Sharp AR-M237 Copier Logo
Posted on Apr 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
U2-40 I HAVE A SHARP AR-M237 COPIER WHEN I TURN THE POWER ON, I GET AN ERROR MESSAGE: CALL FOR SERVICE CODE U2-40 I CHANGED THE CARTRIDGE AN THE ERROR MESSAGE DIDN'T DISAPPEAR. PLEASE HELP.
Anonymous
Level 2:
Sniper:
  • Expert 54 Answers
  • Posted on Apr 17, 2009
Anonymous
Expert
Level 2:
Sniper:
Answers
54
Questions
Helped
44465
Points
133
Push P * C* in quick succession to enter simulation mode. Once there, enter 16 on the keypad. push the print button (like making a copy). Push 1 for yes then print button again. push the CA button. Copier should reboot and run fine for you.
  • wharrell973 Feb 21, 2011
    i tried this solution and i still have the U2-40 code. i changed the print cartridge and the U2-40 code came up. it did reboot and said to check the cartridge then went back to the U2-40 code
2answers
SHARP AR-M237 H2-00 ERROR CODE---HAVE INSTALLED NEW FUSER UNIT WITH SAME ERROR/CODE PROBLEM.
check harness and connector betwen thermistor and control PWB.
clear the error code by using SIM 14 if all didn't work you may have defective AC power supply
I hope this help
3helpful
2answers
Change the toner cartridge message doesn't go away on AR-M237
plese check you have changed the same partno toner or not. if its ok you have problem in connector wich hold the toner cartrdge ic
My copier is SHARP AR-M237 will be to change the toner and I get an error. Code F2-04. What can I do in this case, please help.
your toner should be AR-270NT or AR-310NT. Try cleaning off the brass colored contacts in the plug on the back of the toner cartridge. The toner may also be faulty (try another) Also the contacts inside the copier may need to be cleaned by your copier technician.
How to reset u2-40 for sharp AR266 photocopier
Since this appears to be a non-US model I can only base my response on the closest US body type AR-M237.
U2-40 means the countdown (CRUM) chip in your toner cartridge either broke or went to zero. If you can put in a fresh CRUM chip in your cartridge, that's great, otherwise you'll have to replace the toner cartridge.
L4-01 means main motor lock, probably due to a brownout or otherwise missed timing. You can probably get by with a power off and on. Not sharing your copier with other devices on the same outlet will also help here.
To reset error codes, put the machine in test mode with the four-key combo: # - * - C - * ... 16-Start clears your U2 trouble, 14-Start and 17-Start clear the rest. Then hit CA and allow your copier to reboot. Good luck!
1helpful
Error Code E1-15 - can I fix this myself?
Most messages that state "call for service" are for instances where the unit is not running to prevent damage to the unit.
You should call an autherized or certified technician to work on the unit.
16helpful
4answers
F2-02 Error on Imagistics ZB35 machine
Sharp AR-5620N getting f-2 error. What is the solution
26helpful
5answers
F2-02 error on Sharp AR-M237
on this code you may have to clean out the developing unit and start with fresh developer. Make sure the developer unit is not leaking from one of the bearings. You may need a tech for this one...
Sharp AR-M237 Reset Codes
You have to get into the sevice mode and reset the "PM" counter back to zero. Go to service mode and enter code 24 then enter sub code 04 back to all zeros and exit out and turn the copier off then back on and it should disapear.
6helpful
2answers
Request service manual for sharp AR-5316
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=7b292ec58f421b3b3b442c1437984770&q=Sharp+AR-5316
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
