Question about Fellowes 3011001 Shredder
Powershred ps 40- my machine turns on but will not accept any papers to shred -- there does not seem to be anything stuck in machine.
SOURCE: Fellows Powershred c-120 c indicator lights
your bin full sensors are dirty or broken to clean access bottom side of shredder head and look for a set of screws on each end of the paper throat. There you will see two little bulbs (bin full sensors) these have more than likely gathered paper dust and need to be cleaned with a Q-tip dipped in a little Isopryl Alchohol. This should solve your problem. If you have any questions just call us at 1-800-945-4545. A Customer Service Representative will assist you.
Posted on Apr 23, 2008
SOURCE: Regarding powershred 480
I have a similar problem with the bin full light and understand I have to clean the sensors. The sensor you could be having trouble with is probably up in the feed slot area. Have a look at it with a flashlight and see if there is paper dust covering the sensor. I clean mine with a toothpick.
I haven't had much luck in finding an official description of where the sensors lurk, just trial and error.
Hope this amateur suggestion helps.
Posted on Aug 06, 2008
POCBM
  • 121 Answers
SOURCE: PowerShred C-220 will not shred automatically
OK lets try.
You likely have a photo sensor that detects the paper and it is dirty.
It is likely covered with paper dust (hopefully only on the outside)
Locate the sensor and wipe it off or just wipe the entire throat area.
WITH MACHINE OFF
Hope this helps
Posted on Mar 15, 2009
  • 32 Answers
SOURCE: Fellowes PowerShred PS 40 with defective switch
Its just seated together with the gear/blades housing ,
make sure you didnt miss one screw, then pry and pull upward its just stuck as the gear housing and blades are pressed in and seat firmly making it seem like its stuck , over time all that paper goo is also binding it up .
Heres a few sites that have gears another that has manuals you may have to call or email as not all parts are listed on website
http://www.compax.com/shredders/parts.html
http://wheelermachines.com/manufacturer.html
http://www.manualsonline.com/ex/thread/view/idThread/1735067
Posted on Sep 01, 2009
  • 610 Answers
SOURCE: My Fellowes ps-40 will not shred. The motor is
you have some shredded gears. i don't think fellows has replacement parts for their personal shredder line.
Posted on Nov 16, 2009
Fellowes Powershred 220 gives a perfect cut on half of the paper only? How can this be fixed to give a perfect shred across a whole sheet of A4 paper? Can anyone help?..PLEASE..
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
Jan 16, 2011 | Fellowes 220 Powershred Strip-Cut Shredder...
THE SHREDDER ISNT SHREDDING ANYTHING ANYMORE, the power still runs and it will still take the paper but its not shredding anymore???
You wil need to Have the shredding head rebuilt or replaced. and or a new machine. A new head is very expensive. Here is the number for fellows 800-955-0959. Check on parts if they are still available. Hope this helps your friendly service tech (colorado).
May 06, 2010 | Fellowes Powershred 220 Shredder
Shredder continues to run after page is shredded, must be manually switched off.
there is a sensor that detects paper in front of it to turn on the shredder mech. it is probably covered with paper dust so the machine constantly thinks there is paper being shredded. give it a clean with a qtip moistened with isopropyl alcohol - make sure the shredder is unplugged first.
Jun 20, 2009 | Fellowes Powershred P-45C Shredder
May 16, 2009 | Fellowes 3011001 Shredder
The "bin full" keeps on coming on
first off, fellowes has had problems with the bin full sensors that sometimes, can only be corrected by replacing them. however, there are two things to check. make sure it doesn't have a bunch of shredded paper hanging down from the cutters. that can trigger the bin light as the sensore are located under the head, but above basket. last, but not least, clean the sensors. they get paper dust on them after awhile causing same indication. if those two things don't fix it, it will have to have sensors replaced.
good luck,
razors
Jan 20, 2009 | Fellowes Manufacturing Powershred C-220...
OK lets try.
WITH MACHINE OFF
Hope this helps
Dec 05, 2008 | Fellowes Powershred C-220 Strip-Cut...
Powershred PS 70
This is how a got my hard to fine gear!
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
Apr 18, 2008 | Office Equipment & Supplies
Only one-half (righ side) of the shredder works, left side does not shred
Fellowes has a five year warranty on the cutting block of their shredders. (The cutting block is that part of the machine that actually does the shredding of the paper) Take it back to the store where you bought it ans they should either replace the cutting block or exchange the entire machine, but it will take about a week or more, depending on where you are located. At least it shouldn't cost you anything.
Sep 05, 2007 | Fellowes Powershred 480 Shredder
Fellowes 3011001 Shredder Logo
21 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Jim Keysor
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
