Question about Achiever CCS5000 Shredder
Our CCS5000 will not turn on. How can you tell if the fuse is blown?
Shredder works in reverse only.
How does it act when you try to make it work in the normal operation direction? Does it make a sound like it's trying and then stops or it simply doesn't work? If it does indeed make the sound there possibly is something jammed in the cogs that move the rollers that feed the paper in the scissors.There also could be a bit of dust build up in the switch itself that disabled the contact. Try to blow some compressed air into the switch(make sure the unit is turned off and the aircan is not flamable) and you should probably check the fuses also to make sure that none is blown.
Let me know how it goesVlad
Nov 30, 2011 | Achiever CCS5000 Shredder
How can i tell if my amp is blown
check your amps fuses if they are blown thats your problem also check the fuse underneath the hood from the cable going to the amp if that fuse is blown fix it. that will turn ur amp back on. also if your blue remote wire is loose it will not tell the amp to turn on. thats how u can tell. if all fuses are intack. and blue wire is then its blown
Mar 19, 2011 | Car Audio & Video
I need a fuse for my ccs5000 achiever shredder. Do you know where one can be purchased?
Radio shack has a good selection. Make sure you match it exactly. Do not put a larger capacity fuse in there. It can burn the circuit board.
Jun 18, 2009 | Achiever CCS5000 Shredder
Shredder won't turn on
Has your problem been solved
Please get back to me
Thanks
Jul 07, 2008 | Achiever CCS5000 Shredder
Achiever shredder
The fuse has blown and we need a new fuse for it. We need the fuse number that is on the tip of the fuse. Do you know where we are able to purchase them from?
Jun 10, 2008 | Achiever CCS5000 Shredder
Achiever Shredder CCS5000
Is it on a 20 amp circuit? Check to make sure that it doesn't have a grounding problem or even the plug could be reverse woired.
Oct 10, 2007 | Achiever CCS5000 Shredder
CCS 5000 Achiever Shredder
You need to purchase a real heavy duty shredder that will handle your work applications. Call 800-342-7362 EG Brennan & Co LLC can help you in this regard!
Apr 12, 2007 | Achiever CCS5000 Shredder
Where do I purchase a fuse for the CCS5000
These are the guys who should help; http://www.worldofficeproducts.net/contact.html try them first for troubleshooting and spares and dealer locations. they don't have anything online with any details more than sales literature. Hope this helps - please ask again if no luck :)
Apr 11, 2007 | Achiever CCS5000 Shredder
Achiever CCS5000 Shredder Logo
43 people viewed this question
Top Achiever Office Equipment & Supplies Experts
 Mark Greenbaum
Mark Greenbaum
Level 1 Expert
Gilbert Ruiz
Are you an Achiever Office Equipment and Supply Expert? Answer questions, earn points and help others
