Question about Apple Sound Id 510 W/ Earprint App Iphone Bluetooth Headset
My sound ID 510 will connect to my iphone 5 and then disconnect. I've turned both off and then on, like instructions, disconnected car Bluetooth, still - goes on, connects and then goes off. any suggestions?
  • 35 Answers
SOURCE: IPOD automatically disconnects
the settings in itunes need to be changed so that you can sync manually
Posted on Jan 07, 2008
SOURCE: Iphone bluetooth is not working
the solution is................wait for someone to come up wiv an app for sending recieving data thru bluetooth,otherwise iphone bluetooth only works with in-car/headset ect....
Posted on Mar 04, 2009
  • 21 Answers
SOURCE: How do I set up an iPhone 3G Bluetooth connection?
first go to settings, general, bluetooth, make sure it is on, then try your toyota steps. good luck
Posted on Apr 04, 2009
  • 495 Answers
SOURCE: My ipod is frozen. "Connected eject before disconnected."
Hello, if it's still frozen try holding the power button and the center of the scroll wheel, or the power button and the top of the scroll wheel until it restarts, then try re-connecting it again.
Posted on Nov 30, 2009
BarrettDenCo
  • 1772 Answers
SOURCE: Iphone 4: I connect to
Sorry to read about your problem, I hope this helps you out.
it will not do a auto connect, you will have to hit your headset button to talk, and then the unit will reconnect. their are some headsets, that will send out a auto connect..
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Jan 01, 2011
Testimonial: "THANK YOU"
How do I connect the bluetooth on a marshall stanmore bluetooth speaker?
Check if you have the correct icon, or look on the web for help.
Nov 04, 2014 | Marshall Stanmore Bluetooth Speaker
Tip
How to Pair or Connect the Plantronics 510 Bluetooth Headset to your Bluetooth...
1. Turn on Bluetooth within your phone - Consult phone instruction booklet
2. Put phone into pairing mode - Consult phone instruction booklet
3. Put headset into pairing mode - With headset on, press and hold call button and the volume up simultaneously until the headset begins to flash red and blue.
4. Select "Add new device" on your phone.
5. Select the Plantronics headset when prompted. Enter "0000" as passcode.
6. Your 510 headset will now have a continuous blue light blinking.
7. Choose "Yes" if your phones asks if you want to bond to the 510 bluetooth headset.
8. Your phone is now paired with the Plantronics 510 headset and ready for use.
on Jul 14, 2010 | Cell Phones
Tip
Bluetooth StatusThe Bluetooth icon appears in the iPhone status bar at the top...
Bluetooth StatusThe Bluetooth icon appears in the iPhone status bar at the top of the screen:
  • (blue) or (white): Bluetooth is on and a device is connected to iPhone. (The color depends on the current color of the status bar.)
  • (gray): Bluetooth is on but no device is connected. If you’ve paired a device with iPhone, it may be out of range or turned off.
  • No Bluetooth icon: Bluetooth is turned off.
on Dec 23, 2009 | Apple iPhone 3G
Syncing it to my 3g I-phone without a manual
This link should help you pair your voyager 510 to your iPhone:
http://www.headsetsdirect.com/plantronics-voyager-510-bluetooth-pairing-instructions
Good luck from Headsets Direct - 800-914-7996.
Aug 22, 2011 | Plantronics 510 Voyager Headset - PLN-510...
I am trying to disconnect my bluetooth from my old cell phone and reconnect it to my new cellphone
Unable to connect my new iphone to the bluetooth in my car.
I've turned off the blue tooth in my old phone but it only turns off the bluetooth in the car. I have tried to then reconnect my new iphone, which is searching and showing that it has located the bluetooth (blue tooth flashing in car, shows on the sceen for a second and then turns off with message 'no service' phone off. If I turn on the old phone, everything comes back on.
Any ideas?
Jan 23, 2011 | Motorola Mobility Bluetooth Hands Free...
Same exact problem- music player works fine with headphones
If you had a bluetooth device connected and it did not disconnect properly then the phone may be trying to play the sounds to the bluetooth and not the speaker, Turn the phone's bluetooth off and then on and it should work. Also, if you look at a sound file or video file it will show the bluetooth symbol next to it, which means that it is playing to bluetooth and not the phones other outputs.
Jun 09, 2009 | Samsung Eternity Cell Phone
No sound from pc after disconnecting from headset
Open up the Sounds and Audio Devices control panel, hit the 'audio' tab and make sure that the default playback device is not the bluetooth phones, but rather you sound card.
Aug 28, 2008 | Zoom 4380 Wireless Headphones
Iphone Hangs
do this: Step 1. Turn off your iPhone.
Step 2. Hold down the power and home button.
Step 3. When you see the Apple logo, release the power button but continue holding the home button down.
Step 4. Open iTunes and wait for it to tell you that its in restore mode.
Alternative Method:
Step 1. Connect iphone to USB then listen to the sound when it connect and disconnect.
Step 2. Hold the home and power buttons until hear the disconnect sound then release power button.
Step 3. Wait until you hear another sound then release home button.
Jun 30, 2008 | Apple iPhone Smartphone
Plantronics Voyager 510 & Blackberry Curve
 Plantronics Support Phone Number: 1-800-544-4660
Do not use the power button to sync.
To sync device, Press + button (volume) and Silver button (on boom) at simultaneously. LED Light will blink RED & BLUE.  Device ID should appear on your screen.
Jan 14, 2008 | Plantronics 510 Voyager Headset - PLN-510...
Apple Sound Id 510 W/ Earprint App Iphone Bluetooth Headset Logo
51 people viewed this question
Top Apple Radio Communications Experts
Michial Gueffroy
Tom Chichester
Caitlin Romagna
Caitlin Romagna
Level 1 Expert
Are you an Apple Radio Communication Expert? Answer questions, earn points and help others
