Question about Locks & Locksmithing
Nu set lock box blinking yellow and will not open
2 Suggested Answers
SOURCE: lost combination to nu set lock box
You can dial all the combinations (1000) in a couple of hours while you watch TV. I just did one (2012 version with letters) and hit about half way through. The problem is going to be a lack of a key. You won't be able to open the shackle on some versions and won't be able to reset the combination (same key for both functions).
Posted on Dec 10, 2009
Injector cylinder nu 4 nu 5
or ignition module or coil driver module or ecm
Aug 14, 2014 | 2001 Chrysler Sebring
What does the yellow blinking light mean on Mitsubishi WD65837
Here is a whole list for you :
Mitsubishi Blinking Codes :
Constant Green - TV is Powered On
Constant Red - Lamp Failure
Constant Yellow - DMD temp is very high
Blinking Yellow - Lamp cover is open
1 Red Blink, 6 Yellow Blinks - Color Wheel Failure
3 Red Blinks, 4 Yellow Blinks - Lamp Failure
3 Red Blinks, 6 Yellow Blinks - Exhaust Fan Not Working
3 Red Blinks, 7 Yellow Blinks - DMD Fan is not rotating
5 Red Blinks, 7 Yellow Blinks - Ballast Problem
6 Red Blinks, 6 Yellow Blinks - Lamp Missing, Bad Cable between lamp and ballast
And the Lamp cover must be here somewhere in your TV :
For more you can refer to the below link :
Mitsubishi DLP TV Blinking Code Errors Explained Overview of Each...
Jul 07, 2014 | Mitsubishi WD 65837 65 in. HDTV
Lost combination to nu set lock box . I would like to open the box and be able to reuse it.
Nov 20, 2009 | Locks & Locksmithing
I wanna program my urc3021remote to my ds coverter box but cant find the code
You may want to try searching for the ds converter box code for your URC 3021 remote automatically. These are the steps:
  1. On the remote control, press CBL/SAT once.
  2. Press and hold SET until the LED blinks twice, then release SET.
  3. Enter 9 - 9 - 1.The LED will blink twice.
  4. Aim the remote control at the the converter box and slowly alternate between pressing POWER and CBL/SAT. Stop when the converter box turns off.
  5. To lock in the code, press and hold SET until the LED blinks twice, then release SET.
Hope that helps.
Sep 27, 2009 | One For All URC-3021 Remote Control
Projector is brand new out of the box. Powers up displays Sim2 logo then lamp goes out power light starts to flash and turns off about 3 minutes later. Same thing every time it's turned on. Anyone had the...
the number of blinks determine the problem:
Environment Over Temperature- 1 long blink / 1 short blink
DMD Over Temperature- 1 long blink / 2 short blinks
Lamp Over Temperature- 1 long blink / 3 short blinks
Fan1 Locked- 1 long blink / 4 short blinks
Fan2 Locked- 2 long blinks / 2 short blinks
Fan3 Locked- 2 long blinks / 3 short blinks
Fan4 Locked- 2 long blinks / 4 short blinks
DMD Initial Fail- 3 long blinks / 1 short blink
Lamp Initial Fail- 3 long blinks / 2 short blinks
Ballast UART Error- 3 long blinks / 3 short blinks
Temperature Sensor Fail- 3 long blinks / 4 short blinks
Inter Lock Open- 4 long blinks / 1 short blink
any of these will result in lamp off and shutdown.
Aug 28, 2009 | SIM2 Domino D10 Home Theater Projector...
How do I change the combination code for the glove box if there is not a way how would I find out what the combination is
I assume you know the current combination and can open it. To set the combination to a number code of your choice you must first remove the red plastic guard over the yellow tab next to the combination dials. Push the glove box release lever to the right to open the glove box. To change the combination:
1. With the glovebox open, hold the release to the right and slide the yellow tab up. This locks the release open and permits you to reset the code.
2.After resetting the code, write it down in case you forget it.
3. Slide the yellow tab down and the release will return to the closed position.
4. Close the glove box and move the dials off the code you set to lock it.
This is all from the 89 Pontiac Owners Manual. Good luck, hope it works.
Jun 15, 2009 | 1989 Pontiac Grand Prix
Nu tec crt 54cm tv
the problem is the volume/sound
Oct 28, 2008 | Televison & Video
Digital set top box saying needs lock key password .
Hi.
You dont say what make or model box you have ?
But alot of manufacturers use four zeros(0000)
If no one has put in A customised code this may work.
http://dysonmanuals.llc.nu/
Jul 05, 2008 | Televison & Video
Re: K displayed and Volume control
Hi.
Do this it will remove your set from factory mode.
  1. Unplug the AC power cord of TV set .
  2. While holding down the “VOL (–)” and “INPUT” keys on the set at once, plug in the AC power cord to turn on the set.
  3. The letter K should have disappeared from the screen.
Your set will now work correctly.
May 25, 2008 | Sharp AQUOS LC-32D43U 32 in. LCD...
Locks & Locksmithing Logo
Top Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
