Question about Avanti 310SST Compact Refrigerator
Fridge temp high
Compact fridge (Avanti) used to store meds does not maintain proper temp have defrosted unit
  • 173 Answers
Freon and a compressor is about as easy as it gets....Loss of freon will cause erratic cooling...also if you can feel it touch the compressor after it shuts off if if feels like its really hot ....bad compressor that kicks an internal breaker....bad news then time for new one also only a airconditioner man can put freon in no 12 . but freon will stay for 50 to 80 years for i tested some old fridges and still cool fine.
Posted on Aug 31, 2007
Refrigerator is not cooling properly. Warm all the time.
The issue could be the cold control, timer, wiring, or the compressor.
The temp control has to be closed for voltage to get to the timer. The timer then calls for the fans and compressor to run. The timer could have stalled after a defrost cycle or the cold control could not be sending voltage to the timer.
Jan 28, 2011 | Avanti EC15W-2 Compact Refrigerator
My Avanti refrigerator (about 12 cubic feet) is freezing everything in the refrigerator section.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Sep 07, 2010 | Avanti 248Y Compact Refrigerator
Water in the bottom of the refrigerator
this sounds like a clogged defrost drain remove cover and check drain tube for obstructions
Apr 04, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My compact fridge does not defrost and ice builds up in freezer section. How can I disconnect the freezer and not use it?
Lynne, the freezer section is what provides the cooling for the fridge, so there is no way to disconnect the freezer and still be able to have the fridge operate.
With the small compact fridges, the only thing you can do is to manually defrost the unit, when the ice buildup gets too much, which can vary, based on how you use your fridge, how often it gets opened and closed, etc.
Some compact fridge models have a small push button in the center of the temperature setting control knob - if your's has one, you can push that to initiate a self defrost cycle. However, you'll need to have some towels handy to collect the water that will result from melting off the freezer section.
There are not many small, compact fridge units that have the no-frost feature of full sized fridges, as it is more costly to build in all the needed components required to have frost-free operation. Not to mention the size of the fridge gets much larger, because of all the space needed to house those features (defrost heaters, electronic controls, ciruculating fans, control vents, sensors, drip/drain pan, etc., etc.)
Hope you find this Very Helpful and best regards!
Aug 25, 2009 | GE Refrigerators
Avanti issues
Take this unit back even if you bought it used and get a new one it is still under warranty.
Oct 07, 2008 | Avanti 18CYW Compact Refrigerator
Refrigerator problem
I have a Magic Chef 3.6 cu. ft. Model#mcbr3605 thats 3 years old and has stopped working. When I plug it in you hear it start then you hear a "click" and it turns off. If you leave it plugged in the compressor gets hot. Can this be fixed or is it trash ? Thanks in advance.
Sep 01, 2008 | Magic Chef MCBR440 Compact Refrigerator
Samsung RS20....noticed this AM the fridge side in not cold enough and the temp number on the door is flashing on and off.
Sounds like you're frosting up.
Defrost unit manually. Clean the condenser coils. Don't leave liquids uncovered. Don't leave the door open unnecessarily. Make sure all air passages are open and clear. If this doesn't fix it long likely have lost some refrigerant and need a recharge.
Jun 08, 2008 | Refrigerators
I defrosted the fridge. Took 24 hours! but it won't go back on!
if u press the defrost button of the switch after some time the switch have to come to the original position it would have been stuck due to some problem do press it once more and it would be back to work have a nice day
Jun 27, 2007 | Avanti 310SST Compact Refrigerator
Avanti compact Refrigerator NOT COOLING
I had this same problem. I did some troubleshooting and figured out that the fan was being bogged down by ice. It wouldn't spin because the ice was so heavy. I turned the power off completely and let the ice melt. Once the ice was removed from the fan, the fridge began working again!
Feb 16, 2007 | Avanti EC15W-2 Compact Refrigerator
Avanti 310SST Compact Refrigerator Logo
184 people viewed this question
Top Avanti Refrigerators Experts
Vernon Taylor
Are you an Avanti Refrigerator Expert? Answer questions, earn points and help others
