Question about HP LaserJet Pro 400 M401N Laser Printer
How to replace the fuser on an HP LAserJet Pro 400
SOURCE: Printer HP ColorLaserJet displays Fuser Error
My HP Color Laserjet 2600n Printer is giving me error as
" 50.2 Fuser error " . then every time i have to reatart my printer.
please give me suggestion.
thanks and regards.
ajinmumbai
Posted on Mar 28, 2008
  • 4 Answers
SOURCE: fuser error 50.2
1) First thing is check power source. If you have the printer plugged into a UPS (uninterruptilbe power source) unplug it and plug it directly into the wall. If it is plugged into the wall you might want to try a different outlet to see if it solves the problem.
2) Remove and reinstall the fuser. It may not have seated properly.
#) Make sure you installed the correct fuser. Should be RM1-1082. There should be a sticker on the fuser with this number. See the following article for more info. http://www.partsnow.com/service_today/0705.asp
If you still have the old fuser check also that it is a RM1-1082. If not you may have a euro version machine which would require a different fuser.
If the fusers match up you should check the voltage coming to the fuser if possible. If there is 100- 127 volts where the fuser plugs in you probably got a bad fuser or it was damaged in transit. If there is low voltage or no voltage you may have a board problem. Probably DC controller or Power Supply.
Posted on Mar 30, 2008
  • 10 Answers
SOURCE: 50.1 fuser error on HP 8150 LaserJet Printer
wow if you were an hp certified tech you would know instantly that 50.1 is LVPS also if you were or were not certified you could look at serv man and figure it out right quick
Posted on Oct 22, 2008
  • 13 Answers
SOURCE: how do i change the fuser?
CAUTION: Fuser may be hot. Turn off printer, unplug it and allow it to sit for 20
to 30 minutes before performing these maintenance procedures.
Fusing Assembly Removal and Replacement
1. Remove Back cover:
a.) Open the face up delivery door and press the door down to disengage two door stops
b.) Remove the two screws just above the door stops
c.) Swing the bottom of the cover out first, and then the top
2. Remove I/O cover:
a.) Rotate cover to clear the tabs on right side of cover
3. Remove fusing assembly:
a.) Disconnect black cable above main power cord receptacle
b.) Disconnect two cables on left side of fuser
c.) Remove duplex inlet guide (below fuser) by lifting two locking tabs
d.) Remove four screws from each corner of fuser
e.) Pull fuser straight back
4. Reassemble in reverse order
I have done 15 service calls on these printers
Posted on Jul 27, 2009
SOURCE: hp laserjet p2055dn Replace fuser unit
That is a job by it self. If you don't want to damage your printer, I'd suggest you take it to an HP dealer pay some money and get it first checked and if so be the case that it has to change, let them change it.
Posted on Aug 18, 2009
HP LaserJet Pro 400 M401DN Laser Printer keeps jamming at cartridge.
Is the paper stopping just at the cartridge or is it in the fuser. We have had a few of these fail with bad fusers. The only time we have had a cartridge issue is if the drive shaft on the right side of the cartridge falls off.
Sep 14, 2016 | HP LaserJet Pro 400 M401DN Laser Printer
Why is my hp Laserjet pro 400 mfp 475dw not showing on the LCD as well as scanner calibration
I have had to replace the lcd screen on several of these. Does the unit go thorugh the powerup noises such as fuser rotation and scanner hunting for home? If not, might be the power supply.
Aug 19, 2014 | HP LaserJet Pro 400 color MFP M475dw -...
How do you fix a 59.3 error
59.3 indicates the fuser motor is not starting up.
This usually means the fuser motor needs replaced.
Part Number RM1-8609-000CN
Mar 13, 2014 | HP LaserJet Pro 400 color M451dn - Printer...
My printer hp laser pro 400 show message 50.3 fuser error
hello ,,
50.x Fuser Error
Description
The product has experienced an error with the fuser.
Recommended action
Turn the product power off, wait at least 30 seconds, and then turn the product power on and wait for it to initialize.
Turn off the product, wait at least 25 minutes, and then turn on the product.
If you are using a surge protector, remove it. Plug the product directly into the wall socket. Turn the product power on.
If the message persists, contact HP support.
Oct 21, 2013 | HP LaserJet Pro 400 M401DN Laser Printer
HP LaserJet Pro 400 MFP showing offline when printing
My computer says that the printer is offline and my printer will not print idk what to do... suggestions????
Oct 10, 2012 | HP Laserjet Pro 400 Mfp M425dn...
HP LaserJet Pro 400 M401N Laser Printer Logo
3,135 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
