Question about Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
Steering gear hits deck pulley- gear is being chewed up
  • 3 Answers
How do you fix this
Posted on Jul 31, 2013
WHY WILL MY BLADE NOT WORK ON MY HUSQVARNA RIDE MOWER AFTER HITTING METAL BAR
Sounds like the large nut on top of the spindle may have loosened up or the splines on the pulley are chewed up. Turn the blade and try to hold the pulley on top. If the blade turns and the pulley doesnt, its one of the two things I just described.
Jun 29, 2014 | Husqvarna Garden
The drive belt and power steering belt keep getting chewed up by shifting?
with the belt off are all the pulleys spinning freely-usually the tensioner pulley goes out and causes belt failure-Denny
Nov 03, 2013 | 2000 Nissan Maxima
How do i replace drive belt on murray 42" mower
This is not a job for a beginner. I recommend you have the local repair shop do it.
If you must do it yourself, then here's how to do it.
Start by removing the mowing deck. Set it aside. Make sure to mark where all the hardware goes. Remove the center bolt from the from pulley stack. You will need an extension socket and probably an air powered impact gun. This will allow the pulley to lower enough to remove the front part of the belt. If the pulley is stuck, use a backside pulley puller to remove the stack pulley. Any other kind of puller will damage the stack pulley. Next, remove the lower steering gear and raise the steering comuln up about 4 inches. The gear is held on with a circlip. The tension pulleys will each need to be loosened to get the belt of and back on past the retainers. Completely remove the belt from the rear pully (transmission). Install in reverse order. The entire job should take about 1.5 hours.
Take pictures or draw diagrams before you start. It is helpful when reassembling.
Aug 30, 2010 | Garden
Sears Craftsman riding mower V belt getting chewed
I believe you may have the belt over one or more of the belt retainers next to the pulleys. They are 5 or 6 inches long and about a 1/4 inch in diameter. You have to loosen them when you put the belt on then adjust them to where they are just barely touching the back of the belt. They keep the belt from jumping off.
May 01, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman 42 in. deck lawn tractor. Will start and idle fine but when you let out on the clutch the motor bogs down and dies
few reasons will try to narrow down first start it and put in neutral and deck disengaged release clutch if bogs then fuel problem the carb may need adjustment or repair or fuel filter needs replacement----if no bog step on clutch no put in gear release clutch if bogs check drive belt -upper belt on engine pulley and check for binding an idler pulley problem -debris -or rear unit binding -needs service-drive pulley damaged-rear locked--if not bogging in gear step on clutch engage deck release clutch if bogs need to check deck -belts-pulleys -mandrels -bearings and for bent or binding blades good luck
Mar 10, 2010 | Craftsman Garden
Hit Object - Steering gear shifted....decreasing right turn to 15 degrees...increased left turn to 90 degress. How best to reset?
look down at the base of the steering column and you should notice that the steering is like two gears faceing each other. when you hit an object hard enough it is possible for the gears to jump out of alignment, simply loosen and realign, gears should be facing each other equally, to give you the same turn radius, left and right
Oct 23, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Mandrel chews pulley
Are you sure the spindle is not bent and also are you balancing the blades when sharpening. Other then that make sure bolts are tight on the mandrel. With the deck off and standing up spin the blades and watch center of balde to see if something is bent. Also watch pulley on the other side to see if its bent.
Jul 19, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Mandrel ruins pulley
there are only a couple of things that could be causing this: either the spacer [looks like a thick washer] is put on above the pulley [it goes UNDER the pulley], or the nut holding the pulley on is not being tightened enough
Jun 24, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Steering wheel on rider mower is straight and wheels both point
You need to take the bent tie rod off and straighten it out and put it back on. Look carefully at the engine pulley ("wheel"). Make sure it is not bent. By bent I mean the bottom is not pushed up. The pulley should form a 'V'
Jun 04, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
81 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
