the unit being set too high.
1. First, try lowering the volume of the telephone. If you still hear an echo, adjust the volume of the headset itself.
2. The master transmit controls of the headset are the ABCD switch settings on the bottom of the base. A is the lowest and D is the highest setting.
3. You can fine tune this setting with the plus (+) and minus (-) buttons on the back of the charging base.
4. If this doesn't fix the echo, try moving the configuration dial on the left side of the charging base. The recommended setting for most phones is 1.
  • 608 Answers
SOURCE: Problem for Plantronics CS50 Wireless Headset
The following is a cut from Plantronics web site. I hope it helps, It's just possible you have missed a setting, such as the mute switch.
The CS50 has both transmit (how you are heard) and Receive (how you hear) controls on the unit itself.
The Master Transmit controls are the ABCD switch settings on the bottom of the base. A is the lowest and D is the highest setting. You can fine tune this setting with the Plus (+) and minus (-) buttons on the back of the base that are above and below the picture of the microphone.
The Master Receive setting is on the back of the base (below the picture of the microphone) there is a 1234 switch 1 being the highest setting and 4 being the lowest setting. You can fine tune this setting by using the volume control on the headset itself. This is the rocker volume wheel on the back of the headset (opposite of the microphone).
The headset volume control also doubles as a mute switch if you press it in, instead of rocking it back and forth.
There are also configuration settings on the left hand side of the base. This is a dark grey dial with a 1234 on it. There are notches to the right of this dial. Whatever number is lined up with the notches it what setting you are on.
This needs to be set to the clearest setting.
There is a silver button on the headset itself which is your “Talk button”. This is what you press to use the headset and or transfer the call from the headset back to the hand receiver.
There is also a switch on the right hand side of the base which is your the IntelliStand feature.
When the CS50 is used in conjunction with the HL10 handset lifer you can enable the IntelliStand feature.
The IntelliStand feature senses when the headset has been removed or placed into the CS50 base unit which automatically activates the Handset Lifter and enabling headset/handset mode to answer or end the call.
There is a switch towards the bottom on the right side of the base unit that will switch the IntelliStand feature On and Off.
Posted on Apr 11, 2010
drifterK
  • 4924 Answers
SOURCE: I have been using Plantronics
this is a normal reaction ..specially on a wireless device ..the idea is to lower the volume into the computer ..(to max 80%)..and also get into the volume control by double clicking on the speaker icon in the task bar ..and in here look at the mic volume
if there isnt any volume section for the mic..than click options ..than properties..and from the list tick the case for mic in ..and will list the volume for mic..
if the advanced function is on ..check into the advanced under the microphone it is started the mic boost function ..if it is ..and you want to keep it for a better mic reception ..than you have to put the mic on mute to eliminate the static noise..
THis should not mute it for good..but you can make a trial to be sure..
If the advance boost function is on ..and the muting puts it out for good..the choice is to get rid of the boost but usually works if you mute it ..cause only mutes the noise ..
let me know if you didn't understood anything ..
Posted on Sep 03, 2010
Cs540 caller hears echo
Hello, if they are hearing echo, you are speaking too loud. Or have the receiver too close and talking too loud. Or the person on the other end of the line has phone line problems.
May 16, 2014 | Plantronics CS50 Wireless Headset
Hi, we use the plantronics cs60 headset at my place of work and the earpiece stopped working so i have changed it for another one and i have paired them together but now when i pick the ear piece up the...
It would depend on what headset you actually purchased. You say CS60 but it may be the Plantronics CS50 or CS55 headset. The headsets are not interchangeable. If you are not sure what headset you have, simply look on the bottom of the base for the part number. On the headset you can read what part number that is by very carefully looking under the battery. Here is a link to open the battery.
Here is a link to the CS60 instructions to replace the battery.
I think that if the base and the headset are the same it might be that you may need to subscribe or pair it together again.
Here is a link to the CS60 subscription and pairing instructions.
Good luck from Headsets Direct!
Jul 28, 2011 | Plantronics CS60 Professional Headset
I have a Toshiba TG01 phone and a Plantronics M100 earpiece. My problem is that when i use the earpiece, and my Toshiba phone the other person with who i speak with, can't hear me well. It hears me...
This model headset is one of the headsets rated as compatible with your phone. You want to make sure there are no other bluetooth applications interfering with the link. Disconnect the phone battery, if possible, for a few seconds and reconnect. Then re-pair following the instructions on the link for the Plantronics M100 bluetooth headset.
Jul 14, 2011 | Plantronics M100 Bluetooth Headset
Hi, I have a plantronics CS60 that was working until a few days ago.I made sure it fully charged for the owner last night after it was reported faulty. The green light does not go on for the wireless...
Plantronics CS60: Hard Reset.
NOTE: Before re-subscribing the system make sure the IntelliStand switch (on the right side of the charging base) is in the "_" position and NOT the "=" position.
1. Press both the call control button and the listening volume/mute button for 5 seconds. When the indicator light blinks release both buttons.
2. Press the call control button again. The talk indicator light will again blink briefly to indicate the headset is back to normal.
3. Disconnect the AC charger from the AC charging jack for 5 seconds.
4. Reconnect
Jul 29, 2009 | Plantronics CS60 Professional Headset
Plantronics CS60 - People I call say I sound too soft or distant
To check the charge, press down on the headset into the base station to ensure it is in the base in the correct position.
Jun 23, 2009 | Plantronics CS60 Professional Headset
I have a CS60 Handset doesnt work when the headset is connected
First setup the headset as follows:
  • Locate the 2 ports on the bottom of the CS60 charging base. One has an icon of a "full telephone" and the other has an icon of a "hand receiver."
  • Unplug the hand receiver from the base of your existing telephone and plug it into the "hand receiver" port on the CS60 base unit.
  • Then take the short cable that came with the CS60 and plug it into the "full telephone" port on the base of the CS60.
  • Plug the other end of the short cord into the hand receiver port of your telephone (where the hand receiver just was).
  • Make sure the AC Power is plugged into the wall, and then you can adjust the configuration settings.
To be able to hear or speak through the handset, either place the headset back into its charging cradle or press the call control button on the side of the headset. The talk indicator light on the base should go off and no sound will come through the headset.
Note: Make sure that the cables are connected correctly and the handset cable is connected to the base of the CS60 base.
Jan 27, 2009 | Plantronics CS60 Professional Headset
CS60 ear peice with heavy static when in use
This may be caused by a few things.
2. Make sure your speaking (transmit) level is not too high. First, try lowering the volume on the telephone. If you still hear distortion, adjust the volume of the headset. The master transmit controls are the ABCD switch settings on the bottom of the base. A is the lowest and D is the highest setting. You can fine tune this setting with the Plus (+) and minus (-) buttons on the back of the base that are above and below the picture of the microphone.
4. Make sure the headset has been paired to the base.
Jan 20, 2009 | Plantronics CS60 Professional Headset
Plantronics CS60
Aug 20, 2008 | Plantronics CS60 Professional Headset
Plantronics Problem with my headset
Setup the Plantronics CS60 wireless headset as follows:
To be able to hear or speak through the headset, press the call control button on the side of the headset. The talk indicator light on the base should go on and the green light on the side of the headset should be blinking.
Jul 21, 2008 | Plantronics CS55 Wireless Headset
Connecting headset to phone
Jun 16, 2008 | Plantronics CS60 Professional Headset
Plantronics CS60 Professional Headset Logo
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
