Question about Pass & Seymour Pass and Seymour Decorator Fan Speed Control with Dimmer, White #LSDC16PWV
Installing two pole switch - Pass & Seymour Pass and Seymour Decorator Fan Speed Control with Dimmer, White #LSDC16PWV
  • Pass & Seymour Master
  • 5,245 Answers
Copy following link to help identify switch and wiring:
http://waterheatertimer.org/How-to-wire-switches.html#PandS
Add a comment and describe timer and wiring in detail.
Gene
Posted on Jul 31, 2013
I'm installing a dimmer switch to control two lights. I have three black wires attached to the original light switch that is a single pole. When I hook up the dimmer switch it does not work.
You have either wired it wrong and destroyed the dimmer or just wired it wrong.
I'm guessing that one wire is hot and 2wires go out to the lights.
The hot wire should be on one side of the switch and the other 2wires on the other side.
Here's a video -
Dimmer Switch Installation single pole By Everything Home TV
Sep 17, 2017 | Electrical Supplies
Why after installing a Pass and Seymour lighted single pole toggle switch, the CFLs in my bedroom light flicker on and off.
Is the switch wired wrong?
Does the switch have 4 wires?
Look at wiring for single-pole timer and see it it applies to your switch
http://waterheatertimer.org/How-to-wire-timers.html
Gene
Oct 06, 2014 | Electrical Supplies
Switch and dimmer work opposite each other
Refer this issue directly to Lutron. They could have an ineresting explanation!
Jan 27, 2014 | Lutron Toggler Single Pole 600 Watt Preset...
How do I install a double pole double pole switch on a home receiver
1) Copy following link to help identify switch:
2) Switch is not identified.
What are you wanting to do?
What is a home receiver?
3) Feb 2013. Add a comment and describe project in detail, including voltage, switch-type, and project objective.
Feb 22, 2013 | Electrical Supplies
Electric switch install
Open following link for single-pole and 3-way installations:
http://waterheatertimer.org/How-to-wire-GE-15312-timer.html
If you have two hot wires inside the same box, that is unusual unless the power source is 240volt.
However it is possible that box has two hot wires and each controls a different light.
Jun 20, 2012 | Electric Electrical Supplies
I have two black wires in box attached to regular light switch & want to know if I can install a Skylark S-603PG single pole dimmer switch which has one black , one red&white, red and green wires
This is single-pole -or- 3-way dimmer
Manual shows on following link:
http://www.lutron.com/TechnicalDocumentLibrary/0301107A.pdf
1) Manual says: The red/white wire is not used in a single-pole application. Twist a wire
nut over this wire for a single-pole application.
2) Green wire connects to bare ground wire. Or bare ground to bare ground.
3) Connect dimmer-red and dimmer-black to either insulated wire that came off of old switch
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on dimmer or any do-it-yourself project.
We are always less expensive than a service call.
Jan 14, 2011 | Lutron S-603PG Skylark Single Pole/3-Way...
Installing a combination switch
The three way will have more connections, whereas the Single Pole, should only have a few contacts the three way will have more.
May 27, 2010 | Leviton 002-1754-W Dual Rocker Switches
How do you wire a Two Single Pole Switch for each switch to run seperate lights all off of one circuit. Example: Recess Lights on one switch and a Track light on the other switch. 6 black wires, 6 white...
so 6 grounds is connected together, and conneted to mains ground (direct connection), the white wires is (mains Neutral) and you connect all 6 white wires together (to doble pole safety switch) in one end pole switch, and you connect a wire from another pole the same end at common Two Single Pole Switch and connect (Black wires recess lights) to one free pole switch and (Black wires track lights) to another free pole.
The mains connect to safety switch live (Black or Brown) to another free safety switch pole, Neutral (White or blue) to free safety switch pole and earth to ground wires on mains connector.
Note: Allways use a mains 300mA diferencial safety switch, for better protection.
Jan 02, 2010 | Computers & Internet
How to wire a 2-pole switch?
You should have 3 connections on the switch, double pole,single throw.The brass colored connections are hot and the silver is neutral.You should have a diagram that came with the switch.The switch should also be marked if you look close enough.If you are still not sure , I would go to the nearest hardware store with the switch, and look for the same one in the box and at the diagram. Hope this helped you out.
Good Luck,
Shastalaker7
PS 2-Hot to Hot terminals, and 1-silver, and ground, green.
Nov 06, 2009 | Heating & Cooling
Pass & Seymour Pass and Seymour Decorator Fan Speed Control with Dimmer, White #LSDC16PWV Logo
64 people viewed this question
Top Pass & Seymour Electrical Supplies Experts
ken skalski
Mike
Mike Squire
Are you a Pass & Seymour Electrical Supply Expert? Answer questions, earn points and help others
