Question about Inland Wizling CG Glass Grinder
How do I use the second story work surface on my inland glass grinder
How do I dress a grinding wheel on a bench grinder with a viberating wheel.
Hello.
First of all I must warn you of the dangers bench grinders can represent. Here in Britain no one connected with a business is allowed to carry out any maintenance on any none-portable grinding machine unless they have attended and passed a course on the subject and every employer must keep a register recording what maintenance has been carried out and by whom. Grinding machines have been responsible for many industrial "accidents".
Householders and private individuals are exempt from the Law but cannot afford to be less well informed even though the five and six inch bench grinders sold to the domestic user represent a somewhat reduced risk, great care and precautions are still required, not the least of which is the use of good eye protection even if the grinder is fitted with shields.
The first problem about dressing the grinding wheel of a grinder intended for the domestic market is the tool rests are usually too small and insubstantial for the vibrating star-wheel type wheel dressing tool to be used correctly.
A demonstration would be the best way to learn how to dress a grinding wheel and there are many available on Youtube and here is a link to a particularly good video.
https://www.youtube.com/watch?v=RqxfJ4DtZtQ
Finally, it is best to be aware of one little thought about problem. There is an optimum speed range when a grinding wheel works efficiently and small domestic grinders barely turn fast enough for them to be properly efficient, probably because it is reckoned price and user safety takes priority over efficiency.
The speed that is of concern is the surface or peripheral speed of the grinding surface rather than the rpm of the spindle and should that speed fall too low the wheel will not be able to operate efficiently, will become dull more quickly with a greater tendency to clog and the wheel will become hot in use and hot grinding wheels soon become dangerous.
I hope you will be able to see that by reducing the diameter of a grinding wheel by dressing it also reduces the surface speed of the grinding surface even though the spindle speed remains the same. The relationship between surface speed and spindle speed is why small grinding points need to spin at 20,000 rpm and an eight foot wheel at just a few hundred rpm - in both cases the surface speed is similar.
A domestic grinder should not be used for heavy work but as the size of the wheel is reduced it should be used only for increasingly light work and if it is desired to carry out "normal" grinding operations it would be better to replace the wheel sooner rather than later.
Feb 19, 2015 | Craftsman Grinders
Where do i find a free service manuals to download as a PDF of Okamoto surface grinder
do a search for it.okamoto surface grinder # ???????? free service manual. you should be able to find it.
Jul 22, 2014 | Global 6" W 12" L Okamoto Linear 612...
Glastar allstar grinder wheel not turning
You may have seized the bearings. Either replace the motor or rebuild using new bearings if the motor even works
Nov 29, 2013 | Glastar Diamond Star Grinder w/extras -...
Is it safe to use the 41/2" hand grinder one handed?
The danger of using a grinder single handed is that if the disk catches in the workpiece, the grinder will try to pull out of your hand and you can loose control of it and risk possible injury or damage what you are working on. This is especially dangerous if you are working off a ladder or on a height as you could loose your balance.
When using an angle grinder you should always wear eye protection and try to keep your head to one side out of the plane of the disk avoiding sparks and possible fragments of the disk which will fly at high speed if it shatters.
Mar 04, 2011 | Garden
Lights are on but mouse doesn,t work.Inland wireless mouse and keybord. Keyboard works great.
Check with fresh batteries.. Did you sync the mouse with transciever? Push tiny button on transceiver, (maybe hold for few seconds) light flashes quickly.. then push tiny button under the mouse, light stops flashing. Try few times, maybe otherway round. If still not work consider defective.
Dec 11, 2010 | Inland u-Touch wireless Keyboard/Optical...
I am looking for a glass replacement for the receptical for a Kitchenaid top of the line coffee grinder as we dropped the glass receptical.
Try contacting Kitchenaid directly. They have a fairly extensive parts department:
Contact Center Hours:
Monday – Friday 8am – 8pm EST
1-800-541-6390 http://www.shopkitchenaid.com/cc_contactus.asp
Jul 20, 2010 | KitchenAid Pro Line Burr Coffee Mill...
A plate broke in the dishwasher and glass fell into the food grinder area. I need to remove the glass. I have one of the KUD10 models of dishwashers.
In order to remove the glass you will need to lift the top of the grinder off. To do that is a rather complicated procedure however and I would recomend that you have a repair service come to remove the glass. Attempting to do it yourself could damage the inside of the grinder and possibly make your dishwasher not work at all.
Dec 12, 2009 | KitchenAid Dishwashers
Inland ps2 kvm switch
The control for Inland KVMs is ScrLk + ScrLk + #. Example: ScrLk + ScrLk + 1 gives you the first attached computer, ScrLk + ScrLk + 2 gives you the second.
Apr 10, 2009 | Inland 08216 2-port KVM Switch
Coffee Beans Empty - but the hopper is full!
Caffeind...the problem is likely still some bean remnants stuck in a switch which is causing the problem. Get some newspaper and open it up on a flat surface. Invert the grinder and give it a couple of thumps on the newspaper. The chips should loosen up and fix it. Remember, beans are both sharp in shape and oily in makeup...perfect for getting stuck.
May 08, 2008 | Gaggia Titanium Espresso Machine
Inland Wizling CG Glass Grinder Logo
27 people viewed this question
Top Inland Saws Experts
Bill Boyd
Tom Chichester
ray gallant
Are you an Inland Saw Expert? Answer questions, earn points and help others
