SOURCE: Tear in Eureka Upright "The Boss" 4870
http://geeksquad.fixya.com/ThreadView.aspx?prdid=414813&thid=652524
Posted by kdunnett on Jun 07, 2008
I have a tear in the hose of an upright Eureka "The Boss" 4870 vacuum. I cannot find how to release the parts I need to get the hose out and put in a new hose (which I already have) I've searched the Eureka site and the owner's manual - nothing about how to replace the hose itself. Thanks in advance.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Eureka 431A Optima Bagless Upright Vacuum. In answer to your question, the owner’s manual may or may not give an example to install the hose only, but on most vacuums the hose sometimes will screw in to the hose cuff on both ends unless if it is a hose assm then it will then twist and turn. Check with the Eureka website and have them send out a schematic and owner’s manual for you so that you can install your hose properly. Sometimes you have to place hose glue on the end of each side in order for the hose to screw in properly. the website address will be listed below and they certainly should supply you with the owners’ manual and maybe a schematic of the parts breakdown that also may help. If not; check with your local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.eureka.com Customer Service 1-800-282-2886
Customer Service Dept for U.S.
Electrolux Home Care Products
P.O. Box 3900
Peoria. IL 61612
Hours of Operation
Monday thru Friday 8:00am to 7:30pm CST
Saturday and Sunday 10:00am to 6:30pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
SOURCE: Eureka 4870 hose assembly replacement
Boy, it's been awhile since I took one of these hoses off, but I think at least one of those plastic hose guide things has to come off in order to remove the hose. Those screws that look like they cannot be removed are probably torx screws which need a T20 torx scredriver that you can get at any hardware store. That is the most common size torx screw that Eureka uses.
Here is a link to the owner's manual in case you need any diagrams for getting the clear tubes off:
http://www.eureka.com/service/manuals/70750.pdf
Hope this helps. :-)
SOURCE: Eureka 4870 vacuum brushroll control doesn't work
Use two hands to presscontroll button upward until it snaps in place.
SOURCE: My Eureka 4870 has no suction.
The bag is full.You need to take out old bag and replace with a new bag.
Jim
SOURCE: Eureka 4870: Brush roller turns even in hose setting.
You either have the wrong size belt, most likely too small, or you have installed a new belt incorrectly. When you open the cover on the bottom of your vac, you will see the pulley that moves as you flip the switch from floors to carpet. The belt does not go around this pulley. When activated(carpet) the pulley puts tension on the belt causing it to turn the roller. When switched back to hard floors, the belt looses tension allowing motor to cause suction but disabling roller. Also, the dial on top of vac is only to direct suction, not for disabling roller
