Doss asimom 1189 won't turn on / off - Computers & Internet
I have a Belkin wireless router model F5D7633AU4A and I show a Excellent signal.....but it will not Acquire a network address
Do you mean your computer wil not acquire a network address from the router? If this is the case on your computer, click on start then click on run, in the run window type in cmd and press the enter key. You will now be in the windows doss prompt. Once in the doss prompt type in 'ipconfig /release' with quotes removed and press enter. After you do this type in 'ipconfig /renew' with quotes removed and press enter. After you do this restart the computer and see if it acquires the address. If this does not work try restarting the router. Keep me posted. If you found this solution helpful please rate it. Thanks - Tech101
Jun 25, 2008 | Belkin Computers & Internet
My acer a1-850 is frozen, I can't even turn it off
If you press the power switch in and hold it sometimes what seems like 4 or 5 minutes, but in reality is more like 2 it should turn off. If it dose not, disconnect all power to the device. When you turn it back on it should give you a doss screen that will allow you to scroll down to a repair computer program. Just fallow the on screen instructions and you'll be fine.
Apr 29, 2017 | Acer Computers & Internet
Got a 2001 chevy venture 3.4.. got 2 codes po171 & p1189. An my temp gauge jumps never over heatin but going down. Any suggestions?
171 is bank one lean. 1189 is the oil sending unit. Start with 1189. Replace the oil sending unit. They always fail. Never had to fix wires for these. Probably leaking oil anyways. 171, Two places to look on these 3.4/3.1 engines. First is the vacuum lines and rubber fittings. Best to check them all, but bank one is one the radiator side of the engine. Also the intake upper plenum is known to crack around the bolts. Use WD40 . start the engine and spray it around the intake. If it starts running better, you have a crack or bad gasket. Fix as necessary.
Apr 27, 2015 | Cars & Trucks
I want serial of nero9 - Guest
DON'T FORGET TO RATE
Nero 9 keys :
9M03-01A1-PCX7-K31A-8A94-98PT-KT2E-522A
1k220867079566m45766853875cc
1K22-0867-0795-66M4-5214-0096-0805
7K22-001B-11OS-E11SS-S9M4-B4X3-7E11
6K21-0147-1189-1MAX-5620-666E-2ECC
9M03-01A1-PCX7-K31A-8A94-98PT-KT2E-522A Nero v9 : 9M03-01A1-PCX7-K31A-8A94-98PT-KT2E-522A
Blu-ray Disc Authoring Plug-in: 9M13-0083-2710-5622-98W3-TL0A-THW4-9A0T
Gracenote Plug-in : 9M0C-01A2-K817-3LK8-9X6M-WK3U-L942-3WE1
DTS Plug-in : 9K00-0003-8M80-6320-5043-1458-XAA5
mp3PRO plug-in : 1A41-0800-0000-2903-1645-8530
Nero BackItUp v4 : 9M11-01CA-032E-01A5-AA9C-H44K-6T9U-X4HW
Nero MediaHome v4 : 9M06-019C-TTET-880Z-5PUM-6XA2-5MEC-35WM
Nero Move it : 9M09-01AC-5TE3-KEU9-177W-C6E0-6KCT-2W4K
Jun 26, 2010 | Ahead Software Nero 9 Full Version for PC
Computer is in doss mode. how do i get it back to windows
Hi and welcome to FixYa,
Initially, pls type "EXIT" less the quotes then ENTER. Ths is assuming that what you have described is a DOS Shell running inside WinME. If on the otherhand the computer has booted to DOS (although most unlikely), pls type "WIN" less the quotes then ENTER
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Nov 25, 2008 | Computers & Internet
Three in one RCA U'remote - four digit codes for symphonic tv? code 1189 amost
Try the code search option that tries 100 different codes. If you do not have the manual for the remote, then you can get it here for free:
http://www.replacementremotes.com/tvcodes/index.html
Mar 24, 2008 | RCA RCR350 Remote Control
Code
Check this link:
http://forum.ecoustics.com/bbs/messages/5/10253.html
Apparently there is no code (even according to the manufacturer).
However, one posting reads:
I have a RCA universal remote, (sold at Walmart)
Sanyo code #1189 works on my Duraband TV
So, try 1189 to see if that works
Mike
Nov 21, 2007 | Durabrand PDV-705 Portable DVD Player
Computers & Internet Logo
67 people viewed this question
David Payne
David Payne
